#1 2025-11-14 22:00:29
bai4Iej2need
debug firefox-esr microfone sound
with zoom.us test conference the loudspeaker works but the micro not.
Micro selection in zoom has only one choice, which is the one not working.
Microphone works in chromium zoom conference and in alsa loopback
devuan daedalus
only alsa, no pipewire, no pulseaudio. No other sound servers.
firefox-esr
Version: 140.5.0esr-1~deb12u1
Edit : desktop mate 1.26.0
where to start?
broken by design :
#2 2025-11-15 10:10:01
stultumanto
Re: debug firefox-esr microfone sound
Did you check the mixer? The Mic channel is often muted (or set to 0 volume) when you first set up a new system with ALSA. I'm not sure what desktop you're using, but you should be able to at least open alsamixer in a terminal and check the mic channel.
#3 2025-11-15 10:16:13
bai4Iej2need
alsamixer : all channels are open.
no, as mic works in chromium and loopback, problem is with interface to firefox-esr and librewolf.
broken by design :
#4 2025-11-15 10:36:10
For some firefox version I had to introduce a "dsnoop" pcm on the capture side, so that it could handle multiple concurrent accesses to the microphone. It appeared to be that firefox opened the microphone device before forking and thereby ended up in access contention with itself; the "dsnoop" pcm allows the microphone to be shared.
It resulted in a few pcm declarations in ~/.asoundrc:
pcm.!default {
    type plug
    slave {
        pcm splitter
        rate 48000 ; channels 2
pcm.splitter {
    type asym
    playback.pcm plughw
    capture.pcm mic
# The "mic" PCM adds "dsnoop" to source opening, which allows a single
# source be used by many "consuming processes". This is required by
# firefox, which otherwise locks out itself from using the microphone.
pcm.mic {
    type dsnoop
    ipc_key 5
    ipc_key_add_uid false
    slave {
        pcm "hw:0,0"
        period_size 2048 ; buffer_size 16384
        periods 0 ; period_time 0
        format S16_LE ; rate 48000 ; channels 2
Something like that; it was a while ago and I'm not totally sure about it.
#5 2025-11-15 12:37:51
igorzwx
Ralph, haven't you noticed that Debian/Devuan has already both dmix and dsnoop enabled by default?
Debian Wiki:
Advanced features such as mixing should already be configured with sane defaults.
_https://wiki.debian.org/ALSA#Configuration
Try this command:
grep -r "defaults.pcm.dmix.rate" /usr/share/alsa/
#6 2025-11-15 22:13:58
Yes I noticed you mentioned that some while ago (and has verified on my system).
I still needed the setup on that (daedalus) system, so thought to mention it. Baybe it rather was the S16_LE setting for the microphone that made the difference, or the 48k sampling (?) I'm not sure.
#7 2025-11-15 22:40:16
igorzwx
Do you need a fully functional ALSA software mixer? For example:
