#1 2025-11-16 21:24:35
kapqa
(excalibur) strange messages during startup
Hello ,
sometimes getting strange messages during starting
like
[color]udevd - unknown iidentifier ^zoom^[/color]
to my knowledge have not even installed this program
or sometimes there is error with
[color]alsa-restore[/color]
beg your pardon that the startupp is bit too slow to write down all the messages at once.
thanks
#2 2025-11-16 22:21:54
tux_99
Re: (excalibur) strange messages during startup
You can run sudo dmesg in a terminal window after startup is completed to see these messages again and then copy them here exactly.
Either the users control the program – or the program controls the users” Richard Stallman
#3 2025-11-16 22:33:58
With Excalibur/Trixie a new kernel feature has been introduced. Some additional messages are coloured now.
Look if bootlogd is installed, if not install. Then you get a subset of what is logged during boot in /var/log/boot.
#4 2025-11-17 15:15:59
kapqa
@tux_99 thanks,
this is a rather interesting command, but i think the error messages were somewhat different, will have to look at it again.
is it possible to export the contents of "dmesg" with the same color schemes as they occur inside of therminal?
there are however, some oddities, like "12661.134999] ata7: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ah, now might have found one candidate , like
[12661.141912] ata7.00: failed to set xfermode (err_mask=0x1)
but the most common was "failed to restore alsa" or similar;
@rolfie, thanks , it is installed;
here is like output
潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›瑓牡楴杮戠潯⁴潬杧牥›潢瑯潬摧਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›匀瑥楴杮甠⁰敫批慯摲氠祡畯⹴⸮潤敮മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵䄠瑣癩瑡湩⁧睳灡⸮搮湯⹥਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›桃捥楫杮映汩⁥祳瑳浥⹳⸮獦正昮瑡㐠㈮⠠〲ㄲ〭ⴱㄳഩ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵⼠敤⽶癮敭渱瀱㨳ㄠ‴楦敬ⱳ㈠㐲⼷㐲㘹〲挠畬瑳牥൳䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵搠湯⹥਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›汃慥楮杮甠⁰整灭牯牡⁹楦敬⹳⸮⼠浴⹰਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›潌摡湩⁧敫湲汥洠摯汵⁥灬മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵䰠慯楤杮欠牥敮潭畤敬瀠摰癥മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵䰠慯楤杮欠牥敮潭畤敬瀠牡潰瑲灟⹣਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›潍湵楴杮氠捯污映汩獥獹整獭⸮搮湯⹥਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›捁楴慶楴杮猠慷晰汩⁥睳灡晩愠祮⸮搮湯⹥਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›汃慥楮杮甠⁰整灭牯牡⁹楦敬⹳⸮മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵匠慴瑲湩⁧敓瑴湩⁧敫湲汥瘠牡慩汢獥›祳捳