using devuan_excalibur_6.0.0-rc1_amd64_desktop.iso i just created an excalibur+kde+sddm qemu vm.
one of the nice things about this update is that X11 can be run as non-root.
with kde/sddm it is as simple as adding "DisplayServer=x11-user" to a sddm config file.
i tested this with a debian trixie qemu vm and it works as advertised, but it does not work with excalibur.
something in the hand-off from sddm to X goes badly and all i get is a black screen with a blinking cursor.
if "DisplayServer=x11" is used, then VT number 2 is used and X starts up without issue.
in contrast, the debian vm log file shows the hand-off using VT number 1 and systemd-logind taking over.
the "X11-user" log shows VT number 7 being used. here is a snippet from that Xorg.0.log:
[ 8.128] (++) using VT number 7
[ 8.128] (II) seatd_libseat init
[ 8.128] (II) [libseat/libseat.c:73] Seat opened with backend 'seatd'
[ 8.128] (II) [libseat/backend/seatd.c:212] Enabling seat
[ 8.128] (II) seatd_libseat enable
[ 8.128] (II) seatd_libseat handled 2 events
[ 8.228] (II) seatd_libseat client activated
[ 8.228] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 8.228] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/drm/card0
[ 8.228] (II) seatd_libseat try open graphics /dev/dri/card0
[ 8.228] (II) seatd_libseat opened graphics: /dev/dri/card0 (1:14)
[ 8.230] (--) PCI:*(0@0:1:0) 1af4:1050:1af4:1100 rev 1, Mem @ 0xfa800000/8388608, 0xfcc00000/16384, 0xfea14000/4096, BIOS @ 0x????????/131072
[ 8.231] (II) LoadModule: "glx"
[ 8.231] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 8.231] (II) Module glx: vendor="X.Org Foundation"
[ 8.231] compiled for 1.21.1.16, module version = 1.0.0
[ 8.231] ABI class: X.Org Server Extension, version 10.0
[ 8.231] (==) Matched modesetting as autoconfigured driver 0
[ 8.231] (==) Matched fbdev as autoconfigured driver 1
[ 8.231] (==) Matched vesa as autoconfigured driver 2
[ 8.231] (==) Assigned the driver to the xf86ConfigLayout
[ 8.231] (II) LoadModule: "modesetting"
[ 8.231] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 8.231] (II) Module modesetting: vendor="X.Org Foundation"
[ 8.231] compiled for 1.21.1.16, module version = 1.21.1
[ 8.231] Module class: X.Org Video Driver
[ 8.231] ABI class: X.Org Video Driver, version 25.2
[ 8.231] (II) LoadModule: "fbdev"
[ 8.231] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 8.231] (II) Module fbdev: vendor="X.Org Foundation"
[ 8.231] compiled for 1.21.1.3, module version = 0.5.0
[ 8.231] (II) LoadModule: "vesa"
[ 8.231] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 8.231] (II) Module vesa: vendor="X.Org Foundation"
[ 8.231] compiled for 1.21.1.15, module version = 2.6.0
[ 8.231] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 8.231] (II) FBDEV: driver for framebuffer: fbdev
[ 8.231] (II) VESA: driver for VESA chipsets: vesa
[ 8.231] (EE)
Fatal server error:
[ 8.231] (EE) xf86OpenConsole: Cannot open virtual console 7 (Permission denied)
[ 8.231] (EE)
[ 8.231] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 8.231] (EE) Please also check the log file at "/home/xyz/.local/share/xorg/Xorg.1.log" for additional information.
[ 8.231] (EE)
[ 8.231] (II) seatd_libseat finish
[ 8.232] (EE) Server terminated with error (1). Closing log file.as you can see there is a permission problem with VT number 7. it is not clear to me if the problem is due
to using VT7 instead of VT2 or if VT7 is the correct choice but permissions are such that non-root user cannot
access VT7.
how can i debug this further?
It used to be that the user running Xorg has to be owner of the associated tty, i.e. /dev/tty7 in your case. How does it compare with /dev/tty2 permissions in the working use case?
Though I don't know anything about sddm or KDE.
i try to read all the new posts in an attempt to continue my education
and so i did a search and figured i might as well include it here for the future addicted autodidacts
https://start.duckduckgo.com/lite/?q=excalibur+kde+sddm+qemu+vm
also since i did it...
https://start.duckduckgo.com/lite/?q="sddm"
https://linuxconfig.org/how-to-customize-the-sddm-display-manager-on-linux
another intriguing thought occurred regarding vt handoffs since just yesterday i was reviewing grub entries on a dual boot machine with windows eleven and xubuntu 24.04.3 and saw something similar(that i don't believe i had ever witnessed before iirc)...anywho, enjoy!
more since i just experienced it(again, ha!)...
i get significantly different search results by using/not-using quotation-marks(double quote marks actually as seen above with "sddm") as well as searching with/without browser add-ons such as noscript, privacy badger, ublock origin, etc. activated(just thought i would add that as it seems to be relevant to the encouragement of others regarding current-day internet searches/searching/etc), as always - ymmv.
after a couple of days chasing this problem and not finding anything, i gave up and destroyed the vm.
