#1 2025-11-09 21:49:51
TalionRanger117
Hi, new here just joined devuan. need help with games an programs.
Hi, there i just joined devuan after seeing it has a release dof excalibur. i installed it on my lenovo legion go device. so far i managed it very well.
some issues, i notice winetricks is not available. i couldnt install quake enhanced from heroic games launcher.
i couldnt install wine32.
how do i install winetricks, wine32 an fix quake 1 enhanched? quake enhance refuses to install. it starts installing, but, it fails after it finishes.
how do i update devuan?
otherwise great job, its very smooth an stable an performance is great. just need help with some programs an games.
thanks.
oh, im using xfce distribution. i installed discover store too. im using lenovo legion go device.
#2 2025-11-10 03:31:28
goat
Re: Hi, new here just joined devuan. need help with games an programs.
It seems, it's likely, that your problem is: 'contrib' repository is disabled.
I believe 'contrib' and 'non-free' are omitted/disabled by default.
sudo nano /etc/apt/sources.list
or
su
to root and adjust your sources.list accordingly then run
apt update
.  That should give you access to winetricks
deb http://pkgmaster.devuan.org/merged excalibur main contrib non-free
<-- Should look something like that; and you can query the Web to find out how to alter your /etc/apt/sources.list file, as well.
Now, to install wine32..?  I think you'd have to enable x86 access.  You'll have to look that up.
I did a bit of searching and found some answers with the search query "can't install wine32 on debian."  Though I can't be sure of what is proper for your use case.  Seems there is a way to enable 32bit apt sources, as well as perhaps some kind of "wine-installer" that perhaps just autoconfigures everything?  I think on my main rig, I just enabled 32bit sources with dpkg or some sort of wizardry I don't recall at the moment.
Anywho good luck.  Query the web.
As far as gaming goes, I tend to use pre-packaged and sand-boxed stuff (flatpak, AppImage, etc..), unless the devuan repos suffice for whatever it is.
I think there are a few options out there for dedicated 'gaming distros' as well.  However, if you prefer to remain SystemD free; welcome aboard.
#3 2025-11-10 03:56:19
https://wiki.debian.org/Wine#Step_1:_Enable_multiarch
Without logs or command output, all that remains is speculation.
https://wiki.debian.org/PackageManagement, same as any debian-based distro.
#4 2025-11-10 16:34:55
TalionRanger117
gave methis error
bash: deb: command not found
i was able to get quake 1 enhanced to install. so that worked.
got wine32 to install.
now i just need to get winetricks installed.
#5 2025-11-10 16:53:52
goats advice to use pkgmaster is no good.
On the top of the forum is a link to the Devuan page. Its worth following the link. Here is something to read:
https://www.devuan.org/os/packages
A full blown correct sources entry should look like this:
deb http://deb.devuan.org/merged excalibur main contrib non-free non-free-firmware
BTW: to use
su
to become root is also outdated.
You need to use
su -
or the path setting will be incorrect.
#6 2025-11-10 22:58:17
RedGreen925
You need to use
su -
Unless you were reading the change log file and took the advice contained in it to make this file overcoming that breaking change, perhaps might have been news file not sure now it occurs to me. Something that is becoming far to common in Debian these days breaking compatibility just for the hell of it...
root@9600k:~# cat /etc/default/su
# Added to always have the PATH set for su.
ALWAYS_SET_PATH yes
Edit: Oh if you are going to be messing with the sources file move it to a backup and create the new style one and use that.
root@9600k:~# cat /etc/apt/sources.list.d/devuan.sources
# Devuan 6 excalibur
## The new style method of using repositories to install software.
## This /etc/apt/sources.list.d/devuan.sources is new style and location file
## The /etc/apt/old.style.sources.list contains the same as this.
## https://linuxconfig.org/ubuntus-repository-configuration-ubuntu-sources-have-moved-to-etc-apt-sources-list-d-ubuntu-sources
## Normal excalibur sources
Types: deb
URIs: http://gnlug.org/pub/devuan/merged
Suites: excalibur excalibur-backports excalibur-proposed-updates  excalibur-updates
Components: main non-free contrib non-free-firmware
Enabled: yes
Signed-By: /usr/share/keyrings/devuan-archive-keyring.gpg
Architectures: amd64
## excalibur security sources
Types: deb
Suites: excalibur-security
Enabled: yes
#7 2025-11-11 00:09:39
TalionRanger117
BTW: to use
su
You need to use
su -
i see i give this a read. https://www.devuan.org/os/packages
for deb http://deb.devuan.org/merged excalibur main contrib non-free non-free-firmware
i use that an give it a shot.
