#1 2025-08-31 01:45:33
For those who like open bioses,
I think its common news probably now, but I will say it anyways,
T480/T480s are now supported by libreboot.
Those are 8th gen intel laptops. And if you use me clean on it in combination, which libreboot dev Leah has as a default when its flashed correctly.
Then its a VERY fast libreboot laptop.
The fastest I know of anyhow that isn't a chromebook and maybe in general. smile
If anyone loves such tech, I recommend you to buy one.   I pondered such an idea recently.
Favourite operating systems: Hyperbola Devuan OpenBSD
#2 2025-09-01 08:31:45
Re: For those who like open bioses,
with reference to libreboot, this should probably be a required document:
https://libreboot.org/freedom-status.html
#3 2025-09-02 01:31:34
@stargate-sg1-cheyenne-mtn Yes, but its still far better than the stock bios with intel me rammed completely open.
wink
#4 2025-09-02 05:31:58
SteveM
And here I thought my 11th gen Intel running Coreboot was getting old.
#5 2025-09-02 10:20:57
@SteveM not at all, but I am curious what hardware you have.
#6 2025-09-03 10:48:52
Codalunga
I'm a happy user of a StarLabs StarBook. I believe it's a 6th generation one, no complaints whatsoever. And the bios update process is pretty straightforward; I've had it for a couple of years and the laptop improved with each update. Highly recommended! big_smile
#7 2025-09-03 19:25:05
T480 is a definite improvement over T430 and X230 too. It uses very little electricity from what i see. And at 5.0 load it barely feels hot on my chest.
