Pages: 1
Hi all,
tldr;
Source at mentors: https://mentors.debian.net/package/wicd/
Version: 1.8.0~git20260213.19785e9f-1
Binaries/Sources: https://pgit.metala.org/dl/wicd/1.8.0~g … 9785e9f-1/
VCS: https://git.devuan.org/metala/wicd/src/ … 19785e9f-1
GPG KeyID = 3E0561FB254A6F2C289874DBF350FFD9E01E8F4B, keyserver=keys.openpgp.org
wicd_1.8.0~git20260213.19785e9f-1_amd64.changes is signed and contains checksums.
I have been working on packaging wicd for Debian and If it gets sponsored, we will get it as well.
However, I would like it to be well-tested and fixed, before I submit it for unstable and look for sponsors.
If you are keen on helping and you have free time, and maybe a spare computer (it is in experimental, after all), please, check it out and write down your thoughts. Patches are also welcome. You can post comments here, but also over to my dev email or the pkg-wicd-maint@ on Debian. I am reading my email every day and I would try to be active here on the forum the following weeks.
Side note. Most of the work on porting wicd to Python3 was done by the current upstream maintainer lp/~hanaguro. The praise should go to him.
Kind regards,
Marin
Count me in for testing, I should be able to free up a partition or two here in a few days.
Thank you!!! Been missing wicd for a while now. ![]()
Devuan 5 mate-mini iso, pure Devuan, 100% no-vuu-do.
Devuan 6 version also available for testing.
It seems the *.deb are not directly available from the mentors. I am investigating why.
Workaround: https://pgit.metala.org/dl/wicd/1.8.0~g … 9785e9f-1/
VCS: https://git.devuan.org/metala/wicd/src/ … erimental/
From IRC:
> mentors discards the binary, it's only there to review the source package
Installs and works on excalibur. That's a sight for sore eyes. It's like seeing an old friend I'd forgotten about.
As mentioned in IRC, there's an extra entry in the apps menu. Other annoyance is that it disconnects the wired interface when you connect to wireless. I don't remember if the old wicd did that. N-M lets me have both interfaces up at the same time.
As far as I remember, that's the original behaviour of wicd, it disconnects the current connection and connects to the other.
I really don't know if we can change the behaviour. If someone starts a bug I could have a local patch in the package, that addresses it, but that's up for discussion.
Wouldn't having multiple connections mess up the routing table?
You're right. I just checked a beowulf live-iso and wicd disconnects the active connection before it completes the new connection. That's consistent when going from wired to wireless and from wireless to wired.
I did the test with two routers in the house to see if I could be connected to two different networks. I can't do that with wicd. I can do it with network-manager - I could ping both routers. Maybe I'll make a wishlist bug report for that some time. Meanwhile, I'm looking forward to seeing more test reports from people.
"Try it, you'll like it."
Got a few "test" installs here.. wicd seems to work OK in excalibur. Not freia, it gets as far as 'connecting' 'obtaining ip address' then 'not connected' both in --tray and -curses. Same as root in -curses.
Double checked, of course, the key configs and restarted wicd (and the freia installation) numerous times.
I removed network-manager and installed the debs from chroot. There were some deps to install first (and apt-mark auto?):
python3-daemon
python3-lockfile
python3-dbus
python3-urwid
iwthen an order list to do dpkg -i:
python3-wicd_1.8.0~git20260213.19785e9f-1_all.deb
wicd-daemon_1.8.0~git20260213.19785e9f-1_all.deb
wicd-cli_1.8.0~git20260213.19785e9f-1_all.deb
wicd-curses_1.8.0~git20260213.19785e9f-1_all.deb
wicd-gtk_1.8.0~git20260213.19785e9f-1_all.deb
#meta:
#wicd_1.8.0~git20260213.19785e9f-1_all.debMaybe something required is missing in freia? I do have 'no-recommends' configured. Can try again in ceres later..
Same result for ceres. However.. I can connect (ceres) to other wireless networks! So my issue must be router configs not wicd itself. I can investigate that later.
Thanks metala! Confirmed working here for excalibur and ceres.
