#1 2025-09-04 09:58:23
IdeaFix
[SOLVED] tomcat9 version in chimaera
9.0.107 - https://packages.debian.org/bullseye/tomcat9 (bullseye - 9.0.43-2~deb11u10, bullseye security - 9.0.107-0+deb11u1)
9.0.43 - https://pkginfo.devuan.org/cgi-bin/pack … 3+devuan10
why? Is it in chimaera-security?
#2 2025-09-04 14:45:25
Re: [SOLVED] tomcat9 version in chimaera
No, it's not in -security. Note the "devuan" in the version string. It's a forked package and hasn't been updated yet. I don't know if the maintainer is working on it. Maybe a bug report for tomcat9 in devuan would help. (email method is easy)
https://bugs.devuan.org/Reporting.html
#3 2025-09-04 17:50:04
IdeaFix
Thank you. I tried to make a report and send a copy to maintainer.
Unfortunately, my major packages, for example tomcat and nodejs are broken, outdated and/or misconfigured in Devuan.
#4 2025-09-08 07:43:51
IdeaFix
https://pkginfo.devuan.org/cgi-bin/poli … 9&x=submit
May be it is siolved.... i need to check
