#1 2025-09-17 22:05:44
dave
[SOLVED] LibreOffice install failing (daedalus ARM64)
An up to date system Raspbery Pi-4 4Gig ARM64 system:
~ sudo apt-get install libreoffice
libreoffice : Depends: libreoffice-base but it is not going to be installed
               Depends: libreoffice-calc but it is not going to be installed
               Depends: libreoffice-core (= 4:7.4.7-1+deb12u9) but it is not installable
               Depends: libreoffice-draw but it is not going to be installed
               Depends: libreoffice-impress but it is not going to be installed
               Depends: libreoffice-math but it is not going to be installed
               Depends: libreoffice-report-builder-bin but it is not going to be installed
               Depends: libreoffice-writer but it is not going to be installed
Of note: Depends: libreoffice-core (= 4:7.4.7-1+deb12u9) but it is not installable
~ sudo apt-get download libreoffice-core
E: Can't select candidate version from package libreoffice-core as it has no candidate
Of note:  If I attempt to install via 'Excalibur' (testing), I get a similar error:
Depends: libreoffice-core (= 4:25.2.3-2+deb13u2) but it is not installable
Ditto for Ceres (unstable):
Depends: libreoffice-core (= 4:25.8.1-1) but it is not installable
It would seem that  libreoffice-core is missing from the devuan repositories.
Dare I try using the debian repositories directly or is systemd going to get in the way?
/dave
#2 2025-09-17 22:46:28
RedGreen925
Re: [SOLVED] LibreOffice install failing (daedalus ARM64)
It will install here on both my excalibur x86_64 system and Debian bookworm on my Pi4 8gb.
root@9600k:~# apt -s install libreoffice
Installing:
  libreoffice
Installing dependencies:
  ant                            libneon27t64
  ant-optional                   libnice10
  ca-certificates-java           libnumbertext-1.0-0
  coinor-libcbc3.1               libnumbertext-data
  coinor-libcgl1                 libodfgen-0.1-1
  coinor-libclp1                 libonnx1t64
  coinor-libcoinmp0              libonnxruntime1.21
  coinor-libcoinutils3v5         libopenh264-8
  coinor-libosi1v5               libopenni2-0
  default-jre                    liborcus-0.18-0
  default-jre-headless           liborcus-parser-0.18-0
  firebird-utils                 libpagemaker-0.0-0
  firebird4.0-common             libpentaho-reporting-flow-engine-java
  firebird4.0-common-doc         libpixie-java
  firebird4.0-server-core        libpq5
  firebird4.0-utils              libpthreadpool0
  fonts-crosextra-caladea        libqxp-0.0-0
  fonts-crosextra-carlito        libraptor2-0
  fonts-dejavu                   librasqal3t64
  fonts-dejavu-extra             librdf0t64
  fonts-linuxlibertine           libre2-11
  fonts-opensymbol               libreoffice-base
  fonts-sil-gentium              libreoffice-base-core
  fonts-sil-gentium-basic        libreoffice-base-drivers
  gstreamer1.0-libav             libreoffice-calc
  gstreamer1.0-plugins-bad       libreoffice-common
  gstreamer1.0-plugins-ugly      libreoffice-core
  java-common                    libreoffice-draw
  java-wrappers                  libreoffice-impress
  libabw-0.1-1                   libreoffice-java-common
  libactivation-java             libreoffice-math
  libapache-pom-java             libreoffice-nlpsolver
  libatk-wrapper-java            libreoffice-report-builder
  libatk-wrapper-java-jni        libreoffice-report-builder-bin
  libavtp0                       libreoffice-script-provider-bsh
