#1 2025-12-22 06:56:13
Dutch_Master
Removing obsolete keyrings
Over time, upgrades to Devuan have increasingly becoming more annoying as errors come up, either in aptitude or synaptic. The 2 main culprits are old Devuan keyring archives: devuan-keyring-2022-archive.asc and devuan-keyring-2016-archive.asc Neither show up in package management tools. Both error out with "unsupported file type" or similarly named. So, how to get rid of these? Is there a tool to do so ('cuz I didn't find any sad )
#2 2025-12-22 08:10:14
RedGreen925
Re: Removing obsolete keyrings
sudo rm /etc/apt/keyrings/keyring-2022-archive.asc
sudo rm /etc/apt/keyrings/keyring-2016-archive.asc
Used in a Terminal if in old location if in the new then /usr/share/keyrings/ could be the location to remove them from.
#3 2025-12-22 09:25:29
Dutch_Master
Thx for that reply. Won't these keys need to be de-registered? (they're found in /etc/apt btw)
#4 2025-12-22 11:21:15
You simply remove them. There is no de-registering required.
#5 2025-12-22 11:36:51
I run an up to date Devuan Daedalus:
$ uname -a
Linux devuan 6.1.0-41-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.158-1 (2025-11-09) x86_64 GNU/Linux
I have all these keys as well as those prevously posted:
$ ls -1 /etc/apt/trusted.gpg.d
debian-archive-bookworm-automatic.asc
debian-archive-bookworm-security-automatic.asc
debian-archive-bookworm-stable.asc
debian-archive-bullseye-automatic.asc
debian-archive-bullseye-security-automatic.asc
debian-archive-bullseye-stable.asc
debian-archive-trixie-automatic.asc
debian-archive-trixie-security-automatic.asc
debian-archive-trixie-stable.asc
devuan-keyring-2016-archive.gpg
devuan-keyring-2022-archive.gpg
devuan-keyring-amprolla-2022-archive.gpg
devuan-keyring-daedalus-archive.gpg
devuan-keyring-excalibur-archive.gpg
Only times I have had an issue with apt it was due to some round-robin malfunction.
Just a question of waiting 15' and trying again.
Now ...
rm on devuan-keyring-2016-archive.gpg and devuan-keyring-2022-archive.gpg screws up apt update.
So it would seem that they are current and needed.
Should they be replaced?
ie: because of the 2022 and 2016 dating?
No idea how all this works.
I'd appreciate a heads up.
#6 2025-12-22 11:56:56
Dutch_Master
I have now removed both keyring archives mentioned in my OP, but left all others in that directory. So far, apt/aptitude/synaptic is not complaining (yes, also updated Devuan Stable on my system)
#7 2025-12-22 12:59:39
Dutch_Master wrote:
... also updated Devuan Stable on my system.
Ahh ...
Therein lies the difference.
ie:
Devuan [stable] is now Excalibur, released 2025-11-02.
As a consequence, Daedalus is now [oldstable].
Thanks for your input.
#8 2025-12-22 17:01:36
RedGreen925
The keys you want to remove can be backed up to some other location then if needed again they can be copied back into the keyring directory.
