I use an old 32-bit Dell PP05XB laptop to lead services at my Church which worked well using KDE in Chimaera. However, after upgrading last week to daedalus I found today I was unable to use the projector and KDE froze during start-up. All is normal with no second monitor plugged in.
At home, with a second monitor plugged in I get a black screen on the secondary monitor and a squashed and truncated desktop on the primary with no correspondence between the cursor and the detected mouse position.
# inxi -F
X11 connection rejected because of wrong authentication.
System:
Host: master7 Kernel: 6.1.0-37-686 arch: i686 bits: 32 Console: pty pts/1
Distro: Devuan GNU/Linux 5 (daedalus)
Machine:
Type: Portable System: Dell product: MP061 v: N/A serial: B5Q952J
Mobo: Dell model: 0FF049 serial: .B5Q952J.CN129616325580. BIOS: Dell
v: A01 date: 03/17/2006
Battery:
ID-1: BAT0 charge: 44.6 Wh (100.0%) condition: 44.6/79.9 Wh (55.8%)
CPU:
Info: dual core model: Intel T2300 bits: 32 type: MCP cache: L2: 2 MiB
Speed (MHz): avg: 1000 min/max: 1000/1667 cores: 1: 1000 2: 1000
Graphics:
Device-1: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics
driver: i915 v: kernel
Display: x11 server: X.org v: 1.21.1.7 with: Xwayland v: 22.1.9 driver: X:
loaded: intel unloaded: fbdev,modesetting,vesa dri: i915 gpu: i915
resolution: 1: 1920x1200 2: 1280x1024
API: OpenGL Message: GL data unavailable for root.
Audio:
Device-1: Intel NM10/ICH7 Family High Definition Audio driver: snd_hda_intel
API: ALSA v: k6.1.0-37-686 status: kernel-api
Server-1: PulseAudio v: 16.1 status: active (root, process)
Network:
Device-1: Broadcom BCM4401-B0 100Base-TX driver: b44
Device-2: Intel PRO/Wireless 3945ABG [Golan] Network driver: iwl3945
IF: wlan0 state: up mac: 00:13:02:19:7f:58
IF-ID-1: eth0 state: down mac: 00:14:22:f3:ac:f4
Bluetooth:
Device-1: Dell Wireless 350 Bluetooth type: USB driver: btusb
Report: hciconfig ID: hci0 rfk-id: 1 state: down bt-service: running
rfk-block: hardware: no software: no address: 00:16:41:48:E4:34
Drives:
Local Storage: total: 91.76 GiB used: 13.36 GiB (14.6%)
ID-1: /dev/sda vendor: Fujitsu model: MHV2100BH size: 91.76 GiB
Partition:
ID-1: / size: 27.33 GiB used: 10.73 GiB (39.3%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 61.57 GiB used: 2.63 GiB (4.3%) fs: ext4 dev: /dev/sda6
Swap:
ID-1: swap-1 type: partition size: 976 MiB used: 0 KiB (0.0%) dev: /dev/sda5
Sensors:
System Temperatures: cpu: 37.0 C mobo: N/A sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2410 fan-2: 0
Info:
Processes: 152 Uptime: 25m Memory: 1.96 GiB used: 845 MiB (42.2%)
Shell: Bash inxi: 3.3.26dmesg:
[ 0.000000] Linux version 6.1.0-37-686 (debian-kernel@lists.debian.org) (gcc-12 (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC Debian 6.1.140-1 (2025-05-22)
[ 0.000000] Disabled fast string operations
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007f6d33ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007f6d3400-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000f0006fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f0008000-0x00000000f000bfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed9ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee0ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: Dell Inc. MP061 /0FF049, BIOS A01 03/17/2006
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 1662.462 MHz processor
[ 0.001752] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001759] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001771] last_pfn = 0x7f6d3 max_arch_pfn = 0x100000
[ 0.002610] x86/PAT: PAT not supported by the CPU.
[ 0.003058] x86/PAT: Configuration [0-7]: WB WT UC- UC WB WT UC- UC
[ 0.013352] initial memory mapped: [mem 0x00000000-0x173fffff]
[ 0.013418] RAMDISK: [mem 0x3509b000-0x36844fff]
[ 0.013427] ACPI: Early table checksum verification disabled
[ 0.013433] ACPI: RSDP 0x00000000000FC370 000014 (v00 DELL )
[ 0.013444] ACPI: RSDT 0x000000007F6D3A96 000038 (v01 DELL M07 27D60311 ASL 00000061)
[ 0.013457] ACPI: FACP 0x000000007F6D4800 000074 (v01 DELL M07 27D60311 ASL 00000061)
[ 0.013469] ACPI: DSDT 0x000000007F6D5400 003AF3 (v01 INT430 SYSFexxx 00001001 INTL 20050624)
[ 0.013479] ACPI: FACS 0x000000007F6E3C00 000040
[ 0.013486] ACPI: APIC 0x000000007F6D5000 000068 (v01 DELL M07 27D60311 ASL 00000047)
[ 0.013494] ACPI: MCFG 0x000000007F6D4FC0 00003E (v16 DELL M07 27D60311 ASL 00000061)
[ 0.013502] ACPI: BOOT 0x000000007F6D4BC0 000028 (v01 DELL M07 27D60311 ASL 00000061)
[ 0.013511] ACPI: SSDT 0x000000007F6D3ACE 0004DC (v01 PmRef CpuPm 00003000 INTL 20050624)
[ 0.013518] ACPI: Reserving FACP table memory at [mem 0x7f6d4800-0x7f6d4873]
[ 0.013521] ACPI: Reserving DSDT table memory at [mem 0x7f6d5400-0x7f6d8ef2]
[ 0.013524] ACPI: Reserving FACS table memory at [mem 0x7f6e3c00-0x7f6e3c3f]
[ 0.013526] ACPI: Reserving APIC table memory at [mem 0x7f6d5000-0x7f6d5067]
[ 0.013529] ACPI: Reserving MCFG table memory at [mem 0x7f6d4fc0-0x7f6d4ffd]
[ 0.013532] ACPI: Reserving BOOT table memory at [mem 0x7f6d4bc0-0x7f6d4be7]
[ 0.013534] ACPI: Reserving SSDT table memory at [mem 0x7f6d3ace-0x7f6d3fa9]
[ 0.013574] 1162MB HIGHMEM available.
[ 0.013576] 875MB LOWMEM available.
[ 0.013578] mapped low ram: 0 - 36bfe000
[ 0.013580] low ram: 0 - 36bfe000
[ 0.013592] Zone ranges:
[ 0.013593] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.013598] Normal [mem 0x0000000001000000-0x0000000036bfdfff]
[ 0.013602] HighMem [mem 0x0000000036bfe000-0x000000007f6d2fff]
[ 0.013605] Movable zone start for each node
[ 0.013606] Early memory node ranges
[ 0.013608] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.013611] node 0: [mem 0x0000000000100000-0x000000007f6d2fff]
[ 0.013614] Initmem setup node 0 [mem 0x0000000000001000-0x000000007f6d2fff]
[ 0.013632] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.013774] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.032453] Using APIC driver default
[ 0.032466] Reserving Intel graphics memory at [mem 0x7f800000-0x7fffffff]
[ 0.032785] ACPI: PM-Timer IO Port: 0x1008
[ 0.032798] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.032802] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.032816] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.032822] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.032827] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.032835] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.032840] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.032865] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.032869] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.032874] [mem 0x80000000-0xdfffffff] available for PCI devices
[ 0.032877] Booting paravirtualized kernel on bare hardware
[ 0.032885] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.032896] setup_percpu: NR_CPUS:32 nr_cpumask_bits:2 nr_cpu_ids:2 nr_node_ids:1
[ 0.033126] percpu: Embedded 33 pages/cpu s102932 r0 d32236 u135168
[ 0.033137] pcpu-alloc: s102932 r0 d32236 u135168 alloc=33*4096
[ 0.033144] pcpu-alloc: [0] 0 [0] 1
[ 0.033180] Built 1 zonelists, mobility grouping on. Total pages: 519651
[ 0.033186] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-37-686 root=UUID=f6f12d59-69e2-494f-8d08-96944400595c ro quiet
[ 0.033357] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.1.0-37-686", will be passed to user space.
