#1 2025-11-21 19:31:54
Ron
Deleting pulseaudio/pipwire-pulse loop
So while running a live session of Excalibur I attemted to remove pulseaudio. But it would not let me do it without installing pipewire-pulse. So I allowed it, and then tried to remove pipewire-pulse, but it wouldn't let me do it without installing pulseaudio. So there must be a way to do it (i.e., have neither installed) because my current bare-metal install of Crowz/Devuan 5 has neither installed. How is it done?
#2 2025-11-21 20:06:11
igorzwx
Re: Deleting pulseaudio/pipwire-pulse loop
The obvious solution is to remove them both in one command.
Another obvious solution is to put them on hold.
Old manual for Devuan 5:
$ dpkg-query -W -f='${Package;-40}${Description;50}\n' | grep pulseaudio
pulseaudio                              PulseAudio sound server
pulseaudio-module-bluetooth             Bluetooth module for PulseAudio sound server
pulseaudio-utils                        Command line tools for the PulseAudio sound server
$ dpkg-query -W -f='${Package;-40}${Description;50}\n' | grep libpulse
libpulse-mainloop-glib0                 PulseAudio client libraries (glib support)
libpulse0                               PulseAudio client libraries
libpulsedsp                             PulseAudio OSS pre-load library
To prevent "autoremove":
$ sudo apt-mark manual libpulse0 libpulse-mainloop-glib0 libpulsedsp
Set on hold other crap:
$ sudo apt-mark hold pulseaudio* pipewire*
Purge pulseaudio/pipewire
$ sudo apt-get purge pulseaudio pulseaudio-utils pavucontrol pulseaudio-module-bluetooth pipewire pipewire-bin pipewire-pulse rtkit
Kill PulseAudio:
$ killall pulseaudio
$ fuser -av $(find /dev/snd -type c 2>/dev/null)
                     USER        PID ACCESS COMMAND
/dev/snd/controlC1:
/dev/snd/pcmC1D0c:
/dev/snd/pcmC1D0p:
/dev/snd/controlC0:
and reboot.
There are still some pulse/pipe libs
$ dpkg-query -W -f='${Package;-40}${Description;50}\n' | grep pipe
libpipeline1                            Unix process pipeline manipulation library
libpipewire-0.3-0                       libraries for the PipeWire multimedia server
libpipewire-0.3-common                  libraries for the PipeWire multimedia server - com
#3 2025-11-21 20:11:11
kapqa
had encountered the same situation on latest raspiOs; whenever  de-installing , pipewire, would install pulseaduio; and viceversa;
pluse, it would uninstall the pretty desktop-os; which is a bit of nuisance;
there is a way around it, and found like "one-liner", to uninstall both; but on raspi-os it still would uninstall somehow desktop; on devuan, no such issue; and maybe also, on raspiOs, it might have changed;
but seem to have not written down the exact command; and seem not to find it atm;
it should however involve the "+" or "-" sign;
like
"sudo apt autoremove pulseaudio* -pipewire"
but this could be wrong advice; sorry for not being more precise here;
what i did always in recent times is follow his advice onhow remove pulseaudio:
https://dev1galaxy.org/viewtopic.php?pid=49837#p49837
it functions also on excalibur, but you may need to work your way through uninstalling some additional depdencies manually; (you will know what i mean).
#4 2025-11-21 20:19:13
igorzwx
@kapqa Could you please test Zoom app (audio test, out + mic). It should work on both Devuan and Mint with ALSA out of the box.
No apulse is need.
2. Could you also test Zoom with Firefox, which you compiled yourself without pulse. It should also work with ALSA out of the fox.
apulse is, in any case, useless with your Firefox, because it does not have pulse-rust backend.
It seems that Debian developers disabled mic in FirefoxESR (ALSA ) by some special sort of sandboxing to enforce pulseaudio.
#5 2025-11-21 20:22:08
kapqa
@igorzwx, got your notice; no need to cross-examine for now smile will test some later, thanks for letting us know!
EDIT: its good that you bring back to it;
since was missing already without noting it the functiionality of hot-plugging the headphones on the computer;
fortunately, my pc-speaker have a headphone output; so i can cheat at little bit; but i don't think it is feasible to hot-plug with arateconf standard settings out-of-the-box? eg; when inserting headphones on front-panel, it would switch to headphones?
thanks.