i put deb http://deb.devuan.org/merged excalibur main contrib non-free non-free-firmware  in terminal right?
as for su. that makes sense. so devuan uses a different su thing.
so instead of su its su -
i defiantly make a copy if i mess around with sources.d
#8 2025-11-11 08:43:47
with respect to the relatively recent(historically speaking) su/substitute_user/switch_user/etc kerfuffle
https://unix.stackexchange.com/questions/460478/debian-su-and-su-path-differences
#9 2025-11-11 10:26:42
goat
I still suspect you need to enable your 'contrib' and 'non-free' repos, if you have not done so.
su - root
To get root access for editing your /etc/apt/sources.list file
cd /etc/apt
Change Directory to /etc/apt
cp sources.list sources.list.backup
Make a backup of your original sources.list file
nano sources.list
Open your sources.list file in a text editor so you can modify it to look like the following.
You must add the 'contrib' and 'non-free' sources (you do this while inside the 'nano' program, a text editor).  I believe you also should add 'contrib' and 'non-free' to the 'excalibur-security' and 'excalibur-updates' lines as well.
And that should, to the best of my understanding, give you access to 'winetricks' which is in the 'contrib' repositories.
(sidenote: I do use su - root , myself.  I was just pointing to the 'su' program itself, which is named, 'su'.)
You would then want to follow the above advice from steve_v by enabling multi-arch
That's the best I can think of to solve your issue.
#10 2025-11-11 16:11:19
TalionRanger117
where do i put the deb http://deb.devuan.org/merged excalibur main contrib non-free non-free-firmware in sources.list?
#11 2025-11-12 00:50:02
you may put that line anywhere under the standard info (head), but anywhere will work.
If there is a duplicate you may see error complaints, but it (the update and/or installations) should still work.
As for the su changes, I add an entry in to ~/.bash. Generally I put the line with other alias' in the file.
/home/glenn/.bashrc
	alias su='su -'
This way I don't get problems if there's an update/upgrade that changes the way su (substitute user) is invoked.
#12 2025-11-12 16:03:03
TalionRanger117
so under
#deb cdrom:[Devuan GNU/Linux 6.0.0-rc1 excalibur amd64 - netinstall 20250913]/ excalibur contrib main no>
deb http://deb.devuan.org/merged excalibur main non-free-firmware
deb-src http://deb.devuan.org/merged excalibur main non-free-firmware
deb http://deb.devuan.org/merged excalibur-security main non-free-firmware
deb-src http://deb.devuan.org/merged excalibur-security main non-free-firmware
deb-src http://deb.devuan.org/merged excalibur main contrib non-free non-free-firmware
is this ok to do?
i put contrib one under security.
will this cause any issues?
#13 2025-11-12 20:54:26
The order is not important, but duplicates might be a bother. I.e., you should remove the top two, because the are duplicates for excalibur/main and excalibur/non-free-firmware.
In addition, you should probably add sources.list lines for excalibur-updates and excalibur-proposed-updates ... also using sections main, contrib, non-free and non-free-firmwares. With that you would be more "future ready".
#14 2025-11-13 01:34:50
TalionRanger117
duplicates?  when adding a contrib one i dont need the first one an the security one?
how should it look for deb http://deb.devuan.org/merged excalibur main contrib non-free non-free-firmware
deb-src http://deb.devuan.org/merged excalibur main contrib non-free non-free-firmware?
where does excalibur-updates an excalibur-proposed-updates go to?
sorry for all of these questions im learning how this works. want to make sure im doing this correctly.
#15 2025-11-13 02:39:01
The four labels main, contrib, non-free and non-free-firmware are known as sections;
The four labels excalibur, excalibur-updates, excalibur-secority and excalibur-proposed-updates are known as codenames;
The URL http://deb.devuan.org/merged is known as the base.
The prefix label deb indicates that the line is for binary packages, and the prefix label deb-src indicates that the line is for source packages.
