#1 2017-07-01 17:36:04
GNUser
caja missing video thumbnails [SOLVED]
I'm on Devuan Jessie with caja 1.8.2. Caja's "View" is set to "Icons".
Here are the relevant settings in caja:
This followed by a reboot has no effect:
sudo apt-get install totem ffmpegthumbnailer
Any ideas what to try next?
#2 2017-07-01 17:43:31
GNUser
Re: caja missing video thumbnails [SOLVED]
I renamed some video files and now the renamed ones have thumbnails. Bizarre.
Is there something I can do so that thumbnails show up for all videos, without me having to rename them all?
#3 2017-07-01 17:46:02
GNUser
Yes! This caused thumbnails to show up for everything:
rm -r ~/.cache/thumbnails
