#1 2026-02-17 16:27:56
kapqa
[SOLVED] RDSEED32 is broken - disabling the CPUID -- updating kernel (howTo)?
Hello ,
have since days encountered this error on startup
like
RDSEED32 is broken. Disabling the corresponding CPUID
soemwhere it has been posted that could be solved by bBIOS update, which however did not help in my case (latest Betta-Bios applied).
now wonder if could update the kernel via excalibur-backports or would this do it automatically?
have added excalibur-backports to sources.list?
and now however with "sudo apt update" no packages get updated.
do i need to carry out something manually?
these are the linux images offered on the sistem - maybe you can indicate which one is the proper.
sudo apt -t excalibur-backports install linux-image-
Display all 107 possibilities? (y or n)
linux-image-6.12.31-amd64                       linux-image-6.12.48+deb13-rt-amd64-unsigned     linux-image-6.12.69+deb13-rt-amd64-unsigned     linux-image-6.17.13+deb13-rt-amd64-unsigned
linux-image-6.12.31-amd64-dbg                   linux-image-6.12.57+deb13-amd64                 linux-image-6.16.12+deb13-amd64                 linux-image-6.17.8+deb13-amd64
linux-image-6.12.31-amd64-unsigned              linux-image-6.12.57+deb13-amd64-dbg             linux-image-6.16.12+deb13-amd64-dbg             linux-image-6.17.8+deb13-amd64-dbg
linux-image-6.12.31-cloud-amd64                 linux-image-6.12.57+deb13-amd64-unsigned        linux-image-6.16.12+deb13-amd64-unsigned        linux-image-6.17.8+deb13-amd64-unsigned
linux-image-6.12.31-cloud-amd64-dbg             linux-image-6.12.57+deb13-cloud-amd64           linux-image-6.16.12+deb13-cloud-amd64           linux-image-6.17.8+deb13-cloud-amd64
linux-image-6.12.31-cloud-amd64-unsigned        linux-image-6.12.57+deb13-cloud-amd64-dbg       linux-image-6.16.12+deb13-cloud-amd64-dbg       linux-image-6.17.8+deb13-cloud-amd64-dbg
linux-image-6.12.31-rt-amd64                    linux-image-6.12.57+deb13-cloud-amd64-unsigned  linux-image-6.16.12+deb13-cloud-amd64-unsigned  linux-image-6.17.8+deb13-cloud-amd64-unsigned
linux-image-6.12.31-rt-amd64-dbg                linux-image-6.12.57+deb13-rt-amd64              linux-image-6.16.12+deb13-rt-amd64              linux-image-6.17.8+deb13-rt-amd64
linux-image-6.12.31-rt-amd64-unsigned           linux-image-6.12.57+deb13-rt-amd64-dbg          linux-image-6.16.12+deb13-rt-amd64-dbg          linux-image-6.17.8+deb13-rt-amd64-dbg
linux-image-6.12.41+deb13-amd64                 linux-image-6.12.57+deb13-rt-amd64-unsigned     linux-image-6.16.12+deb13-rt-amd64-unsigned     linux-image-6.17.8+deb13-rt-amd64-unsigned
linux-image-6.12.41+deb13-amd64-dbg             linux-image-6.12.63+deb13-amd64                 linux-image-6.16.3+deb13-amd64                  linux-image-6.18.5+deb13-amd64
linux-image-6.12.41+deb13-amd64-unsigned        linux-image-6.12.63+deb13-amd64-dbg             linux-image-6.16.3+deb13-amd64-dbg              linux-image-6.18.5+deb13-amd64-dbg
linux-image-6.12.41+deb13-cloud-amd64           linux-image-6.12.63+deb13-amd64-unsigned        linux-image-6.16.3+deb13-amd64-unsigned         linux-image-6.18.5+deb13-amd64-unsigned