[ 0.033609] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.033725] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.033769] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.033775] Initializing HighMem for node 0 (00036bfe:0007f6d3)
[ 0.202646] Initializing Movable for node 0 (00000000:00000000)
[ 0.210116] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.210131] Memory: 2025440K/2087364K available (9302K kernel code, 1246K rwdata, 3184K rodata, 904K init, 464K bss, 61924K reserved, 0K cma-reserved, 1190740K highmem)
[ 0.211354] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.211454] ftrace: allocating 36873 entries in 73 pages
[ 0.224509] ftrace: allocated 73 pages with 3 groups
[ 0.224755] trace event string verifier disabled
[ 0.224866] Dynamic Preempt: voluntary
[ 0.224963] rcu: Preemptible hierarchical RCU implementation.
[ 0.224965] rcu: RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=2.
[ 0.224968] Trampoline variant of Tasks RCU enabled.
[ 0.224969] Rude variant of Tasks RCU enabled.
[ 0.224970] Tracing variant of Tasks RCU enabled.
[ 0.224972] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.224974] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.244877] NR_IRQS: 2304, nr_irqs: 440, preallocated irqs: 16
[ 0.245110] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.247652] Console: colour VGA+ 80x25
[ 0.247693] printk: console [tty0] enabled
[ 0.247712] ACPI: Core revision 20220331
[ 0.247884] APIC: Switch to symmetric I/O mode setup
[ 0.247888] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.248343] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.267856] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x17f6a294e98, max_idle_ns: 440795271983 ns
[ 0.267872] Calibrating delay loop (skipped), value calculated using timer frequency.. 3324.92 BogoMIPS (lpj=6649848)
[ 0.267891] Disabled fast string operations
[ 0.267901] x86/cpu: VMX (outside TXT) disabled by BIOS
[ 0.267950] CPU0: Thermal monitoring enabled (TM2)
[ 0.267983] process: using mwait in idle threads
[ 0.268003] Last level iTLB entries: 4KB 128, 2MB 0, 4MB 2
[ 0.268006] Last level dTLB entries: 4KB 128, 2MB 0, 4MB 8, 1GB 0
[ 0.268014] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.268018] Spectre V2 : Mitigation: Retpolines
[ 0.268021] Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
[ 0.268023] L1TF: Kernel not compiled for PAE. No mitigation for L1TF
[ 0.268026] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.268029] MMIO Stale Data: Unknown: No mitigations
[ 0.268035] x86/fpu: x87 FPU will use FXSAVE
[ 0.268651] Freeing SMP alternatives memory: 32K
[ 0.268656] pid_max: default: 32768 minimum: 301
[ 0.268894] LSM: Security Framework initializing
[ 0.268938] landlock: Up and running.
[ 0.268940] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.269044] AppArmor: AppArmor initialized
[ 0.269049] TOMOYO Linux initialized
[ 0.269062] LSM support for eBPF active
[ 0.269171] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.269181] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.378996] smpboot: CPU0: Genuine Intel(R) CPU T2300 @ 1.66GHz (family: 0x6, model: 0xe, stepping: 0x8)
[ 0.379369] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.379372] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.379420] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.379423] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.379492] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.379495] cblist_init_generic: Setting shift to 1 and lim to 1.
[ 0.379557] Performance Events: Core events, core PMU driver.
[ 0.379569] ... version: 1
[ 0.379571] ... bit width: 40
[ 0.379574] ... generic registers: 2
[ 0.379576] ... value mask: 000000ffffffffff
[ 0.379578] ... max period: 000000007fffffff
[ 0.379581] ... fixed-purpose events: 0
[ 0.379583] ... event mask: 0000000000000003
[ 0.379704] signal: max sigframe size: 1440
[ 0.379764] rcu: Hierarchical SRCU implementation.
[ 0.379767] rcu: Max phase no-delay instances is 1000.
[ 0.379865] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.379865] smp: Bringing up secondary CPUs ...
[ 0.379865] x86: Booting SMP configuration:
[ 0.379865] .... node #0, CPUs: #1
[ 0.002716] Disabled fast string operations
[ 0.379865] TSC synchronization [CPU#0 -> CPU#1]:
[ 0.379865] Measured 3026654610 cycles TSC warp between CPUs, turning off TSC clock.
[ 0.379865] tsc: Marking TSC unstable due to check_tsc_sync_source failed
[ 0.380065] smp: Brought up 1 node, 2 CPUs
[ 0.380073] smpboot: Max logical packages: 1
[ 0.380075] smpboot: Total of 2 processors activated (6649.84 BogoMIPS)
[ 0.382027] devtmpfs: initialized
[ 0.382695] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.382720] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.382840] pinctrl core: initialized pinctrl subsystem
[ 0.383502] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.384062] audit: initializing netlink subsys (disabled)
[ 0.384143] audit: type=2000 audit(1752441666.140:1): state=initialized audit_enabled=0 res=1
[ 0.384443] thermal_sys: Registered thermal governor 'fair_share'
[ 0.384448] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.384450] thermal_sys: Registered thermal governor 'step_wise'
[ 0.384453] thermal_sys: Registered thermal governor 'user_space'
[ 0.384455] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.384481] cpuidle: using governor ladder
[ 0.384561] Simple Boot Flag at 0x79 set to 0x1
[ 0.384594] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.384766] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xe0000000-0xe3ffffff] (base 0xe0000000)
[ 0.384777] PCI: MMCONFIG at [mem 0xe0000000-0xe3ffffff] reserved in E820
[ 0.384781] PCI: Using MMCONFIG for extended config space
[ 0.384788] PCI: Using configuration type 1 for base access
[ 0.384984] mtrr: your CPUs had inconsistent variable MTRR settings
[ 0.384987] mtrr: probably your BIOS does not setup all CPUs.
[ 0.384989] mtrr: corrected configuration.
