#1 2025-11-08 15:49:19
josh.viklef
[SOLVED] Excalibur 6 - cannot shut down from terminal
If I shut down from terminal (command sudo halt), it only halt the system, not shut down, ie LEDs remain lit.
How to shut down the laptop from terminal? Hardware button is working, shut down from desktop environment is working, but terminal command not.
Devuan 5 is ok.
#2 2025-11-08 17:17:07
Re: [SOLVED] Excalibur 6 - cannot shut down from terminal
Try sudo shutdown -h now
And man shutdown for details.
NB. man halt lists shutdown in the "See also" section. And look at the -p option.
#3 2025-11-09 13:19:09
josh.viklef
sudo halt -p
works.
Thanks.
#4 2025-11-09 17:28:58
After a bit of investigation I found /etc/default/halt tells halt what to do by default. That may be why it's behaviour has changed.
Found by whereis halt which said halt has *two* man pages, 1 in section 8 and 1 in section 5. man halt shows the 1 in section 8. man 5 halt mentions /etc/default/halt which is what you really wanted to know about.
#5 2025-11-11 10:30:31
stultumanto
I remember being confused by halt very early on and switching to shutdown --poweroff now and eventually just poweroff. (Confusingly, according to the manual, shutdown --halt -h or shutdown -H -h will not power down!)
