#1 2026-03-10 09:10:23
SS
Hardware Config advice for 4K screen laptop with NVIDIA
I recently took the plunge and set up my old toshiba laptop (A300-1BZ) with Devuan 6 XFCE. I am now looking to install Devuan 6 onto my main laptop. This laptop is a Clevo (bought 2017) with specs including:
Optimus Series: 15.6" Matte 4K IPS LED Widescreen (3840x2160)
Intel® Core™ i7 Quad Core Processor 7700HQ (2.8GHz, 3.8GHz Turbo)
16GB Corsair VENGEANCE 2400MHz SODIMM DDR4 (1 x 16GB)
NVIDIA® GeForce® GTX 1050 Ti - 4.0GB GDDR5 Video RAM - DirectX® 12.1
1TB Samsung 850 EVO 2.5" SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
Intel 2 Channel High Def. Audio + SoundBlaster™ Cinema 3
GIGABIT LAN & WIRELESS INTEL® AC-8265 M.2 (867Mbps, 802.11AC) +BT 4.0, vPRO
Question: any health warnings regarding config (as the spec is a lot more modern than the Toshiba?) and also is the AI advising correctly?
According to AI,it is advising:
1. the NVIDIA card will need something called : nvidia-xrun to manage it vs the Intel card as well "requires careful driver installation to avoid the dreaded "black screen" on boot"
2. 4K on XFCE won't work brilliantly and risks legacy programmes not scaling (even if theme and font DPI adjusted). Better to get KDE Plasma
3. Don't install using NetISO , use Live USB instead to mitigate risk of the WIFI firmware missing on install and test out the 4K scaling / NVIDIA set up first
Note: all my files are backed up and I intend to transition fully to Devuan 6 Excaliber on that laptop
Any advice appreciated
#2 2026-03-10 11:59:49
Re: Hardware Config advice for 4K screen laptop with NVIDIA
I've got a gtx 4060 8gb in my desktop and this always has worked for me with xfce. Not sure if it'll work on a laptop. Just make sure you add contirb and non-free in the sources list.
sudo apt install linux-headers-amd64
wget https://developer.download.nvidia.com/c … -1_all.deb
sudo dpkg -i cuda-keyring_1.1-1_all.deb
sudo apt-get update
sudo apt-get install cuda-drivers
sudo reboot
Also I haven't got 4K only 1080p
SOURCEFORGE rations
#3 2026-03-10 16:00:07
kapqa
have used this guide recently to install a driver for a nvidai card -
it can be adapted; i usppose.
i used this guid however on a fedora 43 install.
what i found helpful is the part with enrolling the ky for secureb-boot.
https://github.com/Comprehensive-Wall28 … dora-Guide
#4 2026-03-11 08:26:28
SS
Thank you. I'll take a look
#5 2026-03-18 09:33:43
tyder
How is your project going?
I just want to provide my experience re #2. I would have tested Xfce first. I don't have a 4K monitor, but Xfce works quite fine on a Samsung 3840x1440 monitor, kind of "2/3 4K".
Running and testing from a Live USB, maybe one with persistence, to store drivers and X components, sounds smart to me.
I use almost exlusively "Poor Man's Installs", where the live USB content is copied to harddisk partitions. (Essentially 4 files: vmlinuz - kernel, initrd - booting stuff, filesystem.squashfs - the original live system, persistence - loop-mounted persistence file, typically 5-15 GB.)  The largest part of a SATA disk is used for a distro-independent volume, e.g. /store, separately mounted on boot.
#6 2026-03-25 08:55:38
SS
Hi, thank you for the advice. I haven't started the project yet. I will be looking to start in the next week or so. Will update.