Each sources.list line includes (in order) a prefix label, the base, a codename, and one or more sections. You can have it as 4 lines with a single section on each, or as a single line with all four sections.
I suggested you have one deb line for each codename, with all 4 sections, and one deb-src line for each codename, with all 4 sections.
#16 2025-11-13 03:55:03
TalionRanger117
i see, so when adding a new line the
so like this is good?
deb-src http://deb.devuan.org/merged excalibur excalibur-updates excalibur-security excalibur-proposed-updates main contrib non-free non-free-firmware
#17 2025-11-13 05:36:19
No, there can only be one codename on a line. You need a separate line for each codename.
#18 2025-11-13 16:15:42
TalionRanger117
how about this?
deb http://deb.devuan.org/merged excalibur-updates  main contrib non-free non-free-firmware
deb-src http://deb.devuan.org/merged excalibur-updates  main contrib non-free non-free-firmware
deb http://deb.devuan.org/merged excalibur-proposed-updates  main contrib non-free non-free-firmware
deb-src http://deb.devuan.org/merged excalibur-proposed-updates main contrib non-free non-free-firmware
#19 2025-11-13 16:28:28
A well defined sources.list looks like this.
No deb-src because this is only needed if you do coding and compiling code.
And no proposed-updates, not required for the normal user, and slightly risky, packages are coming in the release before testing is fully done. Only useful in very specific cases.
Backports is added but commented out. Only useful in very specific cases.
deb http://deb.devuan.org/merged excalibur-security main contrib non-free non-free-firmware
#deb http://deb.devuan.org/merged excalibur-backports main contrib non-free non-free-firmware
#20 2025-11-13 16:47:27
TalionRanger117
i see, so thats how it suppose to look. so no dev-src is needed so these are the only ones we need for
i went ahead erased the first two then added these four lines. is tehre any others i need before i save it?
#21 2025-11-13 17:10:54
tux_99
FYI, this is how it looks on my Devuan Excalibur install with backports and non-free stuff enabled, but I'm not an expert of apt so can't guarantee that it's correct:
user@vm:/etc/apt/sources.list.d$ pwd
user@vm:/etc/apt/sources.list.d$ more devuan*sources
devuan-backports.sources
# Modernized from /etc/apt/sources.list
Types: deb deb-src
URIs: http://deb.devuan.org/merged/
Suites: excalibur-backports
Components: main contrib non-free non-free-firmware
devuan.sources
Types: deb deb-src
Suites: excalibur
Types: deb deb-src
Types: deb deb-src
Suites: excalibur-updates
“Either the users control the program – or the program controls the users” Richard Stallman
#22 2025-11-13 17:21:06
TalionRanger117
Types: deb deb-src
devuan.sources
Types: deb deb-src
Suites: excalibur
Types: deb deb-src
Types: deb deb-src
do i have to hae it the same way or no?
sounds like im ok to save it.
whats next after saving it.
do i update? since sounds like im done with adding new lines.
#23 2025-11-13 17:26:45
Don't get confused by tux_99's reply. What I gave you is a correct /etc/apt/sources.list for Excalibur. The traditional format.
Now what tux_99 has posted is the new DEB822 format replacing the sources.list in the future. For the time being I would recommend to stay with the traditional format.
#24 2025-11-13 17:33:57
TalionRanger117
cool sweet, so i avoid using his an use the current format.
sounds like im all set then .
#25 2025-11-13 17:36:55
TalionRanger117
Warning: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target Packages (main/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target Translations (main/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11 (main/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11 (main/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11-icons-small (main/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11-icons (main/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11-icons-hidpi (main/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11-icons-large (main/dep11/icons-128x128.tar) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target Packages (non-free-firmware/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target Packages (non-free-firmware/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target Packages (non-free-firmware/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target Translations (non-free-firmware/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target Translations (non-free-firmware/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11 (non-free-firmware/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11 (non-free-firmware/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11-icons-small (non-free-firmware/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11-icons (non-free-firmware/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11-icons-hidpi (non-free-firmware/dep11/icons-64x64@2.tar) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
Warning: Target DEP-11-icons-large (non-free-firmware/dep11/icons-128x128.tar) is configured multiple times in /etc/apt/sources.list:5 and /etc/apt/sources.list:11
i got this error after saving it. what should i do?