$ cat ~/.asoundrc
# ALSA library configuration file managed by arateconf.
# MANUAL CHANGES TO THIS FILE WILL BE OVERWRITTEN!
# Manual changes to the ALSA library configuration should be implemented
# by editing the ~/.asoundrc file, not by editing this file.
# Configuration for system
# Perform dmixer
pcm.dmixer_system
	type			dmix
	ipc_key			1024
	ipc_perm		0666
	hint
		show		off
		description	"Direct mixing of multiple audio streams (system)"
	slave
		pcm		"hw:system,0"
		rate		48000
		channels	2
		format		S16_LE
		period_size	1920
		buffer_size	7680
# Perform dsnooper
pcm.dsnooper_system
	type			dsnoop
	ipc_key			1025
	ipc_perm		0666
	hint
		show		off
		description	"Recording from the same device for several applications simultaneously (system)"
	slave
		pcm		"hw:system,0"
		rate		48000
		format		S16_LE
		period_size	1920
		buffer_size	7680
# Perform duplex
pcm.duplex_system
	type			asym
	playback.pcm		"dmixer_system"
	capture.pcm		"dsnooper_system"
	hint
		show		off
		description	"Full duplex for simultaneous playback and recording (system)"
# Perform convert
pcm.convert_system
	type			rate
	converter		fftrate
	hint
		show		off
		description	"Sample rate converter (system)"
	slave
		pcm	"duplex_system"
		rate	48000
		format	S16_LE
# Perform plug device
pcm.primary_system
	type			plug
	slave.pcm		"convert_system"
	hint.description	"Default device (system)"
# Configuration for PCH
# Perform dmixer
pcm.dmixer_PCH
	type			dmix
	ipc_key			1026
	ipc_perm		0666
	hint
		show		off
		description	"Direct mixing of multiple audio streams (PCH)"
	slave
		pcm		"hw:PCH,0"
		rate		192000
		channels	2
		format		S32_LE
		period_size	7680
		buffer_size	30720
# Perform dsnooper
pcm.dsnooper_PCH
	type			dsnoop
	ipc_key			1027
	ipc_perm		0666
	hint
		show		off
		description	"Recording from the same device for several applications simultaneously (PCH)"
	slave
		pcm		"hw:PCH,0"
		rate		192000
		format		S32_LE
		period_size	7680
		buffer_size	30720
# Perform duplex
pcm.duplex_PCH
	type			asym
	playback.pcm		"dmixer_PCH"
	capture.pcm		"dsnooper_PCH"
	hint
		show		off
		description	"Full duplex for simultaneous playback and recording (PCH)"
# Perform convert
pcm.convert_PCH
	type			rate
	converter		fftrate
	hint
		show		off
		description	"Sample rate converter (PCH)"
	slave
		pcm	"duplex_PCH"
		rate	192000
		format	S32_LE
# Configuration for default audio device
pcm.!default
	type			plug
	slave.pcm		"convert_PCH"
	hint.description	"Default device"
$ cat /proc/asound/cards
 0 [system         ]: USB-Audio - iMic USB audio system
                      Griffin Technology, Inc iMic USB audio system at usb-0000:00:1a.0-1.3.4, full s
 1 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0xf7e10000 irq 31
Firefox has cubeb inside
libcubeb - Cross-platform Audio I/O Library
_https://github.com/mozilla/cubeb
All backends are still buggy, except for the backend for CoreAudio (macOS).
A standalone cubeb is easy to compile with CMake and ninja. You can debug ALSA backend.
Zoom app works with ALSA, provided that you have a fully functional software mixer.
But Discord should be used with apulse
apulse discord
#8 2025-11-15 23:53:54
That's a great .asoundrc example. Though you could have omitted "primary_system" tree which most likely will confuse the casual reader smile
I suggest the OP should only consider the part following # Configuration for PCH.
You, the reader, may however note the similarities between the "default" tree and the "primary_system" tree (which targets the USB sound card), and pay attention to the differences in their sample rates and bit sizes (48k, 16 bits versus 192k, 32 bits). In both cases rate conversions are handled by fftrate which @igorzwx introduced us to last year.
See e.g, https://dev1galaxy.org/viewtopic.php?id=7142 or search fftrate on the forum. We are still longing for a debian packaging of this.
#9 2025-11-16 05:43:26
stultumanto
If anyone else has been looking for the documentation for the .asoundrc format, I found it at the official ALSA wiki. It was kind of buried in a half-broken list of links on the Documentation page. If that link ever goes down, there's also an archive here. It would be nice if .asoundrc actually had a man page, like xorg.conf, and many other system configuration files.
#10 2025-11-17 10:25:12
bai4Iej2need
@rrq
my current /etc/asound.conf is :
defaults.pcm.!card PCH
defaults.ctl.!card PCH
Is the here https://dev1galaxy.org/viewtopic.php?pid=59668#p59668 proposed solution an addition to that setting ?
thx
broken by design :
#11 2025-11-17 11:14:58
igorzwx
Set defaults in ~/.asoundrc:
$ cat ~/.asoundrc
and run
apulse firefox
$ apt-cache search apulse
apulse - PulseAudio emulation for ALSA
Debug (logging):
with apulse
MOZ_LOG="cubeb:5" apulse firefox 2>&1 about:support
without apulse
MOZ_LOG="cubeb:5" firefox 2>&1 about:support
#12 2025-11-17 12:46:26
@bai4Iej2need yes it would be in addition. Your settings defines the CARD "variable" and it thus applies separately and together.