[ 0.387659] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.405425] HugeTLB: registered 4.00 MiB page size, pre-allocated 0 pages
[ 0.405431] HugeTLB: 0 KiB vmemmap can be freed for a 4.00 MiB page
[ 0.406447] ACPI: Added _OSI(Module Device)
[ 0.406451] ACPI: Added _OSI(Processor Device)
[ 0.406454] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.406457] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.410862] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.423759] ACPI: Dynamic OEM Table Load:
[ 0.423773] ACPI: SSDT 0x00000000C1336800 0001AF (v01 PmRef Cpu0Ist 00003000 INTL 20050624)
[ 0.424331] ACPI: Dynamic OEM Table Load:
[ 0.424340] ACPI: SSDT 0x00000000C1337600 0001C6 (v01 PmRef Cpu0Cst 00003001 INTL 20050624)
[ 0.425042] ACPI: Dynamic OEM Table Load:
[ 0.425052] ACPI: SSDT 0x00000000C127CD80 000090 (v01 PmRef Cpu1Ist 00003000 INTL 20050624)
[ 0.425487] ACPI: Dynamic OEM Table Load:
[ 0.425496] ACPI: SSDT 0x00000000C127C0C0 000085 (v01 PmRef Cpu1Cst 00003000 INTL 20050624)
[ 0.426306] ACPI: Interpreter enabled
[ 0.426345] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.426348] ACPI: Using IOAPIC for interrupt routing
[ 0.426394] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.426398] PCI: Using E820 reservations for host bridge windows
[ 0.426705] ACPI: Enabled 12 GPEs in block 00 to 1F
[ 0.486481] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.486495] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[ 0.486510] acpi PNP0A03:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.495385] acpi PNP0A03:00: host bridge window [io 0x0000-0x0cf7 window] (ignored)
[ 0.495392] acpi PNP0A03:00: host bridge window [io 0x0cf8-0x0cff] (ignored)
[ 0.495396] acpi PNP0A03:00: host bridge window [io 0x0d00-0xffff window] (ignored)
[ 0.495400] acpi PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff window] (ignored)
[ 0.495405] acpi PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff window] (ignored)
[ 0.495409] acpi PNP0A03:00: host bridge window [mem 0x80000000-0xdfffffff window] (ignored)
[ 0.495413] acpi PNP0A03:00: host bridge window [mem 0xf0007000-0xf0007fff window] (ignored)
[ 0.495418] acpi PNP0A03:00: host bridge window [mem 0xf000c000-0xfebfffff window] (ignored)
[ 0.495422] acpi PNP0A03:00: host bridge window [mem 0xfec10000-0xfed1ffff window] (ignored)
[ 0.495426] acpi PNP0A03:00: host bridge window [mem 0xfee10000-0xffafffff window] (ignored)
[ 0.495430] PCI: root bus 00: using default resources
[ 0.496013] PCI host bridge to bus 0000:00
[ 0.496018] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.496023] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.496028] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.496088] pci 0000:00:00.0: [8086:27a0] type 00 class 0x060000
[ 0.496236] pci 0000:00:02.0: [8086:27a2] type 00 class 0x030000
[ 0.496251] pci 0000:00:02.0: reg 0x10: [mem 0xdff00000-0xdff7ffff]
[ 0.496260] pci 0000:00:02.0: reg 0x14: [io 0xeff8-0xefff]
[ 0.496269] pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff pref]
[ 0.496277] pci 0000:00:02.0: reg 0x1c: [mem 0xdfec0000-0xdfefffff]
[ 0.496305] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.496488] pci 0000:00:02.1: [8086:27a6] type 00 class 0x038000
[ 0.496501] pci 0000:00:02.1: reg 0x10: [mem 0xdff80000-0xdfffffff]
[ 0.496752] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.496782] pci 0000:00:1b.0: reg 0x10: [mem 0xdfebc000-0xdfebffff 64bit]
[ 0.496918] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.497137] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.497281] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.497519] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[ 0.497665] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.497914] pci 0000:00:1c.3: [8086:27d6] type 01 class 0x060400
[ 0.498061] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.498302] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.498396] pci 0000:00:1d.0: reg 0x20: [io 0xbf80-0xbf9f]
[ 0.498611] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.498705] pci 0000:00:1d.1: reg 0x20: [io 0xbf60-0xbf7f]
[ 0.498910] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.499003] pci 0000:00:1d.2: reg 0x20: [io 0xbf40-0xbf5f]
[ 0.499221] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.499310] pci 0000:00:1d.3: reg 0x20: [io 0xbf20-0xbf3f]
[ 0.499531] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.499557] pci 0000:00:1d.7: reg 0x10: [mem 0xffa80000-0xffa803ff]
[ 0.499672] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.499874] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401
[ 0.500147] pci 0000:00:1f.0: [8086:27b9] type 00 class 0x060100
[ 0.500270] pci 0000:00:1f.0: Force enabled HPET at 0xfed00000
[ 0.500281] pci 0000:00:1f.0: quirk: [io 0x1000-0x107f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.500289] pci 0000:00:1f.0: quirk: [io 0x1080-0x10bf] claimed by ICH6 GPIO
[ 0.500295] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0900 (mask 007f)
[ 0.500303] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 3 PIO at 0c80 (mask 003f)
[ 0.500547] pci 0000:00:1f.2: [8086:27c4] type 00 class 0x010180
[ 0.500572] pci 0000:00:1f.2: reg 0x10: [io 0x01f0-0x01f7]
[ 0.500587] pci 0000:00:1f.2: reg 0x14: [io 0x03f4-0x03f7]
[ 0.500601] pci 0000:00:1f.2: reg 0x18: [io 0x0170-0x0177]
[ 0.500616] pci 0000:00:1f.2: reg 0x1c: [io 0x0374-0x0377]
[ 0.500630] pci 0000:00:1f.2: reg 0x20: [io 0xbfa0-0xbfaf]
[ 0.500660] pci 0000:00:1f.2: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.500663] pci 0000:00:1f.2: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.500667] pci 0000:00:1f.2: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.500671] pci 0000:00:1f.2: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.500711] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.500874] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.500955] pci 0000:00:1f.3: reg 0x20: [io 0x10c0-0x10df]
[ 0.501169] pci 0000:00:1c.0: PCI bridge to [bus 0b]
[ 0.501432] pci 0000:0c:00.0: [8086:4222] type 00 class 0x028000
[ 0.501506] pci 0000:0c:00.0: reg 0x10: [mem 0xdfdff000-0xdfdfffff]
[ 0.501969] pci 0000:0c:00.0: PME# supported from D0 D3hot D3cold
[ 0.502390] pci 0000:0c:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.502425] pci 0000:00:1c.1: PCI bridge to [bus 0c]
[ 0.502435] pci 0000:00:1c.1: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.502585] acpiphp: Slot [1] registered
[ 0.502594] pci 0000:00:1c.3: PCI bridge to [bus 0d-0e]
[ 0.502601] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.502608] pci 0000:00:1c.3: bridge window [mem 0xdfa00000-0xdfcfffff]
[ 0.502619] pci 0000:00:1c.3: bridge window [mem 0xd0000000-0xd01fffff 64bit pref]
[ 0.502649] pci_bus 0000:03: extended config space not accessible
[ 0.502722] pci 0000:03:00.0: [14e4:170c] type 00 class 0x020000
[ 0.502747] pci 0000:03:00.0: reg 0x10: [mem 0xdf9fe000-0xdf9fffff]
[ 0.502856] pci 0000:03:00.0: supports D1 D2
[ 0.502860] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.502971] pci 0000:03:01.0: [1180:0832] type 00 class 0x0c0010
[ 0.502997] pci 0000:03:01.0: reg 0x10: [mem 0xdf9fd800-0xdf9fdfff]
[ 0.503107] pci 0000:03:01.0: supports D1 D2
[ 0.503110] pci 0000:03:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.503266] pci 0000:03:01.1: [1180:0822] type 00 class 0x080501
[ 0.503292] pci 0000:03:01.1: reg 0x10: [mem 0xdf9fd500-0xdf9fd5ff]
[ 0.503402] pci 0000:03:01.1: supports D1 D2
[ 0.503406] pci 0000:03:01.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.503513] pci 0000:03:01.2: [1180:0592] type 00 class 0x088000
[ 0.503538] pci 0000:03:01.2: reg 0x10: [mem 0xdf9fd600-0xdf9fd6ff]
[ 0.503649] pci 0000:03:01.2: supports D1 D2
[ 0.503652] pci 0000:03:01.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.503759] pci 0000:03:01.3: [1180:0852] type 00 class 0x088000
[ 0.503785] pci 0000:03:01.3: reg 0x10: [mem 0xdf9fd700-0xdf9fd7ff]
[ 0.503899] pci 0000:03:01.3: supports D1 D2
[ 0.503902] pci 0000:03:01.3: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.504053] pci 0000:00:1e.0: PCI bridge to [bus 03] (subtractive decode)
[ 0.504064] pci 0000:00:1e.0: bridge window [mem 0xdf900000-0xdf9fffff]
