Apparently they removed the option from the settings menu a while back. Preferences settings in about:config don't do anything. So I put a "lock" option on the package via the package manager, and hope that will do the trick.
What is the "correct" way to disable firefox auto-update?
# apt-mark hold firefoxOffline
isn't that equivalent to "lock" (in synaptic package manger)?
Most likely.
I don't "gui" system maintenance and hardly know synaptic. A more correct first reply might have been "Yes, this should do the trick.".
Thanks, delgado.
Librewolf better,. firefox has all sorts of crap enabled by default including pocket.
If you wish to be humbled, try to exalt yourself long term If you wish to be exalted, try to humble yourself long term
Unless something has changed very recently, The ESR version of Firefox included with Debian/Devuan never "auto-updates" the way mainline Firefox does. It used to display a message that said updates were being "managed by your organization," but this confused people, so they removed it.
Putting a hold on the package with apt-mark means it will never be updated, not even manually. For an application exposed to the Internet such as a web browser, this can be very dangerous. You won't get patches even for serious vulnerabilities.
@stultumanto I agree with you on that. holding back firefox updates won't solve this problem. Librewolf is the best answer I believe.
