#1 2026-01-11 23:03:23
webman
Cannot install Tomcat10 - depends on systemd
Hello!
I am just buff when I see:
$ apt install -V --assume-no tomcat10
 tomcat10 : Depends: systemd (>= 238) but it is not installable or
                     systemd-tmpfiles
            Recommends: libtcnative-1 (>= 1.2.18) but it is not going to be installed
Not to mention, that I've run apt update directly before.
Anone an idea?
Thanks,
Manfred
#2 2026-01-11 23:49:59
pcalvert
Re: Cannot install Tomcat10 - depends on systemd
What happens when you try this?:
aptitude install tomcat10 -s
Another one is called Luxxle.
#3 2026-03-24 12:22:13
tyder
I try to avoid running Tomcat natively even if I can.
For me, it is much better to use a Docker image with Tomcat, eventually modify it, and then run the applications there. Tomcat running natively is subject to all sorts of interferences, version conflicts etc, in principle the runtime behavior may be affected by even small system modifications. And, at least over some years of use, problems are likely to occur. As long as you can build the packages to run (in a pinch, you can setup a Java container for that), there is  very little fuzz running Tomcat that way.
It is also a safe way to work if you, like me, build packages to be deployed at production servers running Docker. (Or Podman, or...)