[ 0.504074] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.504079] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.504114] pci_bus 0000:00: on NUMA node 0
[ 0.504692] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[ 0.504829] ACPI: PCI: Interrupt link LNKB configured for IRQ 4
[ 0.504963] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[ 0.505096] ACPI: PCI: Interrupt link LNKD configured for IRQ 3
[ 0.505230] ACPI: PCI: Interrupt link LNKE configured for IRQ 9
[ 0.505363] ACPI: PCI: Interrupt link LNKF configured for IRQ 10
[ 0.505497] ACPI: PCI: Interrupt link LNKG configured for IRQ 7
[ 0.505631] ACPI: PCI: Interrupt link LNKH configured for IRQ 5
[ 0.506433] iommu: Default domain type: Translated
[ 0.506437] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.506556] pps_core: LinuxPPS API ver. 1 registered
[ 0.506560] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.506568] PTP clock support registered
[ 0.506590] EDAC MC: Ver: 3.0.0
[ 0.507328] NetLabel: Initializing
[ 0.507330] NetLabel: domain hash size = 128
[ 0.507333] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.507367] NetLabel: unlabeled traffic allowed by default
[ 0.507370] PCI: Using ACPI for IRQ routing
[ 0.510094] PCI: pci_cache_line_size set to 64 bytes
[ 0.510183] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.510187] e820: reserve RAM buffer [mem 0x7f6d3400-0x7fffffff]
[ 0.510292] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.510298] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.510301] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.510312] vgaarb: loaded
[ 0.510408] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.510429] hpet: 3 channels of 0 reserved for per-cpu timers
[ 0.510435] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.510447] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.511913] clocksource: Switched to clocksource hpet
[ 0.512312] VFS: Disk quotas dquot_6.6.0
[ 0.512357] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.512751] AppArmor: AppArmor Filesystem Enabled
[ 0.512791] pnp: PnP ACPI init
[ 0.525425] pnp 00:00: disabling [mem 0x000c0000-0x000cffff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
[ 0.525591] system 00:00: [mem 0x00000000-0x0009fbff] could not be reserved
[ 0.525599] system 00:00: [mem 0x0009fc00-0x0009ffff] could not be reserved
[ 0.525604] system 00:00: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.525609] system 00:00: [mem 0x00100000-0x7f6d33ff] could not be reserved
[ 0.525616] system 00:00: [mem 0x7f6d3400-0x7f6fffff] has been reserved
[ 0.525622] system 00:00: [mem 0x7f700000-0x7f7fffff] has been reserved
[ 0.525628] system 00:00: [mem 0x7f700000-0x7fefffff] could not be reserved
[ 0.525633] system 00:00: [mem 0xffb00000-0xffffffff] has been reserved
[ 0.525638] system 00:00: [mem 0xfec00000-0xfec0ffff] could not be reserved
[ 0.525644] system 00:00: [mem 0xfee00000-0xfee0ffff] has been reserved
[ 0.525649] system 00:00: [mem 0xfed20000-0xfed9ffff] has been reserved
[ 0.525655] system 00:00: [mem 0xf0000000-0xf0003fff] has been reserved
[ 0.525661] system 00:00: [mem 0xf0004000-0xf0004fff] has been reserved
[ 0.525666] system 00:00: [mem 0xf0005000-0xf0005fff] has been reserved
[ 0.525672] system 00:00: [mem 0xf0006000-0xf0006fff] has been reserved
[ 0.525678] system 00:00: [mem 0xf0008000-0xf000bfff] has been reserved
[ 0.525683] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.525767] pnp 00:01: disabling [io 0x1000-0x1005] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
[ 0.525775] pnp 00:01: disabling [io 0x1008-0x100f] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
[ 0.525827] system 00:01: [io 0x04d0-0x04d1] has been reserved
[ 0.525881] pnp 00:02: disabling [io 0x1006-0x1007] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
[ 0.525888] pnp 00:02: disabling [io 0x100a-0x1059] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
[ 0.525893] pnp 00:02: disabling [io 0x1060-0x107f] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
[ 0.525899] pnp 00:02: disabling [io 0x1010-0x102f] because it overlaps 0000:00:1f.0 BAR 13 [io 0x1000-0x107f]
[ 0.525949] system 00:02: [io 0xf400-0xf4fe] has been reserved
[ 0.525955] system 00:02: [io 0x1080-0x10bf] has been reserved
[ 0.525960] system 00:02: [io 0x10c0-0x10df] has been reserved
[ 0.525965] system 00:02: [io 0x0809] has been reserved
[ 0.526276] system 00:06: [io 0x0c80-0x0cff] could not be reserved
[ 0.526282] system 00:06: [io 0x0910-0x091f] has been reserved
[ 0.526287] system 00:06: [io 0x0920-0x092f] has been reserved
[ 0.526291] system 00:06: [io 0x0930-0x097f] has been reserved
[ 0.526777] pnp: PnP ACPI: found 7 devices
[ 0.526789] PnPBIOS: Disabled
[ 0.566031] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.566301] NET: Registered PF_INET protocol family
[ 0.566515] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.567606] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.567782] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.567847] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.567957] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.568047] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.568224] MPTCP toxxxx hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 0.568273] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.568298] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.568413] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.568432] NET: Registered PF_XDP protocol family
[ 0.568455] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 0b] add_size 1000
[ 0.568465] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 0b] add_size 200000 add_align 100000
[ 0.568472] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 0b] add_size 200000 add_align 100000
[ 0.568479] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 0c] add_size 1000
[ 0.568485] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 0c] add_size 200000 add_align 100000
[ 0.568524] pci 0000:00:1c.0: BAR 14: assigned [mem 0x80000000-0x801fffff]
[ 0.568531] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[ 0.568537] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80400000-0x805fffff 64bit pref]
[ 0.568544] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.568550] pci 0000:00:1c.1: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.568559] pci 0000:00:1c.0: PCI bridge to [bus 0b]
[ 0.568566] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.568575] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff]
[ 0.568582] pci 0000:00:1c.0: bridge window [mem 0x80200000-0x803fffff 64bit pref]
[ 0.568593] pci 0000:00:1c.1: PCI bridge to [bus 0c]
[ 0.568598] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff]
[ 0.568606] pci 0000:00:1c.1: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.568613] pci 0000:00:1c.1: bridge window [mem 0x80400000-0x805fffff 64bit pref]
[ 0.568623] pci 0000:00:1c.3: PCI bridge to [bus 0d-0e]
[ 0.568629] pci 0000:00:1c.3: bridge window [io 0xd000-0xdfff]
[ 0.568636] pci 0000:00:1c.3: bridge window [mem 0xdfa00000-0xdfcfffff]
[ 0.568643] pci 0000:00:1c.3: bridge window [mem 0xd0000000-0xd01fffff 64bit pref]
[ 0.568655] pci 0000:00:1e.0: PCI bridge to [bus 03]
[ 0.568663] pci 0000:00:1e.0: bridge window [mem 0xdf900000-0xdf9fffff]
[ 0.568677] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.568681] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.568685] pci_bus 0000:0b: resource 0 [io 0x2000-0x2fff]
[ 0.568689] pci_bus 0000:0b: resource 1 [mem 0x80000000-0x801fffff]
[ 0.568694] pci_bus 0000:0b: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[ 0.568699] pci_bus 0000:0c: resource 0 [io 0x3000-0x3fff]
[ 0.568703] pci_bus 0000:0c: resource 1 [mem 0xdfd00000-0xdfdfffff]
[ 0.568707] pci_bus 0000:0c: resource 2 [mem 0x80400000-0x805fffff 64bit pref]
[ 0.568712] pci_bus 0000:0d: resource 0 [io 0xd000-0xdfff]
[ 0.568716] pci_bus 0000:0d: resource 1 [mem 0xdfa00000-0xdfcfffff]
[ 0.568720] pci_bus 0000:0d: resource 2 [mem 0xd0000000-0xd01fffff 64bit pref]
[ 0.568725] pci_bus 0000:03: resource 1 [mem 0xdf900000-0xdf9fffff]
[ 0.568729] pci_bus 0000:03: resource 4 [io 0x0000-0xffff]
[ 0.568733] pci_bus 0000:03: resource 5 [mem 0x00000000-0xffffffff]
[ 0.571258] PCI: CLS 64 bytes, default 64
[ 0.571447] Trying to unpack rootfs image as initramfs...