  libbase-java                   libreoffice-script-provider-js
  libbatik-java                  libreoffice-script-provider-python
  libbcmail-java                 libreoffice-sdbc-firebird
  libbcpkix-java                 libreoffice-sdbc-hsqldb
  libbcprov-java                 libreoffice-sdbc-mysql
  libbcutil-java                 libreoffice-sdbc-postgresql
  libboost-iostreams1.83.0       libreoffice-style-colibre
  libboost-locale1.83.0          libreoffice-uiconfig-base
  libbox2d2                      libreoffice-uiconfig-calc
  libbsh-java                    libreoffice-uiconfig-common
  libcdr-0.1-1                   libreoffice-uiconfig-draw
  libclucene-contribs1t64        libreoffice-uiconfig-impress
  libclucene-core1t64            libreoffice-uiconfig-math
  libcmis-0.6-6t64               libreoffice-uiconfig-report-builder
  libcolamd3                     libreoffice-uiconfig-writer
  libcommons-collections3-java   libreoffice-wiki-publisher
  libcommons-io-java             libreoffice-writer
  libcommons-logging-java        librepository-java
  libcommons-parent-java         librevenge-0.0-0
  libcpuinfo0                    librhino-java
  libdnnl3.6                     libsac-java
  libe-book-0.1-1                libserializer-java
  libehcache-java                libservlet-api-java
  libel-api-java                 libservlet3.1-java
  libeot0                        libsidplay1v5
  libepubgen-0.1-1               libsoundtouch1
  libetonyek-0.1-1               libspandsp2t64
  libexttextcat-2.0-0            libsrtp2-1
  libexttextcat-data             libstaroffice-0.0-0
  libfbclient2                   libsuitesparseconfig7
  libflute-java                  libuno-cppu3t64
  libfonts-java                  libuno-cppuhelpergcc3-3t64
  libformula-java                libuno-purpenvhelpergcc3-3t64
  libfreehand-0.1-1              libuno-sal3t64
  libgssdp-1.6-0                 libuno-salhelpergcc3-3t64
  libgstreamer-plugins-bad1.0-0  libunoloader-java
  libgupnp-1.6-0                 libvisio-0.1-1
  libgupnp-igd-1.6-0             libvo-aacenc0
  libharfbuzz-icu0               libvo-amrwbenc0
  libhsqldb1.8.0-java            libwebsocket-api-java
  libitext-java                  libwildmidi2
  libjaxp1.3-java                libwpd-0.10-10
  libjcommon-java                libwpg-0.3-3
  libjsp-api-java                libwps-0.4-4
  liblangtag-common              libxml-commons-external-java
  liblangtag1                    libxml-java
  liblayout-java                 libxmlgraphics-commons-java
  liblibreoffice-java            libxmlsec1t64-nss
  libloader-java                 libxnnpack0.20241108
  liblrdf0                       libyajl2
  libltc11                       libzbar0t64
  libmail-java                   libzmf-0.0-0
  libmhash2                      libzxcvbn0
  libmjpegutils-2.1-0t64         openjdk-21-jre
  libmpeg2encpp-2.1-0t64         openjdk-21-jre-headless
  libmplex2-2.1-0t64             python3-uno
  libmspub-0.1-1                 uno-libs-private
  libmwaw-0.3-3                  ure
  libmythes-1.2-0                ure-java
snip ...
Summary:
  Upgrading: 0, Installing: 189, Removing: 0, Not Upgrading: 0
Inst libreoffice-style-colibre (4:25.2.3-2+deb13u2 Devuan:6.0/testing [all])
Inst libreoffice-uiconfig-common (4:25.2.3-2+deb13u2 Devuan:6.0/testing [all])
Inst libuno-sal3t64 (4:25.2.3-2+deb13u2 Devuan:6.0/testing [amd64])
The bookworm output from my Pi4 8gb whose files should be in the daedalus repositories.
