#1 2025-11-18 14:56:47
Danielsan
[SOLVED] set up an "AD HOC" connection with HOSTAPD (OPENRC)
Hi folks,
I am trying to create an "ad hoc" wifi connection through wpa_supplicant; I tried to mix together several sources, but with systemd becoming every day more predominant, it is very difficult finding information for systemdless systems.
This is my adapter:
01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
And the firmware is installed.
Here is my interfaces file:
# wlan0
auto wlan0
iface wlan0 inet static
    address 10.1.10.1
    gateway 10.1.10.254
    netmask 24
    #wpa-driver nl80211
    wpa-conf /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
Here my wpa_supplicant-wlan0.conf with permissions set to 600.
ctrl_interface=DIR=/run/wpa_supplicant GROUP=netdev
fast_reauth=1
update_config=1
ap_scan=2
# AD-HOC NETWORK
network={
        ssid="ESSID"
        #psk="..."
        psk=YADA-YADA-YDAD
        frequency=2432
        mode=1
        proto=RSN
        key_mgmt=WPA-PSK
        pairwise=CCMP
        group=CCMP
The wifi is clearly down:
ip link show wlan0
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default qlen 1000
    link/ether b0:ac:82:ff:a8:86 brd ff:ff:ff:ff:ff:ff
When I try to raise up the wlan0 adapter, it fails:
sudo ifup wlan0
wpa_supplicant: /usr/sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
ifup: failed to bring up wlan0
And when I try to start the service alone it fails the same; wireless-tools are installed:
sudo service wpa_supplicant start
grep: /etc/init.d/wpa_supplicant: No such file or directory
wpa_supplicant: unrecognized service
Now are two days that I am trying to troubleshoot this issue but I couldn't find any solution.
Thanks… 🙏
#2 2025-11-18 16:31:20
Danielsan
Re: [SOLVED] set up an "AD HOC" connection with HOSTAPD (OPENRC)
I found this documentation but when I tested it out, all the connections got frozen...
https://raspi.emawind.com/devnote/raspi … twork.html
#3 2025-11-18 16:52:44
this webpage shows it was last updated in 2012 which may precede some/most/all of the systemd stuff
https://wiki.debian.org/WiFi/AdHoc
#4 2025-11-18 18:44:35
Danielsan
That page doesn't include a method to use a WPA protection, therefore any transmission on the air is plain.
#5 2025-11-18 19:57:50
Danielsan
I found the documentation and what I did looks right:
# mode: IEEE 802.11 operation mode
# 0 = infrastructure (Managed) mode, i.e., associate with an AP (default)
# 1 = IBSS (ad-hoc, peer-to-peer)
# 2 = AP (access point)
# Note: IBSS can only be used with key_mgmt NONE (plaintext and static WEP) and
# WPA-PSK (with proto=RSN). In addition, key_mgmt=WPA-NONE (fixed group key
# TKIP/CCMP) is available for backwards compatibility, but its use is
# deprecated. WPA-None requires following network block options:
# proto=WPA, key_mgmt=WPA-NONE, pairwise=NONE, group=TKIP (or CCMP, but not
# both), and psk must also be set.
# frequency: Channel frequency in megahertz (MHz) for IBSS, e.g.,
# 2412 = IEEE 802.11b/g channel 1. This value is used to configure the initial
# channel for IBSS (adhoc) networks. It is ignored in the infrastructure mode.
# In addition, this value is only used by the station that creates the IBSS. If
# an IBSS network with the configured SSID is already present, the frequency of
# the network will be used instead of this configured value.
# IBSS/ad-hoc network with RSN
network={
	ssid="ibss-rsn"
	key_mgmt=WPA-PSK
	proto=RSN
	psk="12345678"
	mode=1
	frequency=2412
	pairwise=CCMP
	group=CCMP
#6 2025-11-18 20:19:46
Danielsan
Found another hint:
sudo wpa_supplicant -c /etc/wpa_supplicant/wpa_supplicant-wlan0.conf -i wlan0
Successfully initialized wpa_supplicant
Note: nl80211 driver interface is not designed to be used with ap_scan=2; this can result in connection failures
I tried to change driver, clearly this wifi chipset doesn't support "ad hoc":
sudo wpa_supplicant -c /etc/wpa_supplicant/wpa_supplicant-wlan0.conf -i wlan0 -D wext
ioctl[SIOCSIWENCODEEXT]: Invalid argument
wlan0: Trying to associate with SSID 'TEST-ESSID'
ioctl[SIOCSIWGENIE]: Operation not supported
wlan0: Association request to the driver failed
wlan0: Associated with 9a:dc:7c:a0:6d:5a
wlan0: CTRL-EVENT-CONNECTED - Connection to 9a:dc:7c:a0:6d:5a completed [id=0 id_str=]
#7 2025-11-18 20:21:51
g4sra
key_mgmt=WPA-PSK
Make sure you terminate any\all daemons after config change and before 'ifup wlan0', wpa_supplicant daemon in particular can get 'stuck' and require killing.
#8 2025-11-18 20:29:20
Danielsan
Hi g4sra, I will follow you advise however I bought a dongle that should support hot-spot and "ad hoc " mode, then I'll try doing other tests.
#9 2025-11-18 20:41:45
g4sra
Nope. I am wrong, key management is possible in ad hoc.
For AP mode go with the 'hostapd' package ('apt show hostapd')
#10 2025-11-19 15:15:40
Danielsan
HOSTAPD made the magic, however I am still unable to bring up wlan0:
sudo ifup wlan0
Error: ipv4: Address already assigned.
