#1 2025-10-01 11:41:56
sysv_penguin
[SOLVED] removing adjfontsize (LARGER FONTS/SMALLER FONTS)
Hello. Which package is related to these files:
/usr/share/applications/LARGER_FONTS.desktop
/usr/share/applications/SMALLER_FONTS.desktop
adjfontsize
#2 2025-10-01 12:33:36
RedGreen925
Re: [SOLVED] removing adjfontsize (LARGER FONTS/SMALLER FONTS)
It would be some third party package you installed.
zeus@9600k:~$ apt-file search /usr/share/applications/LARGER_FONTS.desktop
zeus@9600k:~$ apt-file search /usr/share/applications/SMALLER_FONTS.desktop
zeus@9600k:~$ apt-file search adjfontsize
As you can see apt-file finds no mention of them in any of the repositories I have listed with a freshly update search cache. I include all of them in my sources file so they do not come from Devuan sources.
#3 2025-10-01 12:47:40
The name of the package is fontsnaps. It's one of the few native devuan packages, but it doesn't have "devuan" in the version string because only forked packages get that.
$ dpkg -S /usr/share/applications/LARGER_FONTS.desktop
fontsnaps: /usr/share/applications/LARGER_FONTS.desktop
#4 2025-10-01 17:55:02
sysv_penguin
Thank you all for taking your time. 🧡
Indeed the package was fontsnaps. Running sudo apt purge fontsnaps got rid of it.
