So yad in it's man page has as one of it's options, a modifier to use css directly in creating a dialog.
--css=[string] , where string can be either a link to a css file, or css commands directly as the string.
But for the life of me I can't figure out the syntax it wants, and there's zero documentation to be found about it other than the one mention in the man page.
I have tried a lot of different combos, direct, quoted, curly brackets+conventional markup, etc. etc. and nothing seems to work. I'm sure it's something simple, but it's escaping me at the moment. I don't want to use an outboard css file for this, it's just one command I need to work, using the line-height property to put some space between lines of text in a paragraph.
Anybody have a clue?
Solved, couldn't get the css to work inline, but pango did the trick!