root@raspi:~# apt -s install libreoffice
  adwaita-icon-theme alsa-topology-conf alsa-ucm-conf ant ant-optional
  at-spi2-common at-spi2-core ca-certificates-java coinor-libcbc3
  coinor-libcgl1 coinor-libclp1 coinor-libcoinmp1v5 coinor-libcoinutils3v5
  coinor-libosi1v5 cpp cpp-12 dconf-gsettings-backend dconf-service
  default-jre default-jre-headless dictionaries-common emacsen-common
  firebird3.0-common firebird3.0-common-doc firebird3.0-server-core
  firebird3.0-utils fontconfig fontconfig-config fonts-crosextra-caladea
  fonts-crosextra-carlito fonts-dejavu fonts-dejavu-core fonts-dejavu-extra
  fonts-droid-fallback fonts-liberation fonts-liberation2 fonts-linuxlibertine
  fonts-noto-core fonts-noto-extra fonts-noto-mono fonts-noto-ui-core
  fonts-opensymbol fonts-sil-gentium fonts-sil-gentium-basic fonts-urw-base35
  gcc-12-base ghostscript glib-networking glib-networking-common
  glib-networking-services gsettings-desktop-schemas gsfonts gstreamer1.0-gl
  gstreamer1.0-libav gstreamer1.0-plugins-bad gstreamer1.0-plugins-base
  gstreamer1.0-plugins-good gstreamer1.0-plugins-ugly gstreamer1.0-x
  gtk-update-icon-cache hicolor-icon-theme hunspell-en-us imagemagick-6-common
  iso-codes java-common java-wrappers liba52-0.7.4 libaa1 libaacs0
  libabsl20220623 libabw-0.1-1 libactivation-java libaom3 libapache-pom-java
  libasound2 libasound2-data libass9 libasyncns0 libatk-bridge2.0-0
  libatk-wrapper-java libatk-wrapper-java-jni libatk1.0-0 libatspi2.0-0
  libauthen-sasl-perl libavc1394-0 libavcodec59 libavfilter8 libavformat59
  libavutil57 libbase-java libbatik-java libbcmail-java libbcpkix-java
  libbcprov-java libbcutil-java libbdplus0 libblas3 libbluray2
  libboost-filesystem1.74.0 libboost-locale1.74.0 libbox2d2 libbs2b0
  libbsh-java libcaca0 libcairo-gobject2 libcairo2 libcdio19 libcdparanoia0
  libcdr-0.1-1 libchromaprint1 libcjson1 libclone-perl libclucene-contribs1v5
  libclucene-core1v5 libcodec2-1.0 libcolamd2 libcolord2
  libcommons-collections3-java libcommons-io-java libcommons-logging-java
  libcommons-parent-java libdata-dump-perl libdatrie1 libdav1d6 libdc1394-25
  libdca0 libdconf1 libde265-0 libdecor-0-0 libdecor-0-plugin-1-cairo
  libdeflate0 libdirectfb-1.7-7 libdjvulibre-text libdjvulibre21
  libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libdv4
  libdvdnav4 libdvdread8 libdw1 libe-book-0.1-1 libegl-mesa0 libegl1
  libehcache-java libel-api-java libencode-locale-perl libeot0 libepoxy0
  libepubgen-0.1-1 libetonyek-0.1-1 libexttextcat-2.0-0 libexttextcat-data
  libfaad2 libfbclient2 libfftw3-double3 libfile-basedir-perl
  libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl
  libflac12 libflite1 libfluidsynth3 libflute-java libfont-afm-perl
  libfontconfig1 libfontenc1 libfonts-java libformula-java libfreeaptx0
  libfreehand-0.1-1 libfreetype6 libfribidi0 libgail-common libgail18 libgbm1
  libgcc-s1 libgdk-pixbuf-2.0-0 libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common