[ 0.572378] Initialise system trusted keyrings
[ 0.572432] Key type blacklist registered
[ 0.572656] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.577052] zbud: loaded
[ 0.577691] integrity: Platform Keyring initialized
[ 0.577712] integrity: Machine keyring initialized
[ 0.577717] Key type asymmetric registered
[ 0.577720] Asymmetric key parser 'x509' registered
[ 1.448617] Freeing initrd memory: 24232K
[ 1.460707] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[ 1.460981] bounce: pool size: 64 pages
[ 1.461093] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.461176] io scheduler mq-deadline registered
[ 1.465487] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.465634] ACPI: \_PR_.CPU0: Found 3 idle states
[ 1.465747] ACPI: \_PR_.CPU1: Found 3 idle states
[ 1.465861] ACPI: \_PR_.CPU0: Found 3 idle states
[ 1.466180] ACPI: \_PR_.CPU1: Found 3 idle states
[ 1.470447] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.470452] ACPI: thermal: Thermal Zone [THM] (54 C)
[ 1.470677] isapnp: Scanning for PnP cards...
[ 1.824795] isapnp: No Plug & Play device found
[ 1.825002] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.826106] Linux agpgart interface v0.103
[ 1.826884] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 1.829493] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.829505] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.829819] mousedev: PS/2 mouse device common for all mice
[ 1.829881] rtc_cmos 00:05: RTC can wake from S4
[ 1.830350] rtc_cmos 00:05: registered as rtc0
[ 1.830399] rtc_cmos 00:05: setting system clock to 2025-07-13T21:21:08 UTC (1752441668)
[ 1.830480] rtc_cmos 00:05: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.830570] intel_pstate: CPU model not supported
[ 1.830620] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.830892] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.832084] NET: Registered PF_INET6 protocol family
[ 1.844474] Segment Routing with IPv6
[ 1.844516] In-situ OAM (IOAM) with IPv6
[ 1.844574] mip6: Mobile IPv6
[ 1.844585] NET: Registered PF_PACKET protocol family
[ 1.844691] mpls_gso: MPLS GSO support
[ 1.845087] microcode: sig=0x6e8, pf=0x20, revision=0x39
[ 1.845098] microcode: Microcode Update Driver: v2.2.
[ 1.845110] IPI shorthand broadcast: enabled
[ 1.845427] registered taskstats version 1
[ 1.845447] Loading compiled-in X.509 certificates
[ 2.048283] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[ 2.048344] Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f'
[ 2.049295] zswap: loaded using pool lzo/zbud
[ 2.049706] Key type .fscrypt registered
[ 2.049710] Key type fscrypt-provisioning registered
[ 2.059741] Key type encrypted registered
[ 2.059753] AppArmor: AppArmor sha1 policy hashing enabled
[ 2.059782] ima: No TPM chip found, activating TPM-bypass!
[ 2.059786] ima: Allocated hash algorithm: sha256
[ 2.059812] ima: No architecture policies found
[ 2.059855] evm: Initialising EVM extended attributes:
[ 2.059857] evm: security.selinux
[ 2.059860] evm: security.SMACK64 (disabled)
[ 2.059862] evm: security.SMACK64EXEC (disabled)
[ 2.059865] evm: security.SMACK64TRANSMUTE (disabled)
[ 2.059867] evm: security.SMACK64MMAP (disabled)
[ 2.059869] evm: security.apparmor
[ 2.059871] evm: security.ima
[ 2.059874] evm: security.capability
[ 2.059876] evm: HMAC attrs: 0x1
[ 3.203042] Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
[ 3.203098] clk: Disabling unused clocks
[ 3.206933] Freeing unused kernel image (initmem) memory: 904K
[ 3.206965] Write protecting kernel text and read-only data: 12488k
[ 3.206975] Run /init as init process
[ 3.206978] with arguments:
[ 3.206980] /init
[ 3.206983] with environment:
[ 3.206985] HOME=/
[ 3.206988] TERM=linux
[ 3.206990] BOOT_IMAGE=/boot/vmlinuz-6.1.0-37-686
[ 3.252112] udevd[108]: starting version 3.2.12
[ 4.290733] random: crng init done
[ 4.292830] udevd[109]: starting eudev-3.2.12
[ 4.366955] ACPI: video: Video Device [VID1] (multi-head: yes rom: no post: no)
[ 4.367562] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/LNXVIDEO:01/input/input2
[ 4.367621] ACPI: video: [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 4.374301] ACPI: battery: Slot [BAT0] (battery present)
[ 4.414483] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 4.416860] i2c i2c-0: 2/2 memory slots populated (from DMI)
[ 4.416866] i2c i2c-0: Memory type 0x12 not supported yet, not instantiating SPD
[ 4.505029] sdhci: Secure Digital Host Controller Interface driver
[ 4.505037] sdhci: Copyright(c) Pierre Ossman
[ 4.514849] ACPI: bus type USB registered
[ 4.514906] usbcore: registered new interface driver usbfs
[ 4.514929] usbcore: registered new interface driver hub
[ 4.514959] usbcore: registered new device driver usb
[ 4.553593] SCSI subsystem initialized
[ 4.563865] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 4.563883] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 4.563903] ehci-pci 0000:00:1d.7: debug port 1
[ 4.568013] ehci-pci 0000:00:1d.7: irq 20, io mem 0xffa80000
[ 4.569784] sdhci-pci 0000:03:01.1: SDHCI controller found [1180:0822] (rev 19)
[ 4.575835] firewire_ohci 0000:03:01.0: added OHCI v1.10 device as card 0, 4 IR + 4 IT contexts, quirks 0x11
[ 4.577209] mmc0 bounce up to 128 segments into one, max segment size 65536 bytes
[ 4.582854] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 4.583231] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 4.583238] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.583243] usb usb1: Product: EHCI Host Controller
[ 4.583247] usb usb1: Manufacturer: Linux 6.1.0-37-686 ehci_hcd
[ 4.583251] usb usb1: SerialNumber: 0000:00:1d.7
[ 4.583819] hub 1-0:1.0: USB hub found
[ 4.583840] hub 1-0:1.0: 8 ports detected
[ 4.586009] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 4.586025] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 4.586038] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 4.586067] uhci_hcd 0000:00:1d.0: irq 20, io port 0x0000bf80
[ 4.586210] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 4.586216] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.586220] usb usb2: Product: UHCI Host Controller
[ 4.586224] usb usb2: Manufacturer: Linux 6.1.0-37-686 uhci_hcd
[ 4.586227] usb usb2: SerialNumber: 0000:00:1d.0
[ 4.586495] hub 2-0:1.0: USB hub found
[ 4.586639] hub 2-0:1.0: 2 ports detected
[ 4.587322] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 4.587332] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 4.587353] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 4.587394] uhci_hcd 0000:00:1d.1: irq 21, io port 0x0000bf60
[ 4.587495] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 4.587501] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.587505] usb usb3: Product: UHCI Host Controller
[ 4.587509] usb usb3: Manufacturer: Linux 6.1.0-37-686 uhci_hcd
[ 4.587512] usb usb3: SerialNumber: 0000:00:1d.1
[ 4.587743] hub 3-0:1.0: USB hub found
[ 4.587758] hub 3-0:1.0: 2 ports detected
[ 4.588294] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 4.588304] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 4.588314] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 4.588349] uhci_hcd 0000:00:1d.2: irq 22, io port 0x0000bf40
[ 4.588448] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 4.588454] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.588458] usb usb4: Product: UHCI Host Controller