汴മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵䌠湯楦畧楲杮渠瑥潷歲椠瑮牥慦散⹳⸮潤敮മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵䌠敬湡湩⁧灵琠浥潰慲祲映汩獥⸮⸮਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›瑓牡楴杮›灁䅰浲牯潌摡湩⁧灁䅰浲牯瀠潲楦敬⹳⸮歓灩楰杮瀠潲楦敬椠支捴愯灰牡潭⹲⽤楤慳汢㩥甠牳戮湩洮浳灴਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›歓灩楰杮瀠潲楦敬椠支捴愯灰牡潭⹲⽤楤慳汢㩥甠牳戮湩琮畨摮牥楢摲਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›潤敮മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵⸠਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›敓瑴湩⁧灵堠猠捯敫⁴楤敲瑣牯敩⹳⸮⼠浴⽰堮ㄱ甭楮⁸琯灭ⸯ䍉ⵅ湵硩മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵匠瑥楴杮甠⁰䱁䅓⸮搮湯⹥਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›瑓牡楴杮圠楲整戠潯⁴湡⁤桳瑵潤湷琠浩獥椠瑮瑷灭扤›瑷灭扤甭摰瑡ⵥ潢瑯മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵匠瑥楴杮猠湥潳獲氠浩瑩⹳⸮剅佒㩒䌠湡琧朠瑥瘠污敵漠⁦畳晢慥畴敲琠浥㍰浟湩›⽉⁏牥潲൲䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵䔠剒剏›慃❮⁴敧⁴慶畬⁥景猠扵敦瑡牵⁥整灭弳慭㩸䤠伯攠牲牯਍潍潎⁶㜱ㄠ㨰〴㈺‵〲㔲›潤敮മ䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵匠慴瑲湩⁧牂楡汬⁥整浲湩污搠楲敶㩲戠汲瑴൹䴊湯丠癯ㄠ‷〱㐺㨰㔲㈠㈰㨵 മ䴊湯丠癯ㄠ‷〱㐺㨰㘲㈠㈰㨵ഠ义呉›湅整楲杮爠湵敬敶㩬㈠഍䴊湯丠癯ㄠ‷〱㐺㨰㘲㈠㈰㨵唠楳杮洠歡晥汩ⵥ瑳汹⁥潣据牵敲瑮戠潯⁴湩爠湵敬敶⸲਍潍潎⁶㜱ㄠ㨰〴㈺‶〲㔲›敓瑴湩⁧灵挠湯潳敬映湯⁴湡⁤敫浹灡⸮搮湯⹥਍潍潎⁶㜱ㄠ㨰〴㈺‶〲㔲›瑓牡楴杮攠扣㩤മ䴊湯丠癯ㄠ‷〱㐺㨰㘲㈠㈰㨵匠慴瑲湩⁧敳瑡㩤猠慥摴മ䴊湯丠癯ㄠ‷〱㐺㨰㘲㈠㈰㨵匠慴瑲湩⁧慷捴摨杯欠敥慰楬敶搠敡潭⹮⸮摷歟敥慰楬敶›渠慷捴摨杯搠癥捩⁥潣普杩牵摥扡牯楴杮਍潍潎⁶㜱ㄠ㨰〴㈺‶〲㔲›മ䴊湯丠癯ㄠ‷〱㐺㨰㘲㈠㈰㨵匠慴瑲湩⁧湥慨据摥猠獹潬摧›獲獹潬摧മ䴊湯丠癯ㄠ‷〱㐺㨰㘲㈠㈰㨵匠慴瑲湩⁧湡捡栨爩湯獩楴⁣牣湯›湡捡潲⹮਍潍潎⁶㜱ㄠ㨰〴㈺‶〲㔲›嬛ㄷ⁇潤敮਍潍潎⁶㜱ㄠ㨰〴㈺‶〲㔲›瑓牡楴杮䄠慰档⁥瑨灴⁤敷⁢敳癲牥›灡捡敨䄲え㔰㠵›灡捡敨㨲䌠畯摬渠瑯爠汥慩汢⁹敤整浲湩⁥桴⁥敳癲牥猧映汵祬焠慵楬楦摥搠浯楡慮敭獵湩⁧㈱⸷⸰⸱⸱匠瑥琠敨✠敓癲牥慎敭‧楤敲瑣癩⁥汧扯污祬琠畳灰敲獳琠楨⁳敭獳条൥䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵⸠਍潍潎⁶㜱ㄠ㨰〴㈺‷〲㔲›瑓牡楴杮瀠牥潩楤⁣潣浭湡⁤捳敨畤敬㩲挠潲⹮਍潍潎⁶㜱ㄠ㨰〴㈺‷〲㔲›瑓牡楴杮传数䉮䑓匠捥牵⁥桓汥敳癲牥›獳摨മ䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵匠慴瑲湩⁧祳瑳浥洠獥慳敧戠獵›扤獵മ䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵匠慴瑲湩⁧楌桧⁴楄灳慬⁹慍慮敧㩲氠杩瑨浤മ䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵匠慴瑲湩⁧敳獳潩慭慮敧敭瑮搠敡潭㩮攠潬楧摮മ䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵匠慴瑲湩⁧癁桡⁩䑭华䐯华匭⁄慄浥湯›癡桡⵩慤浥湯മ䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵匠慴瑲湩⁧啃卐䈠湯潪牵搠敡潭㩮挠灵⵳牢睯敳⹤਍潍潎⁶㜱ㄠ㨰〴㈺‷〲㔲›瑓牡楴杮匠乁⁅敮睴牯捳湡敮⁲敳癲牥›慳敮⹤਍潍潎⁶㜱ㄠ㨰〴㈺‷〲㔲›瑓牡楴杮渠瑥潷歲挠湯敮瑣潩慭慮敧㩲丠瑥潷歲慍慮敧⹲਍潍潎⁶㜱ㄠ㨰〴㈺‷〲㔲›瑓牡楴杮䴠䅔›硥浩⸴਍潍潎⁶㜱ㄠ㨰〴㈺‷〲㔲›潎⁴瑳牡楴杮映瑥档慭汩搠敡潭Ɱ搠獩扡敬⁤楶⁡支捴搯晥畡瑬是瑥档慭汩മ䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵匠慴瑲湩⁧潃浭湯唠楮⁸牐湩楴杮匠獹整㩭挠灵摳മ䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵匠慴瑲湩⁧潭獵⁥湩整晲捡⁥敳癲牥›灧⹭਍潍潎⁶㜱ㄠ㨰〴㈺‷〲㔲›瑓牡楴杮嘠睍牡⁥敳癲捩獥ഺ䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵††楖瑲慵慭档湩⁥潭楮潴᭲㝛䜱搠湯൥䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵††楖瑲慵慭档湩⁥潣浭湵捩瑡潩湩整晲捡᭥㝛䜱搠湯൥䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵††䵖挠浯畭楮慣楴湯椠瑮牥慦散猠捯敫⁴慦業祬嬛ㄷ⁇潤敮਍潍潎⁶㜱ㄠ㨰〴㈺‷〲㔲›†嘠物畴污攠桴牥敮᭴㝛䜱搠湯൥䴊湯丠癯ㄠ‷〱㐺㨰㜲㈠㈰㨵††䵖慷敲䄠瑵敨瑮捩瑡潩慄浥湯嬛ㄷ⁇潤敮਍潍潎⁶㜱ㄠ㨰〴㈺‷〲㔲›†匠慨敲⁤敍潭祲䄠慶汩扡敬嬛ㄷ⁇潤敮਍
aka?
