#1 2025-11-03 17:57:33
mclien
fresh install, raspi-firmware install fails
I used this image on my raspi4:
https://arm-files.devuan.org/RaspberryP … 3-0258.zip
dd onto the sdcard, running fine.
now I was trying to install the raspi firmware (as I want to use it as my video PC:
root@devuanpi:~# apt-get install raspi-firmware
Suggested packages:
  firmware-brcm80211 bluez-firmware
  raspi-firmware
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 4816 kB of archives.
After this operation, 22.8 MB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged daedalus/non-free-firmware arm64 raspi-firmware all 1.20220830+ds-1 [4816 kB]
Fetched 4816 kB in 4s (1181 kB/s)
Selecting previously unselected package raspi-firmware.
(Reading database ... 67482 files and directories currently installed.)
Preparing to unpack .../raspi-firmware_1.20220830+ds-1_all.deb ...
Unpacking raspi-firmware (1.20220830+ds-1) ...
Setting up raspi-firmware (1.20220830+ds-1) ...
Error: missing /boot/firmware, did you forget to mount it?
dpkg: error processing package raspi-firmware (--configure):
 installed raspi-firmware package post-installation script subprocess returned error exit status 1
Processing triggers for initramfs-tools (0.142+deb12u3) ...
update-initramfs: Generating /boot/initrd.img-6.1.93
Creating initrd.gz.
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned error exit status 1
 raspi-firmware
 initramfs-tools
strange thing is, that the mount point looks like this:
root@devuanpi:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/mmcblk0p1  253M   45M  209M  18% /boot/broadcom
root@devuanpi:~# cat /etc/fstab
UUID=95DC-D2E8  /boot/broadcom  vfat    defaults 0 2
So it looks a bit difficult to get a /boot/firmware here..
Is that a error in the raspi image?
#2 2025-11-03 23:57:31
RedGreen925
Re: fresh install, raspi-firmware install fails
I would go with a.
umount /dev/mmcblk0p1
mkdir /boot/firmware
mount /dev/mmcblk0p1 /boot/firmware
Install the package then go back to the broken method the image is built with by reversing the changes to mount the /boot/broadcom again. I have no idea why the images are built with breaking changes that are not compatible with the debian archive files but it is the situation we find ourselves in by using it.  I used an installer from a few days before that on my Pi4 and tried to update it to the Excalibur when it released the damn thing fails on the install of the kernel and initramfs-tools. So there is something to look forward too if ever wanting to do that. Oh if the mounting idea fails then try a symbolic link of the /boot/firmware to the /boot/broadcom.
#3 2025-11-03 23:59:37
Gnostic
The image I started with was
rpi-devuan-daedalus-6.1.93-armel-ext4-2025-10-16-0434.img
I just ran
sudo apt-get install raspi-firmware
and got these results:
Suggested packages:
  raspi-firmware
Fetched 4816 kB in 1s (4125 kB/s)
(Reading database ... 282379 files and directories currently installed.)
update-initramfs: Generating /boot/initrd.img-6.12.52
update-initramfs: Generating /boot/broadcom/initrd.gz
Is it because I ran it with sudo, or is there some critical difference in the builds?
#4 2025-11-04 00:32:05
RedGreen925
I will go with difference in the builds it fails in exactly the same way here. And I see you have a 6.12.52 kernel installed somehow that fails to install on this build too as I mentioned. How did you get that kernel installed?
root@raspi:~# apt install raspi-firmware
Suggested packages:
  raspi-firmware
Need to get 4,816 kB of archives.
Get:1 http://gnlug.org/pub/devuan/merged daedalus/non-free-firmware arm64 raspi-firmware all 1.20220830+ds-1 [4,816 kB]
Fetched 4,816 kB in 1s (4,678 kB/s)
(Reading database ... 70924 files and directories currently installed.)
rror exit status 1
What does work is my suggestion for it.
root@raspi:~# df -h
udev            3.6G     0  3.6G   0% /dev
tmpfs           782M  4.9M  777M   1% /run
/dev/sdb2        40G  2.2G   35G   6% /
tmpfs           5.0M   12K  5.0M   1% /run/lock
tmpfs           1.6G     0  1.6G   0% /dev/shm
/dev/sdb1       499M   45M  455M   9% /boot/broadcom
tmpfs           3.9G     0  3.9G   0% /tmp
/dev/sda1       3.6T  1.2T  2.4T  34% /home/zeus/rtorrent
tmpfs           782M     0  782M   0% /run/user/1000
root@raspi:~# umount /dev/sdb1
root@raspi:~# mkdir /boot/firmware
root@raspi:~# mount /dev/sdb1 /boot/firmware
Suggested packages:
  raspi-firmware
Need to get 0 B/4,816 kB of archives.
