#1 Yesterday 23:41:58
SHADUS_TAIN
New info about "Temporary failure resolving 'deb.devuan.org'"
Greetings...
This is a fresh install on the following hardware:
Lenovo Thinkpad X1 Carbon 5th Gen
CPU: Intel Core i7-7600U Processor (2C/4T) @ 2.8 GHz 4 MB Cache
RAM: 16GB
Storage: 2TB NVMe
GFX: Intel HD Graphics 620
Using: devuan_daedalus_5.0.1_amd64_netinstall.iso
init: runit
DE: LXQt
I run the installer and the install concludes successfully.  As others have reported, after the install I reboot, login, open a shell and...
$ sudo apt update
[sudo] password for USER:
Ign:1 http://deb.devuan.org/merged daedalus InRelease
Ign:2 http://deb.devuan.org/merged daedalus-security InRelease
Ign:3 http://deb.devuan.org/merged daedalus-updates InRelease
Err:1 http://deb.devuan.org/merged daedalus InRelease
Err:2 http://deb.devuan.org/merged daedalus-security InRelease
Err:3 http://deb.devuan.org/merged daedalus-updates InRelease
All packages are up to date.
W: Failed to fetch http://deb.devuan.org/merged/dists/daedalus/InRelease  Temporary failure resolving 'deb.devuan.org'
W: Failed to fetch http://deb.devuan.org/merged/dists/daedalus-security/InRelease  Temporary failure resolving 'deb.devuan.org'
W: Failed to fetch http://deb.devuan.org/merged/dists/daedalus-updates/InRelease  Temporary failure resolving 'deb.devuan.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
So let us get some information...
$ ping -c 3 google.com
PING google.com (142.250.191.110) 56(84) bytes of data.
64 bytes from ord38s28-in-f14.1e100.net (142.250.191.110): icmp_seq=1 ttl=118 time=81.4 ms
64 bytes from ord38s28-in-f14.1e100.net (142.250.191.110): icmp_seq=2 ttl=118 time=81.5 ms
64 bytes from ord38s28-in-f14.1e100.net (142.250.191.110): icmp_seq=3 ttl=118 time=134 ms
--- google.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 81.396/98.831/133.589/24.577 ms
Okay, that works...
$ ping -c 3 deb.devuan.org
ping: deb.devuan.org: Temporary failure in name resolution
That's odd...
$ nslookup deb.devuan.org
Server:         192.168.254.254
Address:        192.168.254.254#53
Non-authoritative answer:
deb.devuan.org  canonical name = deb.rr.devuan.org.
Address: 152.53.121.155
Address: 131.188.12.211
Address: 147.78.194.22
Address: 195.85.215.180
Address: 103.146.168.12
Address: 95.216.15.86
Address: 200.236.31.1
Address: 46.4.50.2
Address: 130.225.254.116
Address: 141.84.43.19
Address: 190.64.49.124
Address: 160.16.137.156
Address: 65.108.230.29
Address: 185.178.192.43
Address: 114.34.81.84
Address: 94.16.114.15
Address: 185.236.240.103
Address: 5.161.180.234
Address: 67.219.104.166
Address: 23.169.200.138
Address: 147.229.176.19
Address: 54.246.199.172
Address: 148.72.159.76
Address: 134.199.205.102
Address: 185.32.21.88
;; Truncated, retrying in TCP mode.
Address: 2a0a:4cc0:c0:4676:4242:4242:4242:4242
Address: 2001:638:a000:1021:21::1
Address: 2a0a:e5c0:10:3::6eeb
Address: 2a01:9e40::180
Address: 2407:b6c0::12
Address: 2a01:4f9:2a:fa9::2
Address: 2801:82:80ff:8000::2
Address: 2a01:4f8:140:1102:2b76:955d:b48f:bdf3
Address: 2001:878:346::116
Address: 2001:4ca0:4300::1:19
Address: 2800:a8:c001::a
Address: 2001:e42:102:1704:160:16:137:156
Address: 2a01:4f9:1a:aa0c::29
Address: 2a03:4000:28:24c::
Address: 2a0d:eb00:8006::acab
Address: 2a01:4ff:f0:dd3a::1
Address: 2401:c080:2000:229e:4b70:fe82:36ed:f788
Address: 2602:817:2000:401::138
Address: 2001:67c:1220:8b0::93e5:b013
Address: 2604:a880:5:1::154:0
$ cat /etc/resolv.conf
# Generated by Connection Manager
nameserver ::1
nameserver 127.0.0.1
I also run a Debian machine so I know this resolv.conf is not correct.  Also begs a question (questions at end of post).  After running Connman UI Setup...