#11 2025-11-19 15:48:48
dzz
Worth rechecking the device really is assigned to wlan0 and not something else.. One of numerous methods:
inxi -nn
#12 2025-11-19 16:17:42
Danielsan
@dzz if I "force" to ignore the issues I can bring up wlan0.
sudo ifup -v --ignore-errors  wlan0
ifup: configuring interface wlan0=wlan0 (inet)
run-parts --verbose /etc/network/if-pre-up.d
run-parts: executing /etc/network/if-pre-up.d/hostapd
run-parts: executing /etc/network/if-pre-up.d/wireless-tools
run-parts: executing /etc/network/if-pre-up.d/wpasupplicant
ip addr add 10.1.10.1/255.255.255.0 broadcast 10.1.10.255 	  dev wlan0 label wlan0
ip link set dev wlan0   up
 ip route add default via 10.1.10.254  dev wlan0 onlink
RTNETLINK answers: File exists
run-parts --verbose /etc/network/if-up.d
run-parts: executing /etc/network/if-up.d/mountnfs
run-parts: executing /etc/network/if-up.d/resolved
run-parts: executing /etc/network/if-up.d/wpasupplicant
inxi -bb
Network:
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    driver: rtw_8821ce
  IF: wlan0 state: up mac: b0:ac:82:ff:a8:86
  Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    driver: r8169
  IF: eth0 state: up speed: 1000 Mbps duplex: full mac: e0:51:d8:17:8d:cd
  IF-ID-1: usb0 state: unknown speed: -1 duplex: half mac: 96:e7:cd:80:f0:f7
#13 2025-11-19 16:25:41
Danielsan
Now I have two static IPv4:
sudo ifconfig
[sudo] password for freezr:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.0.10.1  netmask 255.0.0.0  broadcast 10.255.255.255
        inet6 fe80::e251:d8ff:fe17:8dcd  prefixlen 64  scopeid 0x20<link>
        ether e0:51:d8:17:8d:cd  txqueuelen 1000  (Ethernet)
        RX packets 947810  bytes 72203287 (68.8 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 3407541  bytes 4858575073 (4.5 GiB)
        TX errors 0  dropped 2097 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 160515  bytes 387653396 (369.6 MiB)
        TX packets 160515  bytes 387653396 (369.6 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.92.39.251  netmask 255.255.255.0  broadcast 10.92.39.255
        inet6 fa45::23v7:vvde:la90:d3d4  prefixlen 64  scopeid 0x20<link>
        inet6 5678:lj70:4455:ddfr4:78ip:vvdd:45tr:u7t5  prefixlen 64  scopeid 0x0<global>
        ether 56:a5:lp:78:f5:f3  txqueuelen 1000  (Ethernet)
        RX packets 156925  bytes 214499218 (204.5 MiB)
        TX packets 77688  bytes 11670689 (11.1 MiB)
        TX errors 0  dropped 2 overruns 0  carrier 0  collisions 0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.1.10.1  netmask 255.0.0.0  broadcast 10.255.255.255
        ether b0:ac:82:ff:a8:86  txqueuelen 1000  (Ethernet)
        RX packets 3262  bytes 235917 (230.3 KiB)
        RX errors 0  dropped 3  overruns 0  frame 0
        TX packets 3605  bytes 358278 (349.8 KiB)
        TX errors 0  dropped 95 overruns 0  carrier 0  collisions 0
perhaps I should made "that" bridge that I read in other articles like this one:
https://www.cyberciti.biz/faq/debian-ub … ess-point/
#14 2025-11-19 16:44:20
g4sra
You cannot assign 10.1.10.1 to both eth0 and wlan0.
If you want your wireless network to be a continuation of your existing ethernet network then you need to bridge.
Or
Make a new subnet for your wireless network e.g. 10.1.11.1/255.255.255.0
You will also need a DHCP server for this new subnet and routing configured.
#15 2025-11-19 18:41:11
Danielsan
g4sra... Got you but I am already setup this way, unless I am doing a typical pebcak mistake!  🤷
# eth0
auto eth0
iface eth0 inet static
	address 10.0.10.1/24
	gateway 10.0.10.254
# wlan0
auto wlan0
    address 10.1.10.1/24
    gateway 10.1.10.254
# usb0
allow-hotplug usb0
iface usb0 inet dhcp
#16 2025-11-19 19:27:00
Danielsan
I found the pebcak: you don't need to specify any gateway if your goal is to create a "direct connection".
Here the steps I made:
  • 1. Install hostapd
  • 2. modify /etc/default/hostapd:
    DAEMON_CONF="/etc/hostapd/hostapd.conf"
  • 3. I need to create direct connection (crosscable), here my interfaces
    auto lo
    iface lo inet loopback
    # # DHCP
    # auto eth0
    # allow-hotplug eth0
    # iface eth0 inet dhcp
    # The primary network interface
    auto eth0
    # wlan0
    auto wlan0
    # usb0
    allow-hotplug usb0
  • 4. Create: /etc/hostapd/hostapd.conf
    ### Wireless network name ###
    interface=wlan0
    driver=nl80211
    country_code=US
    ssid=$ESSID-NAME
    hw_mode=g
    channel=1
    wpa=2
    wpa_passphrase=$PASSPHRASE
    ## Key management algorithms ##
    wpa_key_mgmt=WPA-PSK
    ## Set cipher suites (encryption algorithms) ##
    ## TKIP = Temporal Key Integrity Protocol
    ## CCMP = AES in Counter mode with CBC-MAC
    wpa_pairwise=TKIP
    rsn_pairwise=CCMP
    ## Shared Key Authentication ##
    auth_algs=1
    ## Accept all MAC address ###
    macaddr_acl=0
  • 5. restart the network: sudo service networking restart
  • 6. start the hostapd deamon: sudo service networking start
⚠️ please be advised that I reverted the name of the interfaces to the legacy naming!