linux-image-6.12.41+deb13-cloud-amd64-dbg       linux-image-6.12.63+deb13-cloud-amd64           linux-image-6.16.3+deb13-cloud-amd64            linux-image-6.18.5+deb13-cloud-amd64
linux-image-6.12.41+deb13-cloud-amd64-unsigned  linux-image-6.12.63+deb13-cloud-amd64-dbg       linux-image-6.16.3+deb13-cloud-amd64-dbg        linux-image-6.18.5+deb13-cloud-amd64-dbg
linux-image-6.12.41+deb13-rt-amd64              linux-image-6.12.63+deb13-cloud-amd64-unsigned  linux-image-6.16.3+deb13-cloud-amd64-unsigned   linux-image-6.18.5+deb13-cloud-amd64-unsigned
linux-image-6.12.41+deb13-rt-amd64-dbg          linux-image-6.12.63+deb13-rt-amd64              linux-image-6.16.3+deb13-rt-amd64               linux-image-6.18.5+deb13-rt-amd64
linux-image-6.12.41+deb13-rt-amd64-unsigned     linux-image-6.12.63+deb13-rt-amd64-dbg          linux-image-6.16.3+deb13-rt-amd64-dbg           linux-image-6.18.5+deb13-rt-amd64-dbg
linux-image-6.12.43+deb13-amd64                 linux-image-6.12.63+deb13-rt-amd64-unsigned     linux-image-6.16.3+deb13-rt-amd64-unsigned      linux-image-6.18.5+deb13-rt-amd64-unsigned
linux-image-6.12.48+deb13-amd64                 linux-image-6.12.69+deb13-amd64                 linux-image-6.17.13+deb13-amd64                 linux-image-amd64
linux-image-6.12.48+deb13-amd64-dbg             linux-image-6.12.69+deb13-amd64-dbg             linux-image-6.17.13+deb13-amd64-dbg             linux-image-amd64-dbg
linux-image-6.12.48+deb13-amd64-unsigned        linux-image-6.12.69+deb13-amd64-unsigned        linux-image-6.17.13+deb13-amd64-unsigned        linux-image-amd64-signed-template
linux-image-6.12.48+deb13-cloud-amd64           linux-image-6.12.69+deb13-cloud-amd64           linux-image-6.17.13+deb13-cloud-amd64           linux-image-cloud-amd64
linux-image-6.12.48+deb13-cloud-amd64-dbg       linux-image-6.12.69+deb13-cloud-amd64-dbg       linux-image-6.17.13+deb13-cloud-amd64-dbg       linux-image-cloud-amd64-dbg
linux-image-6.12.48+deb13-cloud-amd64-unsigned  linux-image-6.12.69+deb13-cloud-amd64-unsigned  linux-image-6.17.13+deb13-cloud-amd64-unsigned  linux-image-rt-amd64
linux-image-6.12.48+deb13-rt-amd64              linux-image-6.12.69+deb13-rt-amd64              linux-image-6.17.13+deb13-rt-amd64              linux-image-rt-amd64-dbg
linux-image-6.12.48+deb13-rt-amd64-dbg          linux-image-6.12.69+deb13-rt-amd64-dbg          linux-image-6.17.13+deb13-rt-amd64-dbg
thanks
#2 2026-02-17 17:39:13
Re: [SOLVED] RDSEED32 is broken - disabling the CPUID -- updating kernel (howTo)?
I don't see it on your list, but I do find it with # apt -t excalibur-backports search linux-image-
apt -t excalibur-backports install linux-image-amd64
That should pull in new kernels from backports if they show up. I don't think they get patched as fast as the main kernels, but I could be wrong about that.
#3 2026-02-17 18:29:43
kapqa
thanks, it pulled some latest 6.18.5-bpo, this has solved the issue it seems.
EDIt: it seem there are however other warning present, like "warning - failed to measure (something like 0000 etc)" it does however no longer show up later on the text messages during boot, only at initial screen.