domain home
search home
nameserver 192.168.254.254
PING deb.rr.devuan.org (152.53.121.155) 56(84) bytes of data.
64 bytes from v2202501232017310025.powersrv.de (152.53.121.155): icmp_seq=1 ttl=55 time=133 ms
64 bytes from v2202501232017310025.powersrv.de (152.53.121.155): icmp_seq=2 ttl=55 time=132 ms
64 bytes from v2202501232017310025.powersrv.de (152.53.121.155): icmp_seq=3 ttl=55 time=132 ms
--- deb.rr.devuan.org ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 132.197/132.428/132.599/0.169 ms
$ sudo apt update
Get:1 http://deb.devuan.org/merged daedalus InRelease [43.0 kB]
Get:2 http://deb.devuan.org/merged daedalus-security InRelease [33.2 kB]
Get:3 http://deb.devuan.org/merged daedalus-updates InRelease [33.4 kB]
Fetched 110 kB in 6s (18.4 kB/s)
Everything seems to work, right?  After a reboot /etc/resolv.conf reverts back to...
nameserver ::1
What the?... Odd.  So I start poking about, not running Connman UI Setup.  After awhile /etc/resolv.conf gets properly updated...
domain home
search home
So let's see if the system eventually updates resolv.conf on it's own, while limiting our interaction with it...
[clipping the redundant output to 'cut to the chase']
third boot...
$ uptime
 20:05:19 up  1:13,  1 user,  load average: 0.00, 0.00, 0.00
nameserver ::1
$ uptime
 20:41:56 up  1:49,  1 user,  load average: 0.00, 0.00, 0.00
domain home
search home
fourth boot...
$ uptime
 15:52:57 up  1:51,  1 user,  load average: 0.01, 0.01, 0.00
nameserver ::1
$ uptime
 16:05:46 up  2:04,  1 user,  load average: 0.00, 0.00, 0.00
domain home
search home
fifth boot...
$ uptime
 18:08:40 up  1:41,  2 users,  load average: 0.00, 0.00, 0.00
nameserver ::1
$ uptime
 18:12:51 up  1:45,  2 users,  load average: 0.04, 0.03, 0.00
domain home
search home
sixth boot...
$ uptime
 14:44:37 up  1:23,  1 user,  load average: 0.00, 0.00, 0.00
nameserver ::1
$ uptime
 14:57:17 up  1:35,  1 user,  load average: 0.00, 0.00, 0.00
domain home
search home
...and on and on...
So the result of this little experiment begs several questions...
Why is Devuan taking over an hour and thrity minutes to properly update /etc/resolv.conf instead of at boot time?
Is there some setting(s) that didn't get properly setup during the install?
Is this an issue with runit and/or Connection Manager?
Why does google.com resolve but not deb.devuan.org with a bad /etc/resolv.conf?
Why is there such a variance in the time needed to update /etc/resolv.conf?
Is there some setting(s) that can be changed so that /etc/resolv.conf gets properly updated at boot time?
How did this get past testing?
This has never been an issue with any other distro I've worked with (Mint, Debian, Artix, AntiX, Fedora, etc.)  The goal is for Devuan to properly update /etc/resolv.conf at boot like every other distro.  I came to Devuan looking for stability and init freedom.  Hopefully this sheds some light onto the actual cause of the issue people have been having.  Let's work together to fix this issue... ideas?  Thanks.
I'm the tall dark stranger your mother warned you about. There's too much info about me to put into a little box. If you'd like to know something, then look at my homepage or just ask.
