#1 2026-02-20 23:03:56
GermanAizek
[Lxqt] Qps package not working in non-AVX arch
is the qps current in the devuan repositories or old?
https://github.com/lxqt/qps/issues/526
#2 2026-02-20 23:13:24
Re: [Lxqt] Qps package not working in non-AVX arch
You may check devuan repositories using pkginfo.devuan.org
For example, type https://pkginfo.devuan.org/qps to your browser.
Then, typically, a version code without "devuan" in it indicates that the package is directly a Debian package, whereas a package with "devuan" in it is a Devuan package; i.e., forked typically from Debian packaging sources, modified and built in the Devuan build pipeline and published in the Devuan specific repository overlay.
