#1 2017-06-25 11:06:33
nathg
Devuan popcon in ascii
Devuan now has own popcon server and a new package 'popularity-contest'.
Use of the package will populate the Popcon statistics.
Here is the link https://popcon.devuan.org/ .
#2 2017-06-25 13:38:31
catprints
Re: Devuan popcon in ascii
Thanks for the reminder. I just enabled popcon and hope the devuan vua's find the results helpful.
"The obstacle is the path."
#3 2017-06-25 16:02:45
catprints
Can anyone speak of any security risks of enabling popcon? On stable mainly.
#4 2017-06-26 12:47:55
FOSSuser
I've not heard of any risks concerning popcon on Debian, so doubt they'll be any on Devuan.
#5 2017-06-26 15:23:28
The webmaster can see the unique ID number found in /etc/popularity-contest.conf. I don't know if that is associated with your IP address or if they are logged separately. Either way, those numbers don't get published. Whether that's a security risk or not might depend on how paranoid you are. And right now, that's not even working correctly in the desktop-live isos - everyone who uses the same iso gets the same number (there are three in total).
If you install from one of the desktop-live isos, you should delete /etc/popularity-contest.conf before running the installer. That way, you will get a unique number and we get more meaningful statistics. To correct it after installing, delete the file and then run 'dpkg-reconfigure popularity-contest'.
#6 2017-06-26 19:15:22
catprints
I have no need for great paranoia so I re-enabled. Thanks for info (and instructions) people.