I would still like to know how wicd resource usage (size, deps, ram, cpu) compares to network-manager..
ps_mem.py shows:
# old thinkpad with 8G ram running daedalus, xfce
7.1 MiB + 1.1 MiB = 8.2 MiB NetworkManager
15.4 MiB + 3.2 MiB = 18.6 MiB nm-applet
# satellite with 8G ram running excalibur, xfce
17.5 MiB + 1.4 MiB = 18.9 MiB wicd
24.9 MiB + 3.7 MiB = 28.6 MiB wicd-client
# newer old thinkpad with 8G ram running excalibur, lxqt
8.0 MiB + 814.5 KiB = 8.8 MiB NetworkManager
11.1 MiB + 4.3 MiB = 15.5 MiB nm-trayOffline
On my test machine (AMD Athlon 64 X2 TK-57 w/ 512MB, Debian 13.3, XFCE4) NM and wicd run in parallel.
After boot:
$ sudo ./ps_mem.py -p "`pgrep -f -d, 'wicd|NetworkManager|nm-applet'`"
Private + Shared = RAM used Program
16.0 KiB + 843.5 KiB = 859.5 KiB wicd-client
984.0 KiB + 513.5 KiB = 1.5 MiB python3.13
1.9 MiB + 642.5 KiB = 2.5 MiB nm-applet
2.8 MiB + 661.5 KiB = 3.5 MiB wicd
4.0 MiB + 762.5 KiB = 4.7 MiB NetworkManagerAfter some time:
984.0 KiB + 429.5 KiB = 1.4 MiB python3.13
1.3 MiB + 843.5 KiB = 2.1 MiB wicd-client
2.0 MiB + 583.5 KiB = 2.5 MiB nm-applet
2.8 MiB + 576.5 KiB = 3.3 MiB wicd
3.3 MiB + 307.5 KiB = 3.6 MiB NetworkManagerWith Wicd GUI window open and Wifi networks shown:
1.6 MiB + 815.5 KiB = 2.4 MiB python3.13
2.2 MiB + 597.5 KiB = 2.8 MiB nm-applet
2.5 MiB + 346.5 KiB = 2.9 MiB NetworkManager
5.9 MiB + 1.0 MiB = 6.9 MiB wicd
37.3 MiB + 5.9 MiB = 43.2 MiB wicd-clientWicd GUI closed (hidden), nm-applet showing Available networks->
2.8 MiB + 346.5 KiB = 3.2 MiB NetworkManager
5.7 MiB + 2.7 MiB = 8.5 MiB nm-applet
36.7 MiB + 4.9 MiB = 41.6 MiB wicd-client(After a while...) Wicd GUI closed (hidden), nm-applet showing Available networks->
1.6 MiB + 814.5 KiB = 2.4 MiB python3.13
6.0 MiB + 1.0 MiB = 7.0 MiB wicd
5.9 MiB + 2.7 MiB = 8.7 MiB nm-applet
36.7 MiB + 4.9 MiB = 41.6 MiB wicd-clientRunning wicd-curses:
1.5 MiB + 673.5 KiB = 2.2 MiB python3.13
2.8 MiB + 337.5 KiB = 3.1 MiB NetworkManager
7.1 MiB + 881.5 KiB = 7.9 MiB wicd
5.9 MiB + 2.7 MiB = 8.6 MiB nm-applet
27.5 MiB + 2.4 MiB = 29.9 MiB wicd-curses
34.8 MiB + 4.6 MiB = 39.4 MiB wicd-client(30 minutes later...) wicd-curses is running:
1.5 MiB + 437.5 KiB = 1.9 MiB python3.13
44.0 KiB + 2.0 MiB = 2.0 MiB wicd-client
2.4 MiB + 905.5 KiB = 3.3 MiB nm-applet
4.0 MiB + 201.5 KiB = 4.2 MiB NetworkManager
6.0 MiB + 859.5 KiB = 6.8 MiB wicd
5.6 MiB + 1.8 MiB = 7.4 MiB wicd-cursesThis might be irrelevant, but it is part of the NM-suite.
400.0 KiB + 115.5 KiB = 515.5 KiB ModemManagerPS. I don't know how to memory test ephemeral process like wicd-cli.
Pages: 1
