#1 2025-12-07 10:36:43
Roberto
[SOLVED] Cifs share is not mountet automatically
I installed Devuan 6 Excalibur with Cinnamon as the desktop and SysV as the init system.
Then, as I have done countless times before, I created two mount points in my home folder, created a credentials file, and then entered the share in fstab.
Example:
//IP address/folder /home/user/data cifs defaults,rw,credentials=/home/user/.smbcredentials,noserverino,vers=3.0,uid=1000,gid=1000 0 0
After the command:
sudo mount -a
this share is mounted in Nemo.
The problem is that this share is not automatically mounted in Nemo after a restart.
When I click on the “Data” folder, I get the error message:
mount.cifs: permission denied
In Devuan 5 Daedalus and also in various other distributions, I did exactly the same thing and it worked without any problems.
Does anyone have any ideas or tips on what I could do to get my Cifs share mounted automatically?
Thanks
Roberto
#2 2025-12-07 11:20:27
Andre4freedom
Re: [SOLVED] Cifs share is not mountet automatically
Roberto,
yes, there is a solution to that problem:
Its the NetworkManager version used in Excalibur.
Look at this thread:
https://dev1galaxy.org/viewtopic.php?pid=59374#p59374
The workaround is (from steve_v):
@Andre4freedom: You might try grabbing that missing file (/etc/NetworkManager/dispatcher.d/01-ifupdown) from the Daedalus network-manager package. Like I said I don't have a system to test it on, but the manual suggests networkmanager should still call it if it exists.
I hope that may be a temporary solution for you too.
I guess there will be a newer or patched network-manager package in some time, possibly a new point-release or a patch.
Good luck.
#3 2025-12-07 12:37:53
Roberto
Hi Andre4freedom,
thank you very much for your help.
Your tip works very well, and I can definitely live with this workaround.
regards
Roberto
