#1 2025-10-03 06:37:39
evanescente~ondine
sayonara: undefined symbol in libsqlite.so
Setting up libsqlite3-0:amd64 (3.46.1-7) ...
Processing triggers for libc-bin (2.41-12) ...
~> sayonara
[07:35:59] : InstanceChecker: Check for another instance...
[07:36:00] : InstanceChecker: No response from other instance. Ignoring other instance.
sayonara: symbol lookup error: /usr/lib/x86_64-linux-gnu/qt5/plugins/sqldrivers/libqsqlite.so: undefined symbol: sqlite3_column_table_name16
No idea what that means. System's Excalibur and fresh, untainted. I'm trying to find a music player on linux that is not FUCKED, and I did not succeed so far. MPD and all its clients is always buggy and the interfaces nonsensical, cmus can't see into .cue files anymore, most programs can't, Audacious's buggy as hell, etc etc.
And there's the occasional names that just won't start, like this one. I tried with devuan's package, or the latest, official one.
(edit: I used the appimage. Can't read .cue or .ape files either. Still, we should investigate what went wrong)
#2 2025-10-03 20:26:42
igorzwx
Re: sayonara: undefined symbol in libsqlite.so
The best place to discuss appimages is, perhaps, Ubuntu newbie forum.
Audacious is easy to compile
_https://dev1galaxy.org/viewtopic.php?id=7214
#3 2025-10-03 20:29:22
g4sra
As excalibur is not released and still in testing...
when it breaks you get to keep all the pieces
And that is the *only* source of packages you should install from if you don't want system wide breakage (whats wrong with vlc ?)
#4 2025-10-03 20:38:11
igorzwx
the only source?
Have you already tried to compile anything on Devuan?
#5 2025-10-03 21:19:55
does moc work for you?
use the command mocp to run it.
In a terminal emulator that is
#6 2025-10-03 21:21:13
Curious as to what your definition of "not F***ed" is OP? Not that I disagree, I don't like most of them either, that's why I made my own.
As g4sra mentioned, Excalibur has not been declared stable by Devuan, you're liable to run into multiple issues.