Creating initrd.gz.
root@raspi:~# cat /etc/os-release
PRETTY_NAME="Devuan GNU/Linux 5 (daedalus)"
NAME="Devuan GNU/Linux"
VERSION_ID="5"
VERSION="5 (daedalus)"
VERSION_CODENAME="daedalus"
ID=devuan
ID_LIKE=debian
HOME_URL="https://www.devuan.org/"
SUPPORT_URL="https://devuan.org/os/community"
BUG_REPORT_URL="https://bugs.devuan.org/"
root@raspi:~# uname -a
Linux raspi 6.1.93 #1 SMP PREEMPT Wed Oct 29 02:31:11 CET 2025 aarch64 GNU/Linux
#5 2025-11-04 13:14:44
c0rnelius
The Devuan images are built using a fork of: https://github.com/pyavitz/rpi-img-builder
The raspi-firmware pkg contains the boot firmware, which will conflict the kernel the builder packages, as the kernel package contains the boot firmware.
#6 2025-11-04 20:35:49
mclien
Well, I totally overlooked that method since my brain got stuck with "you can't have new dir at the same level as the mountpoint" stupid me. The link will work anyways of course.
Problem now is, that the main purpose of that raspi was watching netflix, which apparently is not possible (al least in a painless enough way) on arm architecture.
#7 2025-11-04 21:25:44
RedGreen925
If looking for a cheap small low power box and the funds are available to buy one try something like a Lenovo Think Center or the equivalent from Dell, HP ot several other brands have them too. SFF is what to search for they are more than enough to do most tasks on I got my two Think Centers with i5s, 8400t & 8500t six core, dirt cheap on Ebay for just over a $100. Wish I had went with them instead of the Pi I bought the year or two before they are much easier to deal with as they are a bog standard x86_64 computer. Easily upgraded with standard off the shelf parts nothing hanging off a dongles with flaky USB performance like a Pi has.
#8 2025-11-05 22:15:31
RedGreen925
Oh for anyone interested going to the Debian site getting the Pi images there using them for install then converting to Devuan install with the instructions from here to do it works well. You end up with a working Devuan system with an up to date kernel with all the packages able to install without problems. Not a broken system with out of date kernel and problems if you try to install a package(s) that need the /boot/firmware directory in place.
Debian files: https://raspi.debian.net/tested-images/
Trixie to Excalibur: https://www.devuan.org/os/documentation … libur.html
Works great with only couple of glitches you need the ntpsec-ntpdate package installed or you end up with the time set to 1970 the beginning of the Unix epoch on every boot. As a Pi has no hardware clock so it needs to be set on every boot. You will want the locales package installed and set to yours to get rid of them warnings and a dpkg-reconfigure tzdata done to set your time zone from the UTC it defaults to yours. Works great wish I had done that install instead of wasting all that time trying to get that pre-built broken image functioning correctly.
PRETTY_NAME="Devuan GNU/Linux 6 (excalibur)"
VERSION_ID="6"
VERSION="6 (excalibur)"
VERSION_CODENAME="excalibur"
ID=devuan
ID_LIKE=debian
Linux raspi 6.12.48+deb13-arm64 #1 SMP Debian 6.12.48-1 (2025-09-20) aarch64 GNU/Linux
root@raspi:~# apt policy linux-image-arm64
linux-image-arm64:
  Installed: 6.12.48-1
  Candidate: 6.12.48-1
  Version table:
     6.16.3-1~bpo13+1 100
        100 http://gnlug.org/pub/devuan/merged excalibur-backports/main arm64 P>
 *** 6.12.48-1 500
        500 http://gnlug.org/pub/devuan/merged excalibur-proposed-updates/main >
        500 http://gnlug.org/pub/devuan/merged excalibur-security/main arm64 Packages
        100 /var/lib/dpkg/status
     6.12.43-1 500
        500 http://gnlug.org/pub/devuan/merged excalibur/main arm64 Packages
#9 2025-11-05 22:20:45
kapqa
netflix on raspi is bit bad idea, you can get a panasonic bluray player like 185 for around 90 euro it does the better job great audio and everything and gives you bluray, even dsd playback too.
have used in on kodi - coreelec  -libreelec too, but it aint that great atm bit hassle to setup (not too much) and probably wont get a lot much better according to authors castagna
https://github.com/CastagnaIT/plugin.vi … ssues/1627
#10 2025-11-07 18:13:13
Gnostic
@RedGreen925
Re
It was from the Latest Builds page with the Trial ARM Images.
https://arm-files.devuan.org/RaspberryP … %20Builds/
Hope that helps.
#11 2025-11-08 00:16:54
RedGreen925
Hope that helps.
Well it is not in the the Pi images on that page with it you get stuck with a kernel that is roughly 60 revisions behind the Debian kernel with no way to upgrade. As I posted I got rid of that and went with a install that updates without problems, just today got the latest new kernel from the archives.
zeus@raspi:~$ uname -a
Linux raspi 6.12.57+deb13-arm64 #1 SMP Debian 6.12.57-1 (2025-11-05) aarch64 GNU/Linux
