#1 2025-08-06 17:27:04
Micronaut
How to lookup printer drivers in CUPS?
My printers are all ancient and suffering various problems. Rather than continue to struggle to keep them running, I am thinking of buying a newer printer. The one I favor, the Brother HL-L2400D is especially appealing for NOT having fancy networking options that just make it hackable. Wifi printers??? No. Just no.
But on researching it, one of the things I have learned is that there is no MacOS driver for this printer. That normally wouldn't be a concern since I don't own Apple hardware, except I thought Apple used the CUPS system like all other *nix based OSes? Do they? How would I check if there is a CUPS driver for this printer before buying one and plugging it into a computer running some flavor of Linux? I would hope there is a reference somewhere that can be checked?
#2 2025-08-06 17:56:16
Dutch_Master
Re: How to lookup printer drivers in CUPS?
Here's the Brother support site:
https://support.brother.com/g/b/product … content=dl
Select your region, model, follow instructions and you should be able to get a download link to the installer. That's just a script selecting the correct drivers for your device and installing them.
FIY: my last 3 printers (actually MFC units) were all Brother products due to their excellent Linux support. Current machine: MFC-J5740DW (no WiFi configured, so no access from outside tongue )
#3 2025-08-06 19:16:35
Brother HL-L3280CDW here
#4 2025-08-06 19:36:28
I am using a Kyocera P6230 LAN printer with a PPD supplied by Kyocera. Before that I owned a FS-5100DN.
#5 2025-08-07 08:17:26
Andre4freedom
Brother_MFC_J5340DW working perfectly well here.
No drivers installed at all.
Devuan5 (Daedalus) with CUPS and IPP
implicitclass://Brother_MFC_J5340DW/
Brother MFC-J5340DW, driverless, cups-filters 1.28.17
Just connect the printer to the local network, set it up, and off you go.
Chances are that your chosen model will work that way.
#6 2025-08-08 00:54:59
pcalvert
Choose a printer that is AirPrint-compatible, and no driver installation will even be necessary.
See:
Driverless printing
https://dev1galaxy.org/viewtopic.php?id=7339
Another one is called Luxxle.