sudo cat /var/log/boot
Mon Nov 17 10:40:25 2025: Starting boot logger: bootlogd
Mon Nov 17 10:40:25 2025: Setting up keyboard layout...done.
Mon Nov 17 10:40:25 2025: Activating swap...done.
Mon Nov 17 10:40:25 2025: Checking file systems...fsck.fat 4.2 (2021-01-31)
Mon Nov 17 10:40:25 2025: /dev/nvme1n1p3: 14 files, 2247/249620 clusters
Mon Nov 17 10:40:25 2025: done.
Mon Nov 17 10:40:25 2025: Cleaning up temporary files... /tmp.
Mon Nov 17 10:40:25 2025: Loading kernel module lp.
Mon Nov 17 10:40:25 2025: Loading kernel module ppdev.
Mon Nov 17 10:40:25 2025: Loading kernel module parport_pc.
Mon Nov 17 10:40:25 2025: Mounting local filesystems...done.
Mon Nov 17 10:40:25 2025: Activating swapfile swap, if any...done.
Mon Nov 17 10:40:25 2025: Cleaning up temporary files....
Mon Nov 17 10:40:25 2025: Starting Setting kernel variables: sysctl.
Mon Nov 17 10:40:25 2025: Configuring network interfaces...done.
Mon Nov 17 10:40:25 2025: Starting: AppArmorLoading AppArmor profiles...Skipping profile in /etc/apparmor.d/disable: usr.bin.msmtp
Mon Nov 17 10:40:25 2025: Skipping profile in /etc/apparmor.d/disable: usr.bin.thunderbird
Mon Nov 17 10:40:25 2025: .
Mon Nov 17 10:40:25 2025: Setting up X socket directories... /tmp/.X11-unix /tmp/.ICE-unix.
Mon Nov 17 10:40:25 2025: Setting up ALSA...done.
Mon Nov 17 10:40:25 2025: Starting Write boot and shutdown times into wtmpdb: wtmpdb-update-boot.
Mon Nov 17 10:40:25 2025: Setting sensors limits...ERROR: Can't get value of subfeature temp3_min: I/O error
Mon Nov 17 10:40:25 2025: ERROR: Can't get value of subfeature temp3_max: I/O error
Mon Nov 17 10:40:25 2025: Starting Braille terminal driver: brltty
INIT: Entering runlevel: 2
Mon Nov 17 10:40:26 2025: Using makefile-style concurrent boot in runlevel 2.
Mon Nov 17 10:40:26 2025: Setting up console font and keymap...done.
Mon Nov 17 10:40:26 2025: Starting ecbd:.
Mon Nov 17 10:40:26 2025: Starting seatd: seatd.
Mon Nov 17 10:40:26 2025: Starting watchdog keepalive daemon...wd_keepalive:  no watchdog device configured, aborting
Mon Nov 17 10:40:26 2025: .
Mon Nov 17 10:40:26 2025: Starting enhanced syslogd: rsyslogd.
Mon Nov 17 10:40:26 2025: Starting anac(h)ronistic cron: anacron.
Mon Nov 17 10:40:26 2025:                                              done
Mon Nov 17 10:40:26 2025: Starting Apache httpd web server: apache2AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
Mon Nov 17 10:40:27 2025: .
Mon Nov 17 10:40:27 2025: Starting periodic command scheduler: cron.
Mon Nov 17 10:40:27 2025: Starting OpenBSD Secure Shell server: sshd.
