#1 2017-06-18 18:27:27
spartrekus
Changing the Keyboard Layout of the tty terminal of Devuan?
Hello,
I have done the classical dpkg-reconfigure keyboard-configuration, and I did set the desired layout for keyboard (Fr).
After I logout the session, and I login again on the same tty and visibly the change made is not working, still us keyboard layout of the tty.
Would you have possibly improvement here on the method employed?
thank  you in advance / merci
#2 2017-06-18 18:41:52
Re: Changing the Keyboard Layout of the tty terminal of Devuan?
Edit /etc/default/keyboard and change us to fr.
See 'man keyboard' for more.