re-creating the vm from the same iso worked as designed and sddm was able to create a non-root X11 session.
just to be sure, i went thu the install six more times, varying the steps to move from the default Xwayland session to the x11-user session. in all cases the non-root X11 session was created.
so i am at a loss to explain what happened on that first, buggy install
¯\_(ツ)_/¯
my apologies for the noise
on a side note, i did go down the sddm rabbit-hole looking for possible clues to this error, but could not find anything like what i encountered. but, there are multiple bug reports of 'black screen, blinking cursor'. this must be what happens when X11 fails at startup.
sddm is quite the mess and the maintainers are moving to wayland-only, no X11, as well as deprecating sysv init support to better align with systemd behavior. this is despite pleas from multiple people, both linux and bsd camps. as an old fart and an outsider to coding these days, i cannot fathom how a "simple" display manager has become such a bloated, tangled mess. geez
so excalibur may well be the last version of devuan to support KDE desktop
so more reason to get lightdm rootless x11 working, mind you it is not an easy task even if it looks like so...
https://github.com/canonical/lightdm/pull/127
if anyone figures the code to get the displayfd method working or is able to at least find which display managers works in that manner to be able to port the code onto lightdm that would be the ideal solution as it is always easier to just yank existing code from someone else than writing it up from nothing...
another idea would be to build a display manager from the ground up that can just be "lazy" and try to route the x11 starting through the xserver-command from the xserver-xorg-legacy package to force the xorg server into starting with dropped priviledges.
so after seeing that bunsenlabs is considering greetd i got into looking at it some, greetd is a small daemon, written in rust (for good or for bad that's not the important part here), needs greeters to display a login
about the greeters most of them target wayland and require a wayland compositor to run, however the way greeters are structured it should be possible to craft a greeter that runs on x11 it would just need to launch x11 as part of it's initialization, that aside rn there are some TUI greeters that do not require wayland AND support rootless x11 (ar at least seem to, have not tested them yet) https://github.com/apognu/tuigreet tuigreet which is written in rust and is packaged on debian 13, there also is https://github.com/Nomadcxx/sysc-greet sysc-greet which is written in go and has a fancier presentation (tho it may need a wayland compositor for such fancier stuff, not sure yet).
tho at the time bunsenlabs is still sticking with lightdm so getting the lightdm rootless x11 session working would still be useful...
i am using Excalibur KDE X11 on my laptop; let me know if it can be of help; it seems to function fine, no major drawback after upgrade noticed so far.
(don't know what non-root X11 session should mean, but login function just fine).
hi @kapqa, thanks for the offer of help, but i cannot reproduce the issue that i reported in the original post.
the non-root X11 session is a new thing in the latest sddm, prompted by wayland behavior, i gather, and i wanted to get it working. sddm X11 sessions were always owned by root. a non-root X11 session is desirable based on the principle of least privilege, but is no biggie if it did not work. mostly, i was curious to try it.
https://en.wikipedia.org/wiki/Principle … _privilege
FYI, this is what i see when the non-root X11 session is running:
> ps -u -p $(pgrep X) | less
USER PID %CPU %MEM VSZ RSS TT S STARTED TIME COMMAND
xyz 1533 0.7 3.9 936652 160576 ? S 14:06:57 01:44:12 /usr/lib/xorg/Xorg -verbose 3 -nolisten tcp -background none -seat seat0 -noreset -keeptty -novtswitch -auth /run/user/1000/xauth_eMzpPV -displayfd 13 vt1Offline
I got this on a kde install of excalibur I did yesterday.
root 1421 0.6 4.0 880628 88088 ? Ssl 17:43 0:01 /usr/lib/xorg/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_yIsirg -noreset -displayfd 16I have /etc/sddm/wayland-session and /etc/sddm/Xsession and neither one looks like a config file to me.
Indeed it is, and VT allocation is a particularly unstable, unpredictable, racy nightmare. All development effort to sort this out is, predictably, focused on systemd+wayland.
If I read the wind right, sddm as an independent project is on borrowed time. The KDE folks have been getting tired of slow progress and constant borkage in what is nominally the KDE greeter for a while, and a fork to bring development into KDE proper is already underway.
oops ...
my bad. the sddm config file i used was of my own making. the directory used is /etc/sddm.conf.d/
the "displayserver" keyword tells sddm what you want, either "x11" or "x11-user"
this is what my file contains:
[Autologin]
Session=plasmax11
User=xyz
[General]
InputMethod=
##DisplayServer=x11i can toggle between the two by changing the displayserver value and rebooting.
note that inputmethod=<blank> does not work, the virtual keyboard remains.
also, autologin works as expected when using "x11" mode, but does not work when using "x11-user" mode.
in "x11-user" mode, a logout takes you to console login as sddm has died.
with a root X11 session this is what i get:
root 1718 1.7 3.1 650296 126456 ? S 18:52:34 00:23:27 /usr/lib/xorg/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_OdxMnf -noreset -displayfd 16Offline
good to hear. may kde do better. i am ready to jump ship to anything else. even the TUI greeters @EDX-0 mentions.
Going to a virtual terminal logging in to edit the file to make the switch then a pkill X should be enough to get it done by killing off the X server and respawing it with the new value being read at its start up.