#6 2025-11-21 20:26:46
igorzwx
about:support
Name 	Firefox Nightly
Version 	146.0a1
Build ID 	20251108203729
Audio Backend	alsa
Max Channels	10000
Preferred Sample Rate	48000
Roundtrip latency (standard deviation)	NaNms (NaN)
$ MOZ_LOG="cubeb:5" firefox-nightly 2>&1 about:support
[Parent 14786: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Parent 14786: Main Thread]: V/cubeb media.cubeb.sandbox: true
ATTENTION: default value of option mesa_glthread overridden by environment.
[Child 14912: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 14912: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 14912: Main Thread]: W/cubeb could not set real-time limit in CubebUtils::InitLibrary
[Parent 14786: Main Thread]: D/cubeb Starting cubeb server...
[Parent 14786: Main Thread]: D/cubeb media.audioipc.shm_area_size: 0
JavaScript warning: resource://gre/modules/Troubleshoot.sys.mjs, line 723: WebGL context was lost.
[Parent 14786: Main Thread]: I/cubeb media.cubeb.sandbox: true
[Parent 14786: Main Thread]: D/cubeb media.audioipc.stack_size: 262144
[Parent 14786: AudioIPC Server RPC]: E/cubeb cubeb.c:727:DeviceID: "default" (PREFERRED)
	Group:	"default"
	Vendor:	"default"
	Type:	output
	State:	enabled
	Maximum channels:	10000
	Format:	S16LE (0x10) (default: S16LE)
	Rate:	[48000, 48000] (default: 48000)
	Latency: lo 0 frames, hi 0 frames
[Parent 14786: Main Thread]: E/cubeb cubeb.c:727:DeviceID: "default" (PREFERRED)
	Group:	"default"
	Vendor:	"default"
	Type:	output
	State:	enabled
	Group:	"default"
	Vendor:	"default"
	Type:	input
	State:	enabled
	Group:	"default"
	Vendor:	"default"
	Type:	input
	State:	enabled
[Child 14981: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 14981: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 14981: Main Thread]: W/cubeb could not set real-time limit in CubebUtils::InitLibrary
[Child 15006: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 15006: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 15006: Main Thread]: W/cubeb could not set real-time limit in CubebUtils::InitLibrary
[Parent 14786: BackgroundThreadPool #1]: D/cubeb Default devices latency in seconds -nan (stddev: -nan)
Firefox 58 (Nightly) tightened its sandbox a bit more. Now ioctl() calls are forbidden too, but are used by ALSA libraries. That causes sandbox violation with subsequent process termination. Exception can be added by setting parameter security.sandbox.content.syscall_whitelist in about:config. That field accepts a comma separated list of system call numbers. Add there 16 for x86-64, or 54 for x86 or ARM.
Firefox 60 tighened its content sandbox more, but at the same time moved audio accesses from content processes to the main process. From Firefox 60 onwards no changes to the sandbox settings are necessary.
_https://github.com/i-rinat/apulse
What Logs Show
Firefox Nightly logs confirm the Firefox 60+ architecture change is working correctly:
The key evidence:
1. Audio runs in the parent process: Notice [Parent 14786: Main Thread] and [Parent 14786: AudioIPC Server RPC] - audio device enumeration happens in the parent process, not child processes
2. AudioIPC architecture: The log shows Starting cubeb server... and AudioIPC Server RPC, which is Firefox's audio IPC (Inter-Process Communication) system that isolates audio in a separate server process
3. Sandbox is enabled but doesn't block audio: media.cubeb.sandbox: true in both parent and child processes, yet audio devices are successfully enumerated (both input and output show as State: enabled)
4. No sandbox override needed: Unlike your ESR logs where Firefox forced the sandbox setting, Nightly respects the sandbox while still allowing audio access through the AudioIPC architecture
Why This Works in Nightly but Not ESR
The difference between Firefox 140.5.0 ESR and Nightly:
- ESR (logs): Shows [Child 12906: Main Thread]: E/cubeb media.cubeb.sandbox: false, but content sandbox enabled - forcing true, indicating audio was being accessed from child processes where the sandbox blocked it
- Nightly (current logs): Audio access happens in [Parent 14786: AudioIPC Server RPC], completely bypassing the content process sandbox issue
This confirms that Firefox ESR 140.5.0 may have regressed or not fully implemented the Firefox 60+ audio architecture, while Nightly has it working correctly.
What This Means for Cubeb
From Cubeb's perspective, nothing changed - the ALSA backend code is identical in both cases :
- It still opens devices with snd_pcm_open() [link to Repo mozilla/cubeb: src/cubeb_alsa.c:1050-1051]
- It still enumerates devices the same way [link to Repo mozilla/cubeb: src/cubeb_alsa.c:1430-1451]
- The latency reporting still returns 0 due to ALSA's dmix/dsnoop limitations [link to Repo mozilla/cubeb: src/cubeb_alsa.c:1450-1451]
The difference is where Firefox calls this code - in the parent process (Nightly) vs. sandboxed child processes (your ESR).
