#1 2025-08-08 00:49:14
pcalvert
Driverless printing
Back in late 2023, when I was setting up the Brother laser printer that I bought back in 2016, I was surprised and delighted to learn that I wouldn't have to follow some tedious driver installation procedure (like I had done previously) because the printer is AirPrint compatible.
To learn more, see:
CUPSDriverlessPrinting
https://wiki.debian.org/CUPSDriverlessPrinting
Driverless printing
https://wiki.gentoo.org/wiki/Driverless_printing
See also:
CUPSQuickPrintQueues
https://wiki.debian.org/CUPSQuickPrintQueues
Troubleshooting tip:
The CUPS graphical interface might confusingly show multiple IPP Everywhere entries. The trademarked one should work.
Another one is called Luxxle.
#2 2025-10-06 15:29:06
kapqa
Re: Driverless printing
found that this has downsides and upsides;
have one ricoh printer with ethernet (geljet) that previously was not easily available outside of windows/server/macos and now is;
as downside,
my epson printer was ethernet/wifi/usb connectivity, and even when installing the proper epson driver, would not show the driver available in cups; unless i would de-install the package "ipp-usb" and then magically the usb-driver would show up in cups;
it might not be big issue for most, but with original driver, the command over usb get sent like more instant, whereas over ipp-usb there is bit of delay.