  libgfortran5 libgif7 libgl1 libgl1-mesa-dri libglapi-mesa libgles2 libglvnd0
  libglx-mesa0 libglx0 libgme0 libgomp1 libgpgmepp6 libgraphene-1.0-0
  libgraphite2-3 libgs-common libgs10 libgs10-common libgsm1 libgssdp-1.6-0
  libgstreamer-gl1.0-0 libgstreamer-plugins-bad1.0-0
  libgstreamer-plugins-base1.0-0 libgstreamer1.0-0 libgtk-3-0 libgtk-3-bin
  libgtk-3-common libgtk2.0-0 libgtk2.0-bin libgtk2.0-common libgudev-1.0-0
  libgupnp-1.6-0 libgupnp-igd-1.0-4 libharfbuzz-icu0 libharfbuzz0b libheif1
  libhsqldb1.8.0-java libhtml-form-perl libhtml-format-perl
  libhtml-parser-perl libhtml-tagset-perl libhtml-tree-perl
  libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl
  libhttp-message-perl libhttp-negotiate-perl libhunspell-1.7-0 libhwy1
  libhyphen0 libib-util libice6 libidn12 libiec61883-0 libijs-0.35
  libimath-3-1-29 libinstpatch-1.0-2 libio-html-perl libio-socket-ssl-perl
  libio-stringy-perl libipc-system-simple-perl libisl23 libitext-java
  libjack-jackd2-0 libjaxp1.3-java libjbig0 libjbig2dec0 libjcommon-java
  libjpeg62-turbo libjson-glib-1.0-0 libjson-glib-1.0-common libjsp-api-java
  libjxl0.7 libjxr-tools libjxr0 libkate1 liblangtag-common liblangtag1
  liblapack3 liblayout-java liblcms2-2 libldacbt-enc2 liblerc4
  liblibreoffice-java liblilv-0-0 libllvm15 libloader-java liblqr-1-0 liblrdf0
  libltc11 libltdl7 liblwp-mediatypes-perl liblwp-protocol-https-perl
  libmagickcore-6.q16-6 libmagickcore-6.q16-6-extra libmagickwand-6.q16-6
  libmail-java libmailtools-perl libmariadb3 libmbedcrypto7 libmhash2
  libmjpegutils-2.1-0 libmodplug1 libmp3lame0 libmpc3 libmpcdec6 libmpeg2-4
  libmpeg2encpp-2.1-0 libmpfr6 libmpg123-0 libmplex2-2.1-0 libmspub-0.1-1
  libmwaw-0.3-3 libmysofa1 libmythes-1.2-0 libneon27 libnet-dbus-perl
  libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl libnice10 libnorm1
  libnspr4 libnss3 libnuma1 libnumbertext-1.0-0 libnumbertext-data
  libodfgen-0.1-1 libogg0 libopenal-data libopenal1 libopencore-amrnb0
  libopencore-amrwb0 libopenexr-3-1-30 libopenh264-7 libopenjp2-7 libopenmpt0
  libopenni2-0 libopus0 liborc-0.4-0 liborcus-0.17-0 liborcus-parser-0.17-0
  libpagemaker-0.0-0 libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0
  libpaper-utils libpaper1 libpentaho-reporting-flow-engine-java libpgm-5.3-0
  libpixie-java libpixman-1-0 libplacebo208 libpng16-16 libpocketsphinx3
  libpoppler126 libpostproc56 libpq5 libproxy1v5 libpulse0 libqrencode4
  libqxp-0.0-0 librabbitmq4 libraptor2-0 librasqal3 librav1e0 libraw1394-11
  librdf0 libregexp-ipv6-perl libreoffice-base libreoffice-base-core
  libreoffice-base-drivers libreoffice-calc libreoffice-common
  libreoffice-core libreoffice-draw libreoffice-impress
  libreoffice-java-common libreoffice-math libreoffice-nlpsolver
  libreoffice-report-builder libreoffice-report-builder-bin
  libreoffice-script-provider-bsh libreoffice-script-provider-js
  libreoffice-script-provider-python libreoffice-sdbc-firebird
  libreoffice-sdbc-hsqldb libreoffice-sdbc-mysql libreoffice-sdbc-postgresql