[ 4.588462] usb usb4: Manufacturer: Linux 6.1.0-37-686 uhci_hcd
[ 4.588465] usb usb4: SerialNumber: 0000:00:1d.2
[ 4.588684] hub 4-0:1.0: USB hub found
[ 4.588704] hub 4-0:1.0: 2 ports detected
[ 4.589258] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 4.589269] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 4.589279] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 4.589315] uhci_hcd 0000:00:1d.3: irq 23, io port 0x0000bf20
[ 4.589414] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.01
[ 4.589420] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.589424] usb usb5: Product: UHCI Host Controller
[ 4.589427] usb usb5: Manufacturer: Linux 6.1.0-37-686 uhci_hcd
[ 4.589430] usb usb5: SerialNumber: 0000:00:1d.3
[ 4.589797] hub 5-0:1.0: USB hub found
[ 4.589813] hub 5-0:1.0: 2 ports detected
[ 4.594807] ssb: Found chip with id 0x4401, rev 0x02 and package 0x00
[ 4.595006] mmc0: SDHCI controller on PCI [0000:03:01.1] using DMA
[ 4.614930] libata version 3.00 loaded.
[ 4.619947] ata_piix 0000:00:1f.2: version 2.13
[ 4.620221] ata_piix 0000:00:1f.2: MAP [ P0 P2 IDE IDE ]
[ 4.621522] scsi host0: ata_piix
[ 4.621827] scsi host1: ata_piix
[ 4.621935] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xbfa0 irq 14
[ 4.621940] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xbfa8 irq 15
[ 4.651006] b44 0000:03:00.0: Sonics Silicon Backplane found on PCI device 0000:03:00.0
[ 4.679659] b44 ssb0:0 eth0: Broadcom 44xx/47xx 10/100 PCI ethernet driver 00:14:22:f3:ac:f4
[ 4.781885] ata2.00: ATAPI: SONY DVD+/-RW DW-Q58A, UDS2, max UDMA/33
[ 4.782249] ata1.00: HPA detected: current 192426570, native 195371568
[ 4.782263] ata1.00: ATA-7: FUJITSU MHV2100BH, 00850028, max UDMA/100
[ 4.782271] ata1.00: 192426570 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 4.838826] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 4.995221] usb 1-1: New USB device found, idVendor=413c, idProduct=a005, bcdDevice=50.18
[ 4.995227] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.995690] hub 1-1:1.0: USB hub found
[ 4.995858] hub 1-1:1.0: 4 ports detected
[ 5.016384] scsi 0:0:0:0: Direct-Access ATA FUJITSU MHV2100B 0028 PQ: 0 ANSI: 5
[ 5.018140] scsi 1:0:0:0: CD-ROM SONY DVD+-RW DW-Q58A UDS2 PQ: 0 ANSI: 5
[ 5.078940] firewire_core 0000:03:01.0: created device fw0: GUID 424fc0000b649450, S400
[ 5.114220] sd 0:0:0:0: [sda] 192426570 512-byte logical blocks: (98.5 GB/91.8 GiB)
[ 5.114280] sd 0:0:0:0: [sda] Write Protect is off
[ 5.114287] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.114368] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.114475] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 5.140269] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 5.140279] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 5.183557] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 5.213072] psmouse serio1: synaptics: Touchpad model: 1, fw: 6.2, id: 0xfa0b1, caps: 0xa04713/0x200000/0x0/0x0, board id: 0, fw id: 128333
[ 5.234181] sda: sda1 sda2 < sda5 sda6 >
[ 5.234690] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.239550] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.239758] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 5.252171] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input3
[ 5.282774] usb 1-1.4: new full-speed USB device number 3 using ehci-pci
[ 5.429872] usb 1-1.4: New USB device found, idVendor=413c, idProduct=8103, bcdDevice=24.22
[ 5.429890] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.963849] PM: Image not found (code -22)
[ 6.392978] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
[ 6.649829] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 8.863085] udevd[379]: starting version 3.2.12
[ 9.787841] udevd[380]: starting eudev-3.2.12
[ 10.406672] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input4
[ 10.422839] ACPI: button: Lid Switch [LID]
[ 10.422969] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[ 10.423061] ACPI: button: Power Button [PBTN]
[ 10.423149] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input6
[ 10.423209] ACPI: button: Sleep Button [SBTN]
[ 10.537765] ACPI: AC: AC Adapter [AC] (on-line)
[ 11.235592] intel_rng: FWH not detected
[ 11.437973] leds_ss4200: no LED devices found
[ 11.517621] r592: driver successfully loaded
[ 12.149168] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 12.151453] cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[ 12.154855] cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 12.158422] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 12.161004] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 12.482811] r852: Non dma capable device detected, dma disabled
[ 12.482838] r852: driver loaded successfully
[ 12.489331] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[ 12.860152] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 13.249528] ACPI: bus type drm_connector registered
[ 13.251888] intel_powerclamp: No package C-state available
[ 13.274914] iTCO_vendor_support: vendor-support=0
[ 13.555430] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[ 13.574211] iTCO_wdt iTCO_wdt.1.auto: Found a ICH7-M or ICH7-U TCO device (Version=2, TCOBASE=0x1060)
[ 13.574836] iTCO_wdt iTCO_wdt.1.auto: initialized. heartbeat=30 sec (nowayout=0)
[ 13.658328] iwl3945: Intel(R) PRO/Wireless 3945ABG/BG Network Connection driver for Linux, in-tree:s
[ 13.658340] iwl3945: Copyright(c) 2003-2011 Intel Corporation
[ 13.658343] iwl3945: hw_scan is disabled
[ 13.658444] iwl3945 0000:0c:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 13.712816] iwl3945 0000:0c:00.0: Tunable channels: 13 802.11bg, 23 802.11a channels
[ 13.712830] iwl3945 0000:0c:00.0: Detected Intel Wireless WiFi Link 3945ABG
[ 13.726886] ieee80211 phy0: Selected rate control algorithm 'iwl-3945-rs'
[ 13.882317] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[ 13.995439] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[ 14.101972] Bluetooth: Core ver 2.22
[ 14.102035] NET: Registered PF_BLUETOOTH protocol family
[ 14.102039] Bluetooth: HCI device and connection manager initialized
[ 14.102048] Bluetooth: HCI socket layer initialized
[ 14.102053] Bluetooth: L2CAP socket layer initialized
[ 14.102061] Bluetooth: SCO socket layer initialized
[ 14.312029] snd_hda_codec_idt hdaudioC0D0: autoconfig for STAC9200: line_outs=3 (0xf/0xe/0x11/0x0/0x0) type:speaker
[ 14.312050] snd_hda_codec_idt hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 14.312059] snd_hda_codec_idt hdaudioC0D0: hp_outs=1 (0xd/0x0/0x0/0x0/0x0)
[ 14.312067] snd_hda_codec_idt hdaudioC0D0: mono: mono_out=0x0
[ 14.312073] snd_hda_codec_idt hdaudioC0D0: dig-out=0x9/0x0
[ 14.312079] snd_hda_codec_idt hdaudioC0D0: inputs:
[ 14.312084] snd_hda_codec_idt hdaudioC0D0: Mic=0x10
[ 14.503391] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 14.503611] input: HDA Intel Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 14.579043] usbcore: registered new interface driver btusb
[ 15.491062] pci 0000:00:00.0: Intel 945GM Chipset
[ 15.491087] pci 0000:00:00.0: detected gtt size: 262144K total, 262144K mappable
[ 15.491396] pci 0000:00:00.0: detected 8192K stolen memory
[ 15.491592] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 15.492515] Console: switching to colour dummy device 80x25
[ 15.495878] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 15.621988] i915 0000:00:02.0: [drm] Initialized overlay support.
