#1 2025-10-07 18:43:55
kapqa
how renew DHCP lease?
hello ,
on an older computer have installed devuan 5.0 and it function beautifully,
maybe it was update from devuan 3.0 and then 4.0 , but one thing seem missing,
since the network icon is missing some "action".
now when i was switching router, the network was not coming back up;
so i wanted to "release" dhcp to renew the lease, but it would not find it then menu.
please show on how to remedy the situation;
i did the other terminal command
sudo ifup eth0 down
sudo ifup eth0 up
to no avail;
thank you very much
https://imgur.com/ysaB2ob.png
#2 2025-10-07 22:09:18
Re: how renew DHCP lease?
e.g.: /etc/init.d/networking restart
#3 2025-10-07 22:29:36
...or with ifupdown it would be
sudo ifdown eth0
sudo ifup eth0
#4 2025-10-08 00:07:43
Perhaps the DHCP options are on the ipv4 settings tab?
#5 2025-10-08 11:48:51
kapqa
thanks , hte command felt wrong to me ,
maybe "sudo ifdown eth0" is the proper one;
however it would be nice if it could be done from taskbar etc.
https://imgur.com/cfRYLmO.png
it seems there is no toggle to release the dhcp;
maybe only possible to "disable" first +save  and then renew by automatic dhcp +save.
https://ibb.co/JRWQF4RS
