#1 2025-12-05 10:13:54
igorzwx
[HowTo] Markdown (ronn) to man
ronn is a Markdown-like format for writing man pages. It's readable and editable in any text editor.
To enable syntax highlighting for .ronn files in VSCodium:
  1. Open the .ronn file.
  2. Click on "Plain Text" in the bottom-right corner of the status bar.
  3. Select "Markdown" from the language list.
This applies Markdown highlighting, which works well for .ronn files.
Alternatively, use the command palette:
Ctrl+Shift+P → "Change Language Mode" → "Markdown".
To convert .ronn files to man format, use the ronn utility available in Devuan repositories:
$ apt-cache search ronn$
ronn - tool to build manuals from Markdown
ruby-ronn - library to build manuals from Markdown
Install ronn:
sudo apt install ronn
Convert .ronn file to man format:
ronn --roff pcm_conv.1.ronn
This generates pcm_conv.1.
View the man page:
man ./pcm_conv.1
Example .ronn file:
cat pcm_conv.1.ronn
PCM_CONV(1)                                         User Commands                                         PCM_CONV(1)
## NAME
pcm_conv - high-quality FFT/DCT-based audio resampler
## SYNOPSIS
`pcm_conv` [<input_file>] [<output_file>] [ `-c` <number> ] [ `-m` <mask> ] [ `-n` <on>`|`<off> ] [ `-I` <input_order> ] [ `-O` <output_order> ] [ `-b` <bits> ] [ `-f` <frequency> ] [ `-T` <trans> ] [ `-W` <win> ] [ `-v` ] [ `-h | --help | --help-all` ]
## DESCRIPTION
Converts WAVE files with high-quality sample rate conversion using FFT or DCT transforms.
## OPTIONS
`-c`
:    Number of output channels: 1 (mono), 2 (stereo), up to 6 (3/2+SW).
`-m`
:    Channel mask (may conflict with -c).
`-n`
:    Normalize channel matrix (default: on).
`-I` <order>, `-O` <order>
:    Input/output channel order: MS, ALSA, or OSS layout.
`-b` <bits>
:    Output bit depth: 8, 16, 24, 32, 32f, or 64f.
`-f` <value of sample rate in Hz>, e.g.: `-f` 192000
:    Output sample rate. The range of 6000–192000 Hz is 100% reliable. Rates above 192 kHz (e.g., 1411200 Hz) appear reliable based on testing, but require further validation with `pcm_mse`.
`-T` <dct>`|`<fft>
:    Transform type (default: dct).
`-W` <vorbis>`|`<hanning>`|`<rect>
:    Windowing function (default: vorbis).
`-v`
:    Verbose output.
`--help-all`
:    Show full help.
## FILES
/etc/fftrate.conf
:    System-wide configuration.
~/.asoundrc
:    User ALSA configuration (used by fftrate plugin).
## SEE ALSO
arateconf(1), fftrate(7)
## EXAMPLES
Convert a 32-bit WAV file to 192kHz, 32-bit fixed-point using FFT resampling:
    $ pcm_conv -f 192000 -b 32 -T fft -v *32bit.wav Faust_192kHz_32bit_downfft.wav
    Input file : 08-Faust - Funeral March Of A Marionette - 32bit.wav
     Samples rate    = 352800 Hz
     Channels        = 2
     Bits per sample = 32 (actual: 32, float)
    Output file: Faust_192kHz_32bit_downfft.wav
     Samples rate    = 192000 Hz
     Channels        = 2
     Bits per sample = 32 (actual: 32, fixed)
            FL      FR
    FL      1.000   -----
    FR      -----   1.000
    Windows : "Vorbis" (37632 => 20480)
    Delay   : 107 ms
    Sync.   : ON
    Trans.  : "FFT"
    [|||||||||||||||||||||||||||||||||||||||||||||||||||]  99.0 %
    Ok.
    File duration  : 275.906667 sec
    Processing time: 13.305000 sec ( 4.82% of real time)
## VERSION
1.6.3
## DATE
November 2025
Manual:
man ronn-format
_https://rtomayko.github.io/ronn/ronn-format.7.html
#2 2025-12-08 01:09:49
Re: [HowTo] Markdown (ronn) to man
I prefer asciidoctor
#3 2025-12-08 13:36:13
EDX-0
but where is the fun of writing manpages by hand and having formatting not work cuz you typed one extra char after the macro?
#4 2025-12-08 17:55:43
wait...you guys are adding man pages to stuff?
#5 2025-12-08 18:03:22
EDX-0
i have hand written manpages by hand for scripts that aren't even 500 lines of code long and that is because i have not generalized redundant code into functions enough like for this systemact script https://github.com/eylles/systemact which as far as i know i'm the only user and i don't even use like half of the features i've added...