Notes
Nightly logs prove that the microphone issue in ESR is indeed a Firefox sandbox architecture problem, not a Cubeb bug. The Cubeb ALSA backend works perfectly when Firefox's AudioIPC architecture is properly implemented.
#7 2025-11-21 20:51:18
kapqa
just tested with linux - mint 22.2 - firefox nightly;
have switched correctly from DAC to internal audio via arateconf - disabled "auto mute" - hence enabled headphone and mic on front panel via alsamixer; tested functionality;
however, Zoom Audio test would fail for Nightly Firefox;
https://ibb.co/5W2KDs76
https://ibb.co/gF7jxbxs
#8 2025-11-21 20:54:55
igorzwx
hot-plug? Do you mean jack sensing?
Jack sensing is a feature in audio devices that automatically detects when a plug, such as headphones or an auxiliary cable, is inserted or removed from the audio jack. This detection triggers an event, like muting the internal speakers or prompting the user to select an audio output. It is primarily implemented using either mechanical switches or impedance-based measurements.
Run
alsamixer
and set everything right.
#9 2025-11-21 21:20:02
kapqa
@igorzwx, yes, might be that;
the setting needed is "auto -mute" has to be set to "disabled" inside alsamixer >> is by default set to "enabled";
tried zoom-audio-test also on devuan 6;
it does not function; but it is certainly a limitation of the rather hushy "firefox-nightly" build;
it gave problems also with other websites; prevented from accessing or prevented from entering listing on ebay;
still, its my favorite browser; many thanks for that!
https://ibb.co/RpNBFzDT
https://support.zoom.com/hc/en/article? … =KB0060732
EDIT:
tested also with app "librewolf" on "devuan 6"
-- audio function; but no mic; probably i just have a faulty headset; will test next week again with new headset;
https://ibb.co/LhP0c7rY
EDIT2:
it seem zoom audio test can only access "internal microphone" =? on webpage; have set "usb audio device" as playback device; but maybe "librewolf"is not able to recognize ? or "internal microphone" is >> "usb recording" ---- in any case, it does not funciton for me here.
https://ibb.co/qMCbj1c6
#10 2025-11-22 01:28:39
igorzwx
librewolf? Try
MOZ_LOG="cubeb:5" librewolf 2>&1 about:support
It seems that Zoom does not like Firefox Nightly
Zoom may not be supported on your browser
Copy the link below and paste it in Safari, Chrome, Firefox, Edge, or Opera
Installed Zoom Workplace for Linux. It works with ALSA out of the box.
Zoom app > Settings > Audio > Test microphone
apulse is not needed
_https://zoom.us/download
Zoom Workplace app also works with ALSA on Linux Mint.
#11 2025-11-22 10:14:14
kapqa
will have to do more test on laptop since upgraded to devuan 7 and it may have broken some alsa-related setups.
for librewolf, it still would not function, but will re-set the alsa - config and test again.
MOZ_LOG="cubeb:5" librewolf 2>&1 about:supportrt
[Parent 6678: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Parent 6678: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 6791: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 6791: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Parent 6678: Main Thread]: D/cubeb Starting cubeb server...
[Parent 6678: Main Thread]: D/cubeb media.audioipc.shm_area_size: 0
[Child 6850: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 6850: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 6852: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 6852: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Parent 6678: Main Thread]: I/cubeb media.cubeb.sandbox: true
[Parent 6678: Main Thread]: D/cubeb media.audioipc.stack_size: 262144
[Parent 6678: AudioIPC Server RPC]: E/cubeb context.rs:642: Error: error while waiting for pulse's context to be ready
[Parent 6678: AudioIPC Server RPC]: E/cubeb context.rs:172: Error: couldn't init pulse's context
Input:  44100 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 1764
Output: 48000 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 1920
Rates:  44100 --> 48000 (J: 0.00%, T: FFT, W: Vorbis)
Ok.
Ok.
[Parent 6678: AudioIPC Server RPC]: E/cubeb cubeb.c:727:DeviceID: "default" (PREFERRED)
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
        Rate:   [44100, 44100] (default: 44100)
[Parent 6678: Main Thread]: E/cubeb cubeb.c:727:DeviceID: "default" (PREFERRED)
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Input:  48000 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 1920
Output: 44100 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 1764
Rates:  48000 --> 44100 (J: 0.00%, T: FFT, W: Vorbis)
Ok.