  libreoffice-style-colibre libreoffice-wiki-publisher libreoffice-writer
  librepository-java librevenge-0.0-0 librist4 librsvg2-2 librsvg2-common
  librubberband2 libsac-java libsamplerate0 libsbc1 libsdl2-2.0-0
  libsensors-config libsensors5 libserd-0-0 libserializer-java
  libservlet-api-java libservlet3.1-java libshine3 libshout3 libsidplay1v5
  libsm6 libsnappy1v5 libsndfile1 libsndio7.0 libsodium23 libsord-0-0
  libsoundtouch1 libsoup-3.0-0 libsoup-3.0-common libsoup2.4-1
  libsoup2.4-common libsoxr0 libspandsp2 libspeex1 libsphinxbase3
  libsratom-0-0 libsrt1.5-gnutls libsrtp2-1 libssh-gcrypt-4
  libstaroffice-0.0-0 libstdc++6 libsuitesparseconfig5 libsvtav1enc1
  libswresample4 libswscale6 libtag1v5 libtag1v5-vanilla libthai-data libthai0
  libtheora0 libtie-ixhash-perl libtiff6 libtimedate-perl libtommath1
  libtry-tiny-perl libtwolame0 libudfread0 libuno-cppu3
  libuno-cppuhelpergcc3-3 libuno-purpenvhelpergcc3-3 libuno-sal3
  libuno-salhelpergcc3-3 libunoloader-java libunwind8 liburi-perl libusb-1.0-0
  libv4l-0 libv4lconvert0 libva-drm2 libva-x11-2 libva2 libvdpau-va-gl1
  libvdpau1 libvidstab1.1 libvisio-0.1-1 libvisual-0.4-0 libvo-aacenc0
  libvo-amrwbenc0 libvorbis0a libvorbisenc2 libvorbisfile3 libvpx7 libvulkan1
  libwavpack1 libwayland-client0 libwayland-cursor0 libwayland-egl1
  libwayland-server0 libwebp7 libwebpdemux2 libwebpmux3
  libwebrtc-audio-processing1 libwebsocket-api-java libwildmidi2
  libwmflite-0.2-7 libwpd-0.10-10 libwpg-0.3-3 libwps-0.4-4 libwww-perl
  libwww-robotrules-perl libx11-protocol-perl libx11-xcb1 libx264-164
  libx265-199 libxaw7 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0
  libxcb-randr0 libxcb-render0 libxcb-shape0 libxcb-shm0 libxcb-sync1
  libxcb-xfixes0 libxcb-xkb1 libxcomposite1 libxcursor1 libxdamage1 libxfixes3
  libxft2 libxi6 libxinerama1 libxkbcommon-x11-0 libxkbcommon0 libxkbfile1
  libxml-commons-external-java libxml-java libxml-parser-perl libxml-twig-perl
  libxml-xpathengine-perl libxmlgraphics-commons-java libxmlsec1
  libxmlsec1-nss libxmu6 libxpm4 libxrandr2 libxrender1 libxshmfence1
  libxslt1.1 libxss1 libxt6 libxtst6 libxv1 libxvidcore4 libxxf86dga1
  libxxf86vm1 libyajl2 libz3-4 libzbar0 libzimg2 libzmf-0.0-0 libzmq5
  libzvbi-common libzvbi0 libzxing2 lp-solve mariadb-common mesa-va-drivers
  mesa-vdpau-drivers mesa-vulkan-drivers mysql-common ocl-icd-libopencl1
  openjdk-17-jre openjdk-17-jre-headless perl-openssl-defaults
  pocketsphinx-en-us poppler-data python3-uno timgm6mb-soundfont
  uno-libs-private ure ure-java va-driver-all vdpau-driver-all x11-common
  x11-utils x11-xserver-utils xdg-utils xfonts-encodings xfonts-utils xkb-data
  zutty
Suggested packages:
  ant-doc default-jdk | java-compiler | java-sdk antlr javacc junit junit4
  jython libbcel-java libbsf-java libcommons-net-java libjdepend-java
  libjsch-java liblog4j1.2-java liboro-java libregexp-java libxalan2-java
snip...
  zutty
  gcc-12-base libgcc-s1 libstdc++6
3 upgraded, 553 newly installed, 0 to remove and 93 not upgraded.
