#1 2017-06-18 23:33:13
Somewhat Reticent
Star (Morbius*)
Xfce, Openbox, Fluxbox, JWM, i3 and netinst in amd64, and JWM in i386.
One I tried came with apulse, the Adwaita-Dark gtk3 theme, and connman-ui.
Interesting.
A "live-build demonstration"; no support recommendation indicated at SourceForge.
(edit:  Does it need some Thunar plugins re-installed?  Certainly a repository /etc/apt/sources.list update!)
Has anyone tried refractasnapshot on one of these?  (add Yad .deb from ibiblio or SF for *-gui)
*(Not the DebIan-based Genesis and Livinia ISOs.)
How's this for a sources.list ?
deb http://auto.mirror.devuan.org/merged/ jessie main contrib
# deb-src http://auto.mirror.devuan.org/merged/ jessie main contrib
# deb http://auto.mirror.devuan.org/merged/ jessie-proposed main contrib
# deb-src http://auto.mirror.devuan.org/merged/ jessie-proposed main contrib
# deb http://auto.mirror.devuan.org/merged/ jessie-security main contrib
# deb-src http://auto.mirror.devuan.org/merged/ jessie-security main contrib
# deb http://auto.mirror.devuan.org/merged/ jessie-proposed-security main contrib
# deb-src http://auto.mirror.devuan.org/merged/ jessie-proposed-security main contrib
# deb http://auto.mirror.devuan.org/merged/ jessie-updates main contrib
# deb-src http://auto.mirror.devuan.org/merged/ jessie-updates main contrib
# deb http://auto.mirror.devuan.org/merged/ jessie-proposed-updates main contrib
# deb-src http://auto.mirror.devuan.org/merged/ jessie-proposed-updates main contrib
# deb http://auto.mirror.devuan.org/merged/ jessie-backports main contrib
# deb-src http://auto.mirror.devuan.org/merged/ jessie-backports main contrib
# deb http://auto.mirror.devuan.org/merged/ jessie-proposed-backports main contrib
# deb-src http://auto.mirror.devuan.org/merged/ jessie-proposed-backports main contrib
# deb http://auto.mirror.devuan.org/devuan/ experimental main
# deb-src http://auto.mirror.devuan.org/devuan/ experimental main
# deb http://auto.mirror.devuan.org/merged/ jessie non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie non-free
# deb http://auto.mirror.devuan.org/merged/ jessie-proposed non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie-proposed non-free
# deb http://auto.mirror.devuan.org/merged/ jessie-security non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie-security non-free
# deb http://auto.mirror.devuan.org/merged/ jessie-proposed-security non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie-proposed-security non-free
# deb http://auto.mirror.devuan.org/merged/ jessie-updates non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie-updates non-free
# deb http://auto.mirror.devuan.org/merged/ jessie-proposed-updates non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie-proposed-updates non-free
# deb http://auto.mirror.devuan.org/merged/ jessie-backports non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie-backports non-free
# deb http://auto.mirror.devuan.org/merged/ jessie-proposed-backports non-free
# deb-src http://auto.mirror.devuan.org/merged/ jessie-proposed-backports non-free
# deb http://www.deb-multimedia.org/ jessie main
# deb-src http://www.deb-multimedia.org/ jessie main
# deb https://linux-libre.fsfla.org/pub/linux-libre/freesh/ freesh main
# deb-src https://linux-libre.fsfla.org/pub/linux-libre/freesh/ freesh main
(Where's a one-raised-eyebrow smiley when I want one? o_O? /:-)? )
#2 2017-06-19 09:59:15
FOSSuser
Re: Star (Morbius*)
I guess it lets you know what is available, as all but the first are commented out. smile
#3 2017-06-19 16:50:57
Re: Star (Morbius*)
refractasnapshot and installer should work with any debian/devuan-based system. Ubuntu-based distros can be a little trickier, since some versions don't have live-config-sysvinit in the repo. (e.g. mint18)
#4 2017-10-10 22:58:58
Somewhat Reticent
Re: Star (Morbius*)
Just wondering why gPartEd won't allow mounting of drives/partitions ("greyed-out") - even for sudo/su?
Enabling automount didn't have the expected effect…
Where can I find documentation on this old version of mpv? Looks like all the files in /usr/share/doc/mpv are size=0.
Does the upstream website actually keep old documentation available?
(note - running live.)
#5 2017-10-11 11:02:57
Re: Star (Morbius*)
Check the other dirs in /usr/share/doc. It's possible that it was all removed to save space. My doc/mpv is full of files that have some content. A reinstall of mpv should fix it.
I don't know about gparted. What you describe is different from the other permission/authentication problems reported for gparted, but it might be related. (consolekit, policykit-1, policykit-1-gnome, libpam-ck-connector, udisks...)  If synaptic is installed, does that work ok?
#6 2017-10-11 16:49:33
Somewhat Reticent
Re: Star (Morbius*)
Thanks!  Re-install appears to have restored doc files (and yes, synaptic is working).