Mon Nov 17 10:40:27 2025: Starting system message bus: dbus.
Mon Nov 17 10:40:27 2025: Starting Light Display Manager: lightdm.
Mon Nov 17 10:40:27 2025: Starting session management daemon: elogind.
Mon Nov 17 10:40:27 2025: Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Mon Nov 17 10:40:27 2025: Starting CUPS Bonjour daemon: cups-browsed.
Mon Nov 17 10:40:27 2025: Starting SANE network scanner server: saned.
Mon Nov 17 10:40:27 2025: Starting network connection manager: NetworkManager.
Mon Nov 17 10:40:27 2025: Starting MTA: exim4.
Mon Nov 17 10:40:27 2025: Not starting fetchmail daemon, disabled via /etc/default/fetchmail.
Mon Nov 17 10:40:27 2025: Starting Common Unix Printing System: cupsd.
Mon Nov 17 10:40:27 2025: Starting mouse interface server: gpm.
Mon Nov 17 10:40:27 2025: Starting VMware services:
Mon Nov 17 10:40:27 2025:    Virtual machine monitor                   done
Mon Nov 17 10:40:27 2025:    Virtual machine communication interface   done
Mon Nov 17 10:40:27 2025:    VM communication interface socket family  done
Mon Nov 17 10:40:27 2025:    Virtual ethernet                          done
Mon Nov 17 10:40:27 2025:    VMware Authentication Daemon              done
Mon Nov 17 10:40:27 2025:    Shared Memory Available                   done
#5 2025-11-17 23:25:14
stultumanto
Open /etc/apache2/apache2.conf, go to the bottom, and add the line below. Don't actually use example.com. If you're running a public-facing server with a valid DNS entry, replace example.com with your domain. Otherwise, if you're just behind a home router with NAT, use the name on your local network, something like mycomputer.home.
ServerName example.com
I searched for some of your other errors. The temperature sensor is just typical boot log noise, in my opinion. Practically every system I've owned in the last 25 years has had a temperature sensor that either reported an error, reported bad data, or just wasn't detected at all. The ATA transfer error could be slowing down your disks, but I couldn't find a solution; you may just have to wait for a kernel patch.
#6 2025-11-19 17:55:19
kapqa
thanks, i may not use "apache" on this computer; probably it is installed on the NAS (to host webpages?=)
however, on laptop have checked again, there are some more error
[    2.443756] hub 1-1.4:1.0: USB hub found
[    2.444349] hub 1-1.4:1.0: 2 ports detected
[    2.460840] udevd[459]: starting version 3.2.14
[    2.495225] udevd[459]: GOTO 'alsa_restore_std' has no matching label in: '/usr/lib/udev/rules.d/90-alsa-restore.rules'
[    2.495257] udevd[459]: GOTO 'alsa_restore_std' has no matching label in: '/usr/lib/udev/rules.d/90-alsa-restore.rules'
[    2.500626] udevd[460]: starting eudev-3.2.14
3.273435] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:09.2/sound/card1/input18
[    3.291928] r8152 3-3:1.0 eth1: v1.12.13
[    3.292024] usbcore: registered new interface driver r8152
[    3.320062] usbcore: registered new interface driver cdc_ether
[    3.337465] usbcore: registered new interface driver r8153_ecm
[    3.338384] udevd[466]: Unknown key identifier 'zoom'
[    3.377372] r8152 3-3:1.0 enx00e04c723b68: renamed from eth1
thank zou very much
#7 2025-11-20 05:54:42
stultumanto
Yes, there are several different packages that can pull in apache2 as a dependency, including web configuration interfaces and documentation browsers. I think most people just ignore that error message if they're not hosting a real public-facing website.
The alsa_restore_std errors were due to a bug in a configuration file in upstream Debian. It was discussed in this thread. Supposedly, it was fixed, but it appears to have been broken again. It's still broken on all my Excalibur systems. As far as I can tell, it's not causing any audio problems, so I've been ignoring it.
I don't know about the 'zoom' error. It seems to have something to do with a USB Ethernet adapter. If the device is working properly, it may not be important. My Realtek Ethernet NIC reports missing firmware on boot, but when I looked it up, I found that the kernel doesn't even need the firmware to use the device! Linux errs on the side of caution when reporting errors.
#8 2025-11-20 17:55:34
RE: the alsa errors, have a look here: https://dev1galaxy.org/viewtopic.php?pid=59886#p59886
#9 2025-11-20 21:01:21
stultumanto
Thanks, greenjeans. I actually need to correct what I said, I haven't been getting the alsa error since November 15; I was looking at old boot logs. It seems I received an updated version at some point after the 15th.