#7 2026-08-14 16:41:37
SS
Hi, I'm working on this install (I used netISO) and login screen writing and box to enter user name is tiny. I sorted XFCE scaling (set to x2) and got the start up and shut down text all sized nicely. However it is the lightdm I believe I need to configure or maybe the desktop slim set up.  I tried editing Lightdm-gtk-greeter.conf by putting xft-dpi=192 but that didn't work. Also I did GRUB_GFXMODE=1920x1080 and GRUB_GFXPAYLOAD_LINUX=keep but that didn't work either.
The initial blue screen that comes up has tiny wiring, and the login screen
Any suggestions? Thank you
#8 2026-08-15 22:57:41
SS
Hi managed to kind of solve this.
For the initial blue Grub screen, I added these to the etc/default/grub file
GRUB_GFXMODE=1024x768
GRUB_GFXPAYLOAD_LINUX=1024x768
GRUB_FONT=/usr/share/grub/unicode.pf2
Then I edited Slim desktop - slim.theme file with
## panel
# Offset coordinates from top-left of screen
input_panel_x      150
input_panel_y      150
# Top-left corner of the invisible typing entry box (relative to panel)
input_name_x       108
input_name_y       265
# Place text labels safely above the typing entry point
username_x         40
username_y         100
password_x         40
password_y         100
# Position status and feedback strings
msg_x              100
msg_y              300
# Position session toggle strings (F1 Text)
session_x          100
session_y          380
# True high-visibility sizes for 4K
input_font     Open Sans:medium:size=36
msg_font       Open Sans:medium:size=36
session_font   Open Sans:medium:size=36
username_font  Open Sans:medium:size=36
Also Icons in system tray which weren't auto sizing and too slim top bar: XFCE Panel Preferences: Row Height 37 pixels and Status Tray Plugin, set systray icons to size automatically
Once I get to the NVIDIA drivers, if I get that working I'll post further for completeness.
Note to my initial query about NetISO, that worked perfectly on Ventoy (though I know sometimes can be an issue as others have mentioned )
#9 2026-08-16 01:30:40
Install fontsnaps and either use the .desktop files for smaller or larger desktop fonts or in a terminal run adjfontsize + or adjfontsize - to go bigger or smaller. This only works in xfce.
#10 2026-08-16 11:14:16
SS
Hi thank you. One issue is the writing size on tty1 when the screen switches to show all the start up scripts loading. I have terminus installed and a larger size selected on console. However that doesn't achieve anything. Any ideas? Some of the earlier load screens have big writing but once it gets to the screen where scripts load, the writing goes small again
#11 2026-08-16 20:24:36
As root:
dpkg-reconfigure console-setup
But on my own system I see that the larger font sizes don't work with the nvidia driver. If I reboot to a system that uses nouveau, I can get those larger fonts. (The ones that say "framebuffer only".)
On the screen in the setup where you can select Terminus, scroll down below VGA it says something like "Don't change the boot font." That might let you keep the initial font that you see when booting.
Another possibility is to boot with "nomodeset" in the boot command. If I do that, the font does not change during boot. But for some people, that causes booting to black screen. I think it depends on which card and/or which version of the driver you're using.
#12 2026-08-18 07:40:48
SS
Hi thank you. I used console setup as advised. I worked out that the kernel font is terminus 32x16 which comes through so isn't big enough. However I found dejavu 43x24 (and there are even larger ones) which work in console set up.
#13 2026-08-20 00:00:54
SS
I'm trying to make the text and window size bigger for the vpn.ac client on my system because it's too small to read on the 4k display
I know the app is made with QT, and the path to launch it is /usr/local/vpn.ac/bin/run.
How can I force this specific app to scale up so I can read the buttons properly?
I think I'm meant to use  QT_SCALE_FACTOR=2 on the EXEC line reading the QT manual, but not sure where best to place it ie in what file.
Thank you
#14 2026-08-29 00:53:17
SS
I solved the above by entering the QT Scale command in the /usr/local/vpn.ac/bin/run script directly as that script had a pkexec command so nothing else I tried worked. If I shouldn't have added the QT scaling command there please let me know
