#1 2017-06-28 19:37:05
spartrekus
Easy compilation portable RPN calculator?
Hello,
I was looking for Orpie, when I found that it won't be anywhere.
Curious, is that there aren't much calculator that work on the terminal, with bc or dc to be the most used. But other alt?
would you know some very portable calculator into devuan, or some that can be compiled easily?
thank you
#2 2017-06-29 01:24:02
PeteGozz
Re: Easy compilation portable RPN calculator?
There is genius
It has a command line only mode.
I think it can also work in RPN
Its way more than I need.
#### wandering off topic #####
units is hours of fun smile
Also I dont think I'm alone in firing up python
for some simple stuff. (which is all I need)
hmmm or most  interpreters actually.
Though watch out for divide by zero on some.
or even plain old bash:
ANS=$(( 2 * 2 ))
echo $ANS
oh and emacs of course it has a -few-  calcs smile
(someone had to say it)
#3 2017-06-30 05:26:43
spartrekus
I think that on the raspberry I miss orpie. I looked for a good portable terminal or x11 solution, easily compilable, and that might work in next years
