#1 2026-02-14 11:35:33
Kiergan
errors with apt update on Daedalus
Hello all,
what could be the reason I got these errors?
apt update
Err:1 http://deb.devuan.org/merged daedalus InRelease
  443  Too Many Requests [IP: 91.195.240.12 80]
Err:2 http://deb.devuan.org/merged daedalus-security InRelease
Err:4 http://deb.devuan.org/merged daedalus-updates InRelease
Get:3 https://apt.syncthing.net syncthing InRelease [24.2 kB]
Hit:5 https://download.webmin.com/download/newkey/repository stable InRelease
E: The repository 'http://deb.devuan.org/merged daedalus InRelease' is no longer signed.
E: Failed to fetch http://deb.devuan.org/merged/dists/daedalus/InRelease  443  Too Many Requests [IP: 91.195.240.12 80]
E: Failed to fetch http://deb.devuan.org/merged/dists/daed … /InRelease  443  Too Many Requests [IP: 91.195.240.12 80]
E: The repository 'http://deb.devuan.org/merged daedalus-security InRelease' is no longer signed.
E: The repository 'http://deb.devuan.org/merged daedalus-updates InRelease' is no longer signed.
This comes from a server in another country and the Internet there is not terrible, but not great either.
Any tips on how to proceed?
TIA
#2 2026-02-14 11:49:43
Dutch_Master
Re: errors with apt update on Daedalus
Do first:
apt-get --allow-releaseinfo-change update
If you haven't already, you need to update/install usrmerge before upgrading your system;
apt-get install usrmerge
Let it complete, can take some time. Then:
apt-get dist-upgrade
Again, let it finish before changing any packages (install/uninstall, etc)
#3 2026-02-14 12:02:52
It appears you are using a VPN or http proxy where that VPN or proxy service is unhapy with the number of requests (per second?).
If that is the case, then you may need to choose a different provider; (I suppose it's technically possible to set up outbound bandwidth limitation but that might require working package system to get set up)
#4 2026-02-14 13:02:49
Kiergan
@Dutch_master
I am not considering an DIST-upgrade, specially not while apt has troubles updating.
@ralph.ronnquist
Yes, the provider there is not the best, but there are no other options.
I think they give limited access out of the country. (Hungary)
maybe I can set the mirrors back to the Hungarian ones, but those have been slow and unreliable with their updates as well.
I am not sure how they organise things there, it seems their clients are all in some big local network and are been given real IPv4-addresses when asked for.
#5 2026-02-14 13:38:59
If the limitation is on "number of requests" you might want to try using socks5 tunneling over tcp, to a socks server... I can probably provide you with one such (on email) if you like.
