#1 2025-11-13 00:42:51
Danielsan
Issue with Evolution
Hi guys, it looks like this upgrade to Excalibur hasn't been painless at all.
After the video card, the logs, it is time of Evolution:
$ evolution
(org.gnome.Evolution:13855): dbind-WARNING **: 19:32:13.898: Couldn't connect to accessibility bus: Failed to connect to socket /run/user/115/at-spi/bus_0: Permission denied
(evolution-alarm-notify:13878): dbind-WARNING **: 19:32:15.005: Couldn't connect to accessibility bus: Failed to connect to socket /run/user/115/at-spi/bus_0: Permission denied
bwrap: Can't find source path /run/user/115/at-spi: Permission denied
** (org.gnome.Evolution:13855): ERROR **: 19:32:15.205: Failed to fully launch dbus-proxy: Child process exited with code 1
fish: Job 1, 'evolution' terminated by signal SIGTRAP (Trace or breakpoint trap)
I tried to reinstall some packages, but I have this feeling the problem is that I have to (re)install it with all the recommended dependencies that means half gnome... 🤷
#2 2025-11-13 00:46:27
Danielsan
Re: Issue with Evolution
I am thinking to ditch Evolution, that used to work very well, with Claws Mail... 🤔
#3 2025-11-14 15:01:11
claws should be fine, especially if you are in the no-html email camp
#4 2025-11-14 17:07:39
Calamity
Been using Claws Mail for a long time, and can definitely recommend it. Very configurable yet lightweight.
Re-examine all that you have been told. Dismiss that which insults your soul.  - Walt Whitman
Dump shampoo and hair dye
Global Skywatch・Subliminal Manipulation
#5 2025-11-15 15:27:27
Danielsan
Claws Mail works fine.
Evolution has been good so far... I found that also others dude in the non-systemd spectrum are having issue:
https://forum.artixlinux.org/index.php/ … 340.0.html
Today I got a beefy packages update (including a "libevolution") but it didn't fix the issue... On Debian Trixie I don't have this problem though...  I feel stink of systemd... 🤢