[ 15.622768] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 15.774021] fbcon: i915drmfb (fb0) is primary device
[ 16.498700] Console: switching to colour frame buffer device 160x64
[ 16.521017] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 18.381763] Adding 999420k swap on /dev/sda5. Priority:-2 extents:1 across:999420k FS
[ 18.493599] EXT4-fs (sda1): re-mounted. Quota mode: none.
[ 19.824248] lp: driver loaded but no devices found
[ 19.877247] ppdev: user-space parallel port driver
[ 20.189953] EXT4-fs (sda6): mounted filesystem with ordered data mode. Quota mode: none.
[ 21.195380] audit: type=1400 audit(1752441687.516:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=1129 comm="apparmor_parser"
[ 21.309673] audit: type=1400 audit(1752441687.628:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/i386-linux-gnu/lightdm/lightdm-guest-session" pid=1128 comm="apparmor_parser"
[ 21.309690] audit: type=1400 audit(1752441687.628:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/i386-linux-gnu/lightdm/lightdm-guest-session//chromium" pid=1128 comm="apparmor_parser"
[ 21.325103] audit: type=1400 audit(1752441687.644:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mariadbd_akonadi" pid=1141 comm="apparmor_parser"
[ 21.335518] audit: type=1400 audit(1752441687.656:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mysqld_akonadi" pid=1146 comm="apparmor_parser"
[ 21.376107] audit: type=1400 audit(1752441687.696:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1149 comm="apparmor_parser"
[ 21.376123] audit: type=1400 audit(1752441687.696:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1149 comm="apparmor_parser"
[ 21.380225] audit: type=1400 audit(1752441687.700:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="postgresql_akonadi" pid=1151 comm="apparmor_parser"
[ 21.453540] audit: type=1400 audit(1752441687.772:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/akonadiserver" pid=1155 comm="apparmor_parser"
[ 21.468323] audit: type=1400 audit(1752441687.788:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1152 comm="apparmor_parser"
[ 30.603655] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 30.603668] Bluetooth: BNEP filters: protocol multicast
[ 30.603679] Bluetooth: BNEP socket layer initialized
[ 30.615421] Bluetooth: MGMT ver 1.22
[ 36.469448] iwl3945 0000:0c:00.0: firmware: direct-loading firmware iwlwifi-3945-2.ucode
[ 36.469475] iwl3945 0000:0c:00.0: loaded firmware version 15.32.2.9
[ 41.214556] NET: Registered PF_QIPCRTR protocol family
[ 100.838929] wlan0: authenticate with d8:7d:7f:bd:e1:7b
[ 100.841940] wlan0: send auth to d8:7d:7f:bd:e1:7b (try 1/3)
[ 100.845841] wlan0: authenticated
[ 100.854757] wlan0: associate with d8:7d:7f:bd:e1:7b (try 1/3)
[ 100.862125] wlan0: RX AssocResp from d8:7d:7f:bd:e1:7b (capab=0x411 status=0 aid=1)
[ 100.863847] wlan0: associated
[ 100.895200] wlan0: Limiting TX power to 17 (20 - 3) dBm as advertised by d8:7d:7f:bd:e1:7b
[ 100.987425] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 227.015926] Bluetooth: RFCOMM TTY layer initialized
[ 227.015948] Bluetooth: RFCOMM socket layer initialized
[ 227.015969] Bluetooth: RFCOMM ver 1.11.xsession-errors:
Xsession: X session started for xxxx at Sun 13 Jul 22:24:06 BST 2025
localuser:xxxx being added to access control list
dbus-update-activation-environment: systemd --user not found, ignoring --systemd argument
dbus-update-activation-environment: setting GTK_MODULES=gail:atk-bridge
dbus-update-activation-environment: setting QT_ACCESSIBILITY=1
dbus-update-activation-environment: setting USER=xxxx
dbus-update-activation-environment: setting LANGUAGE=en_GB:en
dbus-update-activation-environment: setting GTK_CSD=0
dbus-update-activation-environment: setting XDG_SESSION_TYPE=x11
dbus-update-activation-environment: setting HOME=/home/xxxx
dbus-update-activation-environment: setting DESKTOP_SESSION=plasma
dbus-update-activation-environment: setting XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
dbus-update-activation-environment: setting DBUS_SESSION_BUS_ADDRESS=unix:path=/tmp/dbus-XV94v9ugbT,guid=374a01f0d1c1eb4efd187161687423f7
dbus-update-activation-environment: setting LOGNAME=xxxx
dbus-update-activation-environment: setting XDG_SESSION_CLASS=user
dbus-update-activation-environment: setting GTK_OVERLAY_SCROLLING=0
dbus-update-activation-environment: setting LIBOVERLAY_SCROLLBAR=0
dbus-update-activation-environment: setting PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
dbus-update-activation-environment: setting XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
dbus-update-activation-environment: setting XDG_RUNTIME_DIR=/run/user/1000
dbus-update-activation-environment: setting DISPLAY=:0
dbus-update-activation-environment: setting LANG=en_GB.UTF-8
dbus-update-activation-environment: setting XDG_CURRENT_DESKTOP=KDE
dbus-update-activation-environment: setting LD_PRELOAD=libgtk3-nocsd.so.0
dbus-update-activation-environment: setting XDG_SESSION_DESKTOP=plasma
dbus-update-activation-environment: setting XAUTHORITY=/home/xxxx/.Xauthority
dbus-update-activation-environment: setting XDG_GREETER_DATA_DIR=/var/lib/lightdm/data/xxxx
dbus-update-activation-environment: setting SHELL=/bin/bash
dbus-update-activation-environment: setting GDMSESSION=plasma
dbus-update-activation-environment: setting GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
dbus-update-activation-environment: setting PWD=/home/xxxx
kdeinit5: preparing to launch '/usr/lib/i386-linux-gnu/libexec/kf5/klauncher'
kdeinit5: Launched KLauncher, pid = 1807, result = 0
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
kdeinit5: opened connection to :0
Initializing "/usr/lib/i386-linux-gnu/qt5/plugins/plasma/kcms/systemsettings/kcm_style.so"
kdeinit5: Got SETENV 'GTK_RC_FILES=/etc/gtk/gtkrc:/home/xxxx/.gtkrc:/home/xxxx/.config/gtkrc' from launcher.
kdeinit5: Got SETENV 'GTK2_RC_FILES=/etc/gtk-2.0/gtkrc:/home/xxxx/.gtkrc-2.0:/home/xxxx/.config/gtkrc-2.0' from launcher.
