#1 2025-09-02 11:43:23
kapqa
Music Playback File 24/192
Hello ,
i have received a DAC and would like to use it for playback with the PC;
have it connected via USB port to the Computer; it supposedly is already connected in USB 2.0 Mode (vs. USB 1.0).
However, if i playback a track in 24/192, the sampling does not change.
the file is from here
https://msbtechnology.com/support/bit-perfect-testing/
Do i need to manually change the setup or why would pipewire/pulseaudio and friends not pick up the proper sampling rate?
Thanks.
aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
default
    Playback/recording through the PulseAudio sound server
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
hw:CARD=HDMI,DEV=3
    HDA ATI HDMI, EV2360
    Direct hardware device without any conversions
hw:CARD=HDMI,DEV=7
    HDA ATI HDMI, EA231WU
hw:CARD=HDMI,DEV=8
    HDA ATI HDMI, HDMI 2
hw:CARD=HDMI,DEV=9
    HDA ATI HDMI, HDMI 3
plughw:CARD=HDMI,DEV=3
    Hardware device with all software conversions
plughw:CARD=HDMI,DEV=7
plughw:CARD=HDMI,DEV=8
plughw:CARD=HDMI,DEV=9
hdmi:CARD=HDMI,DEV=0
    HDMI Audio Output
hdmi:CARD=HDMI,DEV=1
    HDMI Audio Output
hdmi:CARD=HDMI,DEV=2
    HDMI Audio Output
hdmi:CARD=HDMI,DEV=3
    HDMI Audio Output
dmix:CARD=HDMI,DEV=3
    Direct sample mixing device
dmix:CARD=HDMI,DEV=7
dmix:CARD=HDMI,DEV=8
dmix:CARD=HDMI,DEV=9
usbstream:CARD=HDMI
    HDA ATI HDMI
    USB Stream Output
hw:CARD=Generic,DEV=3
    HD-Audio Generic, HDMI 0
hw:CARD=Generic,DEV=7
    HD-Audio Generic, HDMI 1
plughw:CARD=Generic,DEV=3
plughw:CARD=Generic,DEV=7
hdmi:CARD=Generic,DEV=0
    HDMI Audio Output
hdmi:CARD=Generic,DEV=1
    HDMI Audio Output
dmix:CARD=Generic,DEV=3
dmix:CARD=Generic,DEV=7
usbstream:CARD=Generic
    HD-Audio Generic
    USB Stream Output
hw:CARD=Generic_1,DEV=0
    HD-Audio Generic, ALC897 Analog
hw:CARD=Generic_1,DEV=1
    HD-Audio Generic, ALC897 Digital
plughw:CARD=Generic_1,DEV=0
plughw:CARD=Generic_1,DEV=1
sysdefault:CARD=Generic_1
    Default Audio Device
front:CARD=Generic_1,DEV=0
    Front output / input
surround21:CARD=Generic_1,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic_1,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic_1,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic_1,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic_1,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic_1,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Generic_1,DEV=0
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Generic_1,DEV=0
dmix:CARD=Generic_1,DEV=1
usbstream:CARD=Generic_1
    HD-Audio Generic
    USB Stream Output
hw:CARD=C20,DEV=0
    Cambridge Audio USB Audio 2.0, USB Audio
plughw:CARD=C20,DEV=0
sysdefault:CARD=C20
front:CARD=C20,DEV=0
surround21:CARD=C20,DEV=0
surround40:CARD=C20,DEV=0
surround41:CARD=C20,DEV=0
surround50:CARD=C20,DEV=0
surround51:CARD=C20,DEV=0
surround71:CARD=C20,DEV=0
iec958:CARD=C20,DEV=0
dmix:CARD=C20,DEV=0
usbstream:CARD=C20
    USB Stream Output