Inst fonts-droid-fallback (1:6.0.1r16-1.1 Debian:12.12/oldstable [all])
It will basically install a desktop to get it but will do it. I would take a look at the policy command to see the version available to you as you might have to use them in a command to install the packages needed.
root@raspi:~# apt policy libreoffice libreoffice-base libreoffice-calc libreoffice-core libreoffice-draw libreoffice-impress  libreoffice-math libreoffice-report-builder-bin libreoffice-writer libreoffice-core
libreoffice:
  Installed: (none)
  Candidate: 4:7.4.7-1+deb12u9
  Version table:
     4:25.2.3-2+deb13u2~bpo12+1 100
        100 http://ftp.ca.debian.org/debian bookworm-backports/main arm64 Packages
     4:7.4.7-1+deb12u9 500
        500 http://ftp.ca.debian.org/debian bookworm/main arm64 Packages
     4:7.4.7-1+deb12u8 500
        500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
libreoffice-base:
  Installed: (none)
  Version table:
libreoffice-calc:
  Installed: (none)
  Version table:
libreoffice-core:
  Installed: (none)
  Version table:
libreoffice-draw:
  Installed: (none)
  Version table:
libreoffice-impress:
  Installed: (none)
  Version table:
libreoffice-math:
  Installed: (none)
  Version table:
libreoffice-report-builder-bin:
  Installed: (none)
  Version table:
libreoffice-writer:
  Installed: (none)
  Version table:
libreoffice-core:
  Installed: (none)
  Version table:
Here you can see it wants to install the version 4:7.4.7-1+deb12u9 of the packages from the main repository. It can be told to get the version 4:25.2.3-2+deb13u2~bpo12+1 from the -backports and systemd will have nothing to do with it both you and I would be using systend less systems. Me because I removed that junk from my Debian install you because you use distribution without it by default.
root@raspi:~# apt policy systemd
systemd:
  Installed: (none)
  Candidate: (none)
  Version table:
     254.26-1~bpo12+1 -1
     252.39-1~deb12u1 -1
     252.38-1~deb12u1 -1
#3 2025-09-20 12:50:58
dave
Sorry @RedGreen925, but it seems the debian/devuan repositories for libreoffice are broken.  I tried installing directly from a Debian/Bookworm sources.list and still no-go.
Have you tried a (re)installation?  The libreoffice-core "4:7.4.7-1+deb12u9" is currently missing from the repositories.
~$ apt policy libreoffice  libreoffice-core
libreoffice:
  Installed: (none)
  Version table:
        500 http://pkgmaster.devuan.org/merged daedalus/main arm64 Packages
        500 http://pkgmaster.devuan.org/merged daedalus-security/main arm64 Packages
libreoffice-core:
  Installed: (none)
  Candidate: (none)
  Version table:
     4:7.4.7-1+deb12u9 -30000
     4:7.4.7-1+deb12u8 -30000
Note that libreoffice-core is "Candidate: (none)" with a weight of "-30000" using both the Debian and Devuan sources.
#4 2025-09-20 14:00:20
Have you checked your package pinning"
#5 2025-09-29 23:56:13
dino.mesina
root@luna:~# LANG=EN apt install libreoffice
Solving dependencies... Error!
