#1 2025-08-12 21:08:20
geki
daedalus: iwlwifi firmware missing for linux-image-6.12.38+deb12-amd64
Hi all,
I upgraded the kernel to 6.12.38+deb12-amd64, bootet into it and the wi-fi was offline. Then, I bootet the old kernel 6.1 again and wi-fi was online. dmesg log shows that the firmware is not found. Any ideas how to solve this issue?
# head -n1 /var/log/dmesg.0
[    0.000000] Linux version 6.12.38+deb12-amd64 (debian-kernel@lists.debian.org) (x86_64-linux-gnu-gcc-12 (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC Debian 6.12.38-1~bpo12+1 (2025-07-27)
# grep QuZ-a0-hr-b0 /var/log/dmesg.0
[    2.351570] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-QuZ-a0-hr-b0-77.ucode (-2)
[    2.351583] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-QuZ-a0-hr-b0-77.ucode (-2)
[    2.351592] iwlwifi 0000:00:14.3: firmware: failed to load iwlwifi-QuZ-a0-hr-b0-77.ucode (-2)
[    2.351593] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-77.ucode failed with error -2
[    2.351617] iwlwifi 0000:00:14.3: iwlwifi-QuZ-a0-hr-b0-77 is required
# dpkg -L firmware-iwlwifi | grep QuZ-a0-hr-b0
/lib/firmware/iwlwifi-QuZ-a0-hr-b0-50.ucode
/lib/firmware/iwlwifi-QuZ-a0-hr-b0-59.ucode
/lib/firmware/iwlwifi-QuZ-a0-hr-b0-72.ucode
# lspci | grep Wi-Fi
00:14.3 Network controller: Intel Corporation Wi-Fi 6 AX201 (rev 20)
#2 2025-08-12 22:13:23
RedGreen925
Re: daedalus: iwlwifi firmware missing for linux-image-6.12.38+deb12-amd64
Since you are using a package that is one generation release on from the default you are using, I would check to make sure you have the iwlwifi packages from the same source as it installed too. The daedalus-backports should have the firmware-iwlwifi need to match that kernel looking at the Debian packages that should be there in it.
https://packages.debian.org/search?keyw … ection=all
At least that is what it would give me if needed running the same kernel on excalibur.
zeus@9600k:~$ apt policy firmware-iwlwifi
firmware-iwlwifi:
  Installed: (none)
  Candidate: 20250410-2
  Version table:
     20250410-2 950
        950 http://de.deb.devuan.org/merged excalibur/non-free-firmware amd64 P>
zeus@9600k:~$ uname -r
6.12.38+deb13-amd64
Edit: and I would make certain you have backup network connection that works before installing the wifi package and risking having none if only method of connecting fails with that package too.
#3 2025-08-13 00:53:25
I don't see 'bpo' in the kernel version. It looks like it's the excalibur kernel. Please post your /etc/apt/sources.list and any other sources apt is using.
I just booted excalibur with that kernel and firmware-iwlwifi is working correctly. (version 20250410-2)
#4 2025-08-13 17:03:12
geki
I am on it cache looks like this:
$ apt-cache policy firmware-iwlwifi
firmware-iwlwifi:
  Installiert:           20230210-5
  Installationskandidat: 20230210-5
  Versionstabelle:
     20250410-2~bpo12+1 100
        100 https://ftp.fau.de/devuan/merged daedalus-backports/non-free-firmware amd64 Packages
        100 https://ftp.fau.de/devuan/merged daedalus-backports/non-free-firmware i386 Packages
 *** 20230210-5 500
        500 https://ftp.fau.de/devuan/merged daedalus/non-free-firmware amd64 Packages
        500 https://ftp.fau.de/devuan/merged daedalus/non-free-firmware i386 Packages
        100 /var/lib/dpkg/status
Downloaded both firmware debs. I guess that helps already switching kernels.