Ok.
[Parent 6678: BackgroundThreadPool #1]: E/cubeb Could not get input latency
[Child 6913: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 6913: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 6938: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 6938: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Parent 6678: BackgroundThreadPool #1]: D/cubeb Default devices latency in seconds -nan (stddev: -nan)
[Child 7032: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 7032: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 7072: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 7072: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 7117: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 7117: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 7153: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 7153: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 7194: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 7194: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 7072: Main Thread]: I/cubeb media.cubeb.sandbox: true
[Child 7072: Main Thread]: D/cubeb media.audioipc.stack_size: 262144
Ok.
[Child 7244: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 7244: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 7277: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 7277: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Child 7117: Main Thread]: I/cubeb media.cubeb.sandbox: true
[Child 7117: Main Thread]: D/cubeb media.audioipc.stack_size: 262144
Ok.
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
[Child 7117: MediaSupervisor #1]: E/cubeb cubeb.c:727:DeviceID: "default" (PREFERRED)
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
Ok.
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
[Child 7117: MediaSupervisor #4]: E/cubeb cubeb.c:727:DeviceID: "default" (PREFERRED)
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
[Child 7117: MediaSupervisor #2]: E/cubeb cubeb.c:727:DeviceID: "default" (PREFERRED)
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
[Child 7117: CubebOperation #1]: I/cubeb CubebStreamInit output stream rate 44100
Ok.
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
[Child 7117: Main Thread]: E/cubeb cubeb.c:727:DeviceID: "default" (PREFERRED)
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
[Child 7117: MediaSupervisor #3]: E/cubeb cubeb.c:727:DeviceID: "default" (PREFERRED)
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
[Child 7117: CubebOperation #2]: I/cubeb CubebStreamInit output stream rate 44100
Ok.
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
[Child 7117: CubebOperation #3]: I/cubeb CubebStreamInit output stream rate 44100
Ok.
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
Ok.
[Child 7117: CubebOperation #4]: I/cubeb CubebStreamInit output stream rate 44100
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
Ok.
Ok.
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
        Group:  "default"
        Vendor: "default"
        Type:   input
        State:  enabled
Ok.
[Child 7117: MediaDecoderStateMachine #1]: I/cubeb CubebStreamInit output stream rate 48000
Rates:  48000 --> 48000 (J: 0.00%, T: None, W: Planar)
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
Ok.
[Child 7558: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 7558: Main Thread]: V/cubeb media.cubeb.sandbox: true
for "zoom" app >> the microphone functions, but only after setting options for microphone from default ! to "original sound for musicians"
#12 2025-11-26 09:13:14
kapqa
am playing back a music track via web-player "spotify".
getting this output
[Child 17531: MediaDecoderStateMachine #1]: I/cubeb media.cubeb.sandbox: true
[Child 17531: MediaDecoderStateMachine #1]: D/cubeb media.audioipc.stack_size: 262144
[Child 17531: MediaDecoderStateMachine #1]: I/cubeb CubebStreamInit output stream rate 44100
Output: 192000 Hz, 2 ch, 's32_le' (0xa): dummy = 0, period = 7680
Rates:  44100 --> 192000 (J: 0,00%, T: FFT, W: Vorbis)
Ok.
however, how can track which bitrate webplayer is "feeding" into stream, or is this already inclueded in the above output?
#13 2025-11-26 10:16:51
igorzwx
Yes. You can find examples here:
_https://dev1galaxy.org/viewtopic.php?pid=59689#p59689
A sort of rather simple command like this:
$ MOZ_LOG="MediaDecoder:4,cubeb:3" firefox 2>&1 https://youtu.be/uO6jfQ5tQHM | awk '!/ATT/ && !/libva/ && !/s=1/ && !/s=0/ && (!/MediaDecoder/ || /rate/)'
[Child 17205: Main Thread]: D/MediaDecoder MediaDecoder[7ff8efdfc600] MetadataLoaded, channels=2 rate=48000 hasAudio=1 hasVideo=1
[Child 17205: MediaSupervisor #2]: I/cubeb media.cubeb.sandbox: true
[Child 17205: Main Thread]: D/MediaDecoder MediaDecoder[7ff8efdfc600] FirstFrameLoaded, channels=2 rate=48000 hasAudio=1 hasVideo=1 mPlayState=PLAY_STATE_LOADING transportSeekable=1
[Child 17205: MediaDecoderStateMachine #1]: I/cubeb CubebStreamInit output stream rate 48000
Ok.
#14 2025-11-30 19:47:43
Ron
Thanks for the answer and instructions.
