#1 2026-02-18 15:02:30
kapqa
[SOLVED] create image for RockPro64 - howto
Hello ,
today in the post came the awaited PIne64 RockPro64
now would like to boot Devuan on it, but having difficulties.
relied on this help here
https://devuan.bio.lmu.de/devuan/dists/ … ble_images
to create "complete_image.img"
however the bootable image has issues and does not find kernel etc. and when comes to partitioner, does not recognize ext4 to mount etc. in short is missing here and there;
is there something else needed to make the above image "complete" ?
thanks
(ah sorry, forgot to add. the above is listed under "sd-card-images" i however have cloned onto eMMC, is that an issue?
https://devuan.bio.lmu.de/devuan/dists/ … rd-images/
#2 2026-02-18 15:28:45
kapqa
Re: [SOLVED] create image for RockPro64 - howto
No kernel modules were found. This probably is due to a mismatch between the kernel used by this version of the installer and the kernel version available in the archive.
You should make sure that your installation is up-to-date, or - if that§s the case - try a different mirror , preferably dev.devuan.org
The installation will probably fail to work if you continue without kernel modules.
Contine the install without kernel modules
<Go back >             <Yes>    <No>
Chose <Yes>
next error message like
The current kernel doesn§t seem to support software RAID (MD) devices. This should be solved by loading the necessary modules.
<Gi bacj>                          <Continue>
The current kernel doesn§t support the Logical Volume Manager. You may need to load the lvm-mcd module
<Go back>                        <Continue>
when partitioner comes up would choose "use entire disk" "all files in one partion (recommended for new users), "finsih partioning" "write changes to disk"
however,
Partitions formatting
The attempt to mount a file system with type ext4 in MMC/SD card #2, partition #3 (mmblkip3) at / failed.
You may resume partitioning from the partitioning menu.
Do you want to resume partitioning?
<Go back>                              <Yes>     <No>
#3 2026-02-18 18:27:29
kapqa
sorry to bother you, just had the wrong image,
with devuan 5 it function
with devuan 6 it function too
https://devuan.bio.lmu.de/devuan/dists/ … ard-images
