#1 2025-11-30 11:44:36
kapqa
what is the most viable path f nvidia-legacy-340xx-alternative
HELL O,
i am thinking of updating the laptop running Devuan 3.0 to newer version;
is this upgrade path still valid; would need "nvidia-legacy-340xx-alternative" for graphics card acceleration.
what is the most viable path for update?
thank you very much.
edit:
(may be this is needed, too?)
https://gist.github.com/Anakiev2/b828ed … e9e5cf2c63
#2 2025-11-30 11:49:35
Re: what is the most viable path f nvidia-legacy-340xx-alternative
New threads are new trheads.
#3 2025-11-30 11:52:37
kapqa
thanks , it is not necessary to update, but since sometime i use "yt-dlp" it would be nice since on devuan 3.0 python is 3.7 only;
EDIT:
have seen that i have python3.8 already installed,
how could i use it / evoke before "yt-dlp" so could continue using Devuan 3.0 for some time?
put otherwise: how could i "bind" python3.8.2 to "yt-dlp" so that everytime it gets evoked , it would use "python3.8.2" instead of systemwide-python 3.7?
thanks.
EDI2:
on second thought, the original questoin still stands, since it might be necessary to update in the future if would like continue using this laptop on the internet;
thanks.
(how use nvidia-legacy-340xx-alternative or build nvidia-340 for newer devuan (devuan 4,5,6).
this nvidia-legacy-340xx-alternative is probably available only in sid/ceres?