Unsatisfied dependencies:
 libreoffice : Depends: libreoffice-calc but it is not installable
               Depends: libreoffice-draw but it is not installable
               Depends: libreoffice-impress but it is not installable
               Depends: libreoffice-math but it is not installable
               Depends: libreoffice-writer but it is not installable
               Depends: python3-uno (>= 4.4.0~beta2) but it is not installable
               Recommends: fonts-liberation2 but it is not going to be installed
               Recommends: libreoffice-nlpsolver but it is not installable
               Recommends: libreoffice-report-builder but it is not installable
               Recommends: libreoffice-script-provider-bsh but it is not installable
               Recommends: libreoffice-script-provider-js but it is not installable
               Recommends: libreoffice-script-provider-python but it is not installable
               Recommends: libreoffice-sdbc-mysql but it is not installable
               Recommends: libreoffice-sdbc-postgresql but it is not installable
               Recommends: libreoffice-wiki-publisher but it is not installable
               Recommends: libreoffice-java-common (>= 4:7.4.7~) but it is not installable
 libreoffice-base : Depends: libreoffice-core (= 4:7.4.7-1+deb12u9) but it is not installable
                    Recommends: libreoffice-writer but it is not installable
 libreoffice-base-core : Depends: libreoffice-core-nogui (= 4:7.4.7-1+deb12u9) but it is not installable or
 libreoffice-base-drivers : Depends: libreoffice-core-nogui but it is not installable or
                                     libreoffice-core but it is not installable
                            Recommends: libreoffice-sdbc-hsqldb but it is not installable
                            Recommends: libreoffice-sdbc-firebird but it is not installable
 libreoffice-common : Conflicts: libreoffice-base (< 4:25.2.1~rc1-3~) but 4:7.4.7-1+deb12u9 is to be installed
                      Recommends: python3-uno but it is not installable
 libreoffice-report-builder-bin : Depends: libreoffice-core but it is not installable
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
   Unable to satisfy dependencies. Reached two conflicting decisions:
   1. libreoffice:amd64=4:7.4.7-1+deb12u9 is selected for install
   2. libreoffice:amd64 Depends python3-uno (>= 4.4.0~beta2)
      but none of the choices are installable:
      - python3-uno:amd64 Depends python3 (< 3.12)
        - python3:amd64=3.11.2-1+b1 is not selected for install
sad
Also docker-ce is not possible to install...
root@luna:~# LANG=EN apt install docker-ce
 iptables : Depends: libxtables12 (= 1.8.9-2) but 1.8.11-2 is to be installed
   1. docker-ce:amd64=5:28.4.0-1~debian.12~bookworm is selected for install
   2. docker-ce:amd64 Depends iptables
      - iptables:amd64 Depends libxtables12 (= 1.8.9-2)
        - libxtables12:amd64=1.8.9-2 is not selected for install
There is a lot of problems with dependecies in daedalus?
#6 2025-09-30 00:28:04
You seem to have a mix of sources; e.g.
    docker-ce is not a package in either daedalus or excalibur;
    iptables=1.8.9-2 is in daedalus;
    libxtables12=1.8.11-2 is in excalibur
It's quite easy to mix sources.list points from anywhere, and usually doing so ends up with confusion about packages and what is where and why.
The whole idea behind a debian (and devuan) "release" is to offer a collection of software that works together. There is no promise that packages of different releases, or "foreign packages" for that matter, work together.
#7 2025-09-30 13:16:44
kapqa
tried this today and could download libreoffice regularly
downloaded latest arm64 for daedalus here
arm-files.devuan.org (latest raspberry pi builds however)
#8 2025-09-30 21:09:38
dino.mesina
I have upgraded to excalibur and now there is no problems by dependencies
Thank you
#9 2025-10-01 02:08:26
dave
@ralph.ronnquist:  Thanx...
A 'grep -r office /etc/apt/*' returned:
/etc/apt/preferences.d/apt-listbugs:Package: libreoffice-core
So it looks like the un-downloadability is a self-inflicted 'bug' ??
Moving the report-bug file out of the way (or deleting it) gets me:
sudo apt-get  install libreoffice-writer libreoffice-math libreoffice-calc
  ... Package and download stuff snipped ...
Fetched 43.4 MB in 11s (3,804 kB/s)
Retrieving bug reports... Done
Parsing Found/Fixed information... Done
grave bugs of libreoffice-core (→ 4:7.4.7-1+deb12u9) <Forwarded>
 b1 - #935182 - Concurrent file open on the same host results file deletion
Summary:
 libreoffice-core(1 bug)
Are you sure you want to install/upgrade the above packages? [Y/n/?/...] y
Extracting templates from packages: 100%
So I said 'Y', it installed, and now I just have to worry about Bug #935182 "Concurrent file open on the same host results file deletion". :-[
Thanx  ( I think... )
Now: Where did this "apt-listbugs" package come from?  Looks like it was auto-installed on my recent upgrade from chim to daed...
Sigh.
/dave
