#1 Yesterday 22:37:00
jandrg
excalibur image for original rpi?
I have an old Raspberry Pi model B that I'd like to run excalibur on, but I notice that the arm builds at arm-files.devuan.org/RaspberryPi Latest Builds don't include excalibur builds for the original rpi.  Is there a reason for that?  I thought Debian and the kernel did still explicitly support the original Pi.
I could start with daedalus and upgrade of course (unless there's a reason it wouldn't work) but I figure it would be cleaner to just start with excalibur.
Thanks, thanks to everyone who works to make Devuan!  I also have it on ia32 (daedalus), ia64 amd64 (excalibur), and arm64 (old Samsung Chromebook Plus V1, soon to upgrade to excalibur) machines.
#2 Today 02:24:08
RedGreen925
Re: excalibur image for original rpi?
Those are not real builds anyways they are made with a script that creates images that are broken by default and do not allow the kernel to be upgraded like on a proper system. If you want to be able fully upgrade the system so that actually follows a normal Debian/Devuan process install then you need to install the Trixie using Debian images then convert it to Devuan like I did when I figured out the broken nature of them files.
#3 Today 11:59:48
bai4Iej2need
so what to do to get a real build ?
I need on for my rpi4, 4GB .
broken by design :