Though, as @igorzwx noted, the default setup might already have dsnoop and dmix.
#13 2025-11-17 12:53:30
igorzwx
Full duplex is also enabled by default with asym  in /usr/share/alsa/cards/HDA-Intel.conf
MOZ_LOG="cubeb:5" should show
        Type:	input
	State:	enabled
DMIX IS ENABLED by default.
Remove your ALSA config, play audio from two sources at once, and you’ll hear the default dmix quietly doing its job. When using multiple sound cards, setting defaults.pcm.!card and defaults.ctl.!card in ~/.asoundrc ensures ALSA directs audio and control to the correct device. Without this, removing your config may cause ALSA to default to a different card — potentially making sound "disappear." Use the card’s name (e.g., PCH) or index to lock the default.
#14 2025-11-17 15:28:23
igorzwx
Firefox with apulse
Firefox pulse-rust → apulse → ALSA   Input is ENABLED  Roundtrip latency 162.86ms (18.90)
$ MOZ_LOG="cubeb:5" apulse firefox 2>&1 about:support
	Type:	output
	State:	enabled
	Type:	input
	State:	enabled
	Maximum channels:	2
	Format:	S16LE S16BE F32LE F32BE (0x3030) (default: S16LE)
	Rate:	[1, 384000] (default: 44100)
	L
about:support
Name 	Firefox
Version 	140.5.0esr
Build ID 	20251106203603
Audio Backend	pulse-rust
Max Channels	2
Preferred Sample Rate	44100
Roundtrip latency (standard deviation)	162.86ms (18.90)
Firefox with ALSA without apulse
Firefox → ALSA   NOTHING about Input   Roundtrip latency ?
$ MOZ_LOG="cubeb:5" firefox 2>&1 about:support
	Type:	output
	State:	enabled
	Maximum channels:	10000
	Format:	S16LE (0x10) (default: S16LE)
	Rate:	[48000, 48000] (default: 48000)
	Latency: lo 0 frames, hi 0 frames
# NOTHING about Input
about:support
Name 	Firefox
Version 	140.5.0esr
Audio Backend	alsa
Max Channels	10000
Preferred Sample Rate	48000
Roundtrip latency (standard deviation)	NaNms (NaN)
Défault ALSA config, only one soundcard iMic USB
You can file a bug to Firefox (CUBEB's ALSA backend)
#15 2025-11-18 01:04:02
bai4Iej2need
@igorzwx
MOZ_LOG="cubeb:5" firefox 2>&1 about:support > alsadebug.txt
grep -A1 Type: alsadebug.txt
	Type:	output
	State:	enabled
	Type:	output
	State:	enabled
grep -c input alsadebug.txt
40
40*
Parent 5845: BackgroundThreadPool #1]: E/cubeb Could not get input latency
[Parent 5845: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Parent 5845: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Parent 5845: Main Thread]: V/cubeb media.cubeb.sandbox: false
[Parent 5845: Main Thread]: E/cubeb media.cubeb.sandbox: false, but content sandbox enabled - forcing true
[Child 5935: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 5935: Main Thread]: V/cubeb media.cubeb.sandbox: false
[Child 5935: Main Thread]: E/cubeb media.cubeb.sandbox: false, but content sandbox enabled - forcing true
[Child 5935: Main Thread]: I/cubeb media.cubeb.sandbox: true
[Parent 5845: Main Thread]: D/cubeb Starting cubeb server...
[Parent 5845: Main Thread]: D/cubeb media.audioipc.shm_area_size: 0
[Parent 5845: Main Thread]: I/cubeb media.cubeb.sandbox: true
[Parent 5845: Main Thread]: D/cubeb media.audioipc.stack_size: 262144
[Parent 5845: AudioIPC Server RPC]: E/cubeb cubeb.c:654:DeviceID: "default" (PREFERRED)
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
[Parent 5845: Main Thread]: E/cubeb cubeb.c:654:DeviceID: "default" (PREFERRED)
        Group:  "default"
        Vendor: "default"
        Type:   output
        State:  enabled
[Parent 5845: BackgroundThreadPool #1]: E/cubeb Could not get input latency
MOZ_LOG="cubeb:5" firefox about:support 2>&1  9,65s user 2,25s system 22% cpu 52,439 total
While chromium shows all the micro inputs in the settings menu, firefox shows default only .
@rrq : done with the modificaion shown
@rrq : The change in /etc/asound.conf had adverse effects on chromium : no sound on my receiving end. I eliminated this change.
broken by design :
#16 2025-11-19 16:40:23
igorzwx
To get microphone working with Firefox, you should completely disable sandboxing.
This is, of course, a security problem.
SETUP for DEBUG (MOZ_LOG):
$ inxi -Sxxx
System:
  Host: devuan Kernel: 6.1.0-41-amd64 arch: x86_64 bits: 64 compiler: gcc
    v: 12.2.0 Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
    dm: LightDM v: 1.26.0 Distro: Devuan GNU/Linux 5 (daedalus)
about:support
Name 	Firefox
Version 	140.5.0esr
Audio Backend	alsa
Max Channels	10000
about:config
media.cubeb.backend		alsa
media.cubeb.sandbox		false
Default Debian/Devuan ALSA config (without any changes).
1 soundcard iMic USB
$ cat ~/.asoundrc
cat: ~/.asoundrc: No such file or directory
Debug (Mozilla logging):
MOZ_DISABLE_CONTENT_SANDBOX=1 MOZ_LOG="cubeb:5" firefox 2>&1 about:support
	Type:	input
	State:	enabled
$ MOZ_DISABLE_CONTENT_SANDBOX=1 MOZ_LOG="cubeb:5" firefox 2>&1 about:support
[Parent 10304: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Parent 10304: Main Thread]: V/cubeb media.cubeb.sandbox: true
[Parent 10304: Main Thread]: V/cubeb media.cubeb.sandbox: false
[Child 10401: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 10401: Main Thread]: V/cubeb media.cubeb.sandbox: false
[Parent 10304: Main Thread]: I/cubeb media.cubeb.sandbox: false
[Parent 10304: Main Thread]: E/cubeb cubeb.c:654:DeviceID: "default" (PREFERRED)
	Group:	"default"
	Vendor:	"default"
	Type:	output
	State:	enabled
	Group:	"default"
	Vendor:	"default"
	Type:	input
	State:	enabled
[Child 10461: Main Thread]: V/cubeb media.cubeb.force_null_context: false
[Child 10461: Main Thread]: V/cubeb media.cubeb.sandbox: false
[Parent 10304: BackgroundThreadPool #1]: E/cubeb Could not get input latency
The "Could not get input latency" error in Firefox with ALSA is a known limitation in Cubeb.
Despite dsnoop working and audio flowing, Cubeb fails to query latency from ALSA input devices — especially when using dmix/dsnoop via the default PCM. This results in 0 frames reported for input latency, even though capture works.
This issue is documented in:
Bugzilla #1650131 : ALSA input shows Latency: lo 0 frames, hi 0 frames
_https://bugzilla.mozilla.org/show_bug.cgi?id=1650131
Bugzilla #907817 : ALSA backend does not implement proper latency reporting
_https://bugzilla.mozilla.org/show_bug.cgi?id=907817
Cubeb assumes PulseAudio or PipeWire for accurate timing — with raw ALSA, it falls back to estimated or fixed latency values.
The setup works — the error is cosmetic and reflects Cubeb’s lack of ALSA input latency support, not a functional failure.
Right — the setup works, really. Only a minor security oversight, nothing one wouldn’t overlook. PulseAudio, of course, enjoys a rather privileged position — able to wander in and out as it pleases. ALSA, on the other hand, is quite content with its role: quietly serving, obeying, and generally staying out of the way. One might say its freedom is… limited, just enough to make independent use a tad inconvenient.
And if one happens to hear perfectly well, well — perhaps macOS was the intended destination all along.