Initializing "/usr/lib/i386-linux-gnu/qt5/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Initializing "/usr/lib/i386-linux-gnu/qt5/plugins/plasma/kcms/systemsettings/kcm_mouse.so"
kdeinit5: Got SETENV 'XCURSOR_THEME=breeze_cursors' from launcher.
kdeinit5: Got SETENV 'XCURSOR_SIZE=24' from launcher.
org.kde.plasma.session: process job "kcminit_startup" finished with exit code 0
org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
org.kde.bolt.kded: Couldn't connect to Bolt DBus daemon
kwin_xkbcommon: XKB: inet:334:58: unrecognized keysym "XF86EmojiPicker"
Qt: Session management error: networkIdsList argument is NULL
kdeinit5: Got SETENV 'SESSION_MANAGER=local/master7:@/tmp/.ICE-unix/1837,unix/master7:/tmp/.ICE-unix/1837' from launcher.
/usr/bin/iceauth: creating new authority file /run/user/1000/ICEauthority
Initializing "/usr/lib/i386-linux-gnu/qt5/plugins/plasma/kcms/systemsettings/kcm_touchpad.so"
kcm_touchpad: Using X11 backend
Initializing "/usr/lib/i386-linux-gnu/qt5/plugins/plasma/kcms/systemsettings/kcm_kgamma.so"
Xlib XKB extension major= 1 minor= 0
X server XKB extension major= 1 minor= 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 817, resource id: 18874373, major code: 18 (ChangeProperty), minor code: 0
New PolkitAgentListener 0x246e500
Adding new listener PolkitQt1::Agent::Listener(0x244a950) for 0x246e500
Listener online
Authentication agent result: true
OpenGL vendor string: Mesa Project
OpenGL renderer string: i915 (chipset: 945GM)
OpenGL version string: 2.1 Mesa 22.3.6
OpenGL shading language version string: 1.20
Driver: Unknown
GPU class: Unknown
OpenGL version: 2.1
GLSL version: 1.20
Mesa version: 22.3.6
X server version: 1.21.1
Linux kernel version: 6.1
Requires strict binding: yes
GLSL shaders: yes
Texture NPOT support: yes
Virtual Machine: no
Baloo File Indexing has been disabled
Checking screens: available: (QScreen(0x2044bf0, name="LVDS1")) redundant: QHash((QScreen(0x2045870, name="VGA1"), QScreen(0x2044bf0, name="LVDS1"))) fake: QSet() all: (QScreen(0x2044bf0, name="LVDS1"), QScreen(0x2045870, name="VGA1"))
org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
kf.kio.gui: "Could not find the program 'wicd-gtk'"
kup.daemon: "Kup is not enabled, enable it from the system settings module. You can do that by running kcmshell5 kup"
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1020, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1025, resource id: 56623108, major code: 18 (ChangeProperty), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1029, resource id: 56623112, major code: 18 (ChangeProperty), minor code: 0
xsettingsd: Loaded 12 settings from /home/xxxx/.config/xsettingsd/xsettingsd.conf
xsettingsd: Created window 0x3600001 on screen 0 with timestamp 212564
xsettingsd: Selection _XSETTINGS_S0 is owned by 0x0
xsettingsd: Took ownership of selection _XSETTINGS_S0
xsettingsd: Reloading configuration
xsettingsd: Loaded 0 settings from /home/xxxx/.config/xsettingsd/xsettingsd.conf
dbus-daemon[2009]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=1877 comm="/usr/lib/i386-linux-gnu/libexec/kactivitymanagerd")
dbus-daemon[2009]: Successfully activated service 'org.a11y.atspi.Registry'
SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Installing the delayed initialization callback.
org.kde.powerdevil: Handle button events action could not check for screen configuration
Delayed initialization.
Reloading the khotkeys configuration
Version 2 File!
true
Imported file "/usr/share/khotkeys/defaults.khotkeys"
Imported file "/usr/share/khotkeys/kde32b1.khotkeys"
Imported file "/usr/share/khotkeys/konqueror_gestures_kde321.khotkeys"
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5961, resource id: 8388645, major code: 18 (ChangeProperty), minor code: 0
QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Known activities: ("a2221466-77df-4092-b87a-b637b43f5ddc")
Registering ":1.24/StatusNotifierItem" to system tray
libkwinglutils: Invalid framebuffer status: "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Checking screens: available: (QScreen(0x2044bf0, name="LVDS1"), QScreen(0x2045870, name="VGA1")) redundant: QHash() fake: QSet() all: (QScreen(0x2044bf0, name="LVDS1"), QScreen(0x2045870, name="VGA1"))
kf.plasma.quick: Applet preload policy set to 1
kdeconnect.core: Could not query capabilities from notifications server
org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
qml: The backend got an unknown wallpaper provider type. The wallpaper will now fall back to the default. Please check your wallpaper configuration!
org.kde.plasma.kicker: Entry is not valid "kontact.desktop" QSharedPointer(0x335e0d0)
org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x336ee60)
org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x335ca30)
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
Both point size and pixel size set. Using pixel size.
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:69:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:19:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredHeight"
QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
libkcups: CUPS-Get-Printers last error: 0 successful-ok
libkcups: Create-Printer-Subscriptions last error: 0 successful-ok
libkcups: Get-Jobs last error: 0 successful-ok
Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
file:///usr/share/plasma/plasmoids/org.kde.kscreen/contents/ui/main.qml:30:5: Unable to assign [undefined] to bool
file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
qt.svg: <input>:956: Could not resolve property: #radialGradient4782
qt.svg: <input>:956: Could not resolve property: #radialGradient4857
qt.svg: <input>:956: Could not resolve property: #radialGradient4883
qt.svg: <input>:956: Could not resolve property: #radialGradient4885
libkcups: 3 "Dell_C1760nw_Color_Printer_"
libkcups: 0
libkcups: 0
qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaData
kf.coreaddons: Expected a KPluginFactory, got a KIOPluginForMetaDataHow do I get the ability to use a projector back?
Somebody smarter than me will likely be along directly, but my first thoughts were:
1. xwayland???? Does that even work on 32 bit?
2. KDE on a low spec 32 bit machine? That's like the most complex and resource-intensive DE.
Devuan 6 mate-mini iso, pure Devuan, 100% no-vuu-do, mostly
Well I can take the point about KDE but:
1. It was fine on Chimaera and
2. On Daedalus I can't run two monitors on xfce either.
I don't want Xwayland and don't know whether Chimaera used it as I had no need to check - it just worked. Is there an alternative, other than Wayland which doesn't work at all with a second monitor plugged in?
Maybe I'll have to accept this laptop has reached the end of the road for Devuan at Chimaera for my use case, but it would be expensive to replace. I only use Devuan on 32-bit machines because it's one of the few non-systemd distros still supporting them, so it keeps them out of landfill and reduces waste.
FWIW, I just plugged in a second monitor on my Asus EEE 32-bit netbook that's 14 or 15 years old. I had to add lxrandr to make it easy - click one checkbox and then hit the Apply button. It works. No KDE here. Openbox with some qt apps. Running excalibur with a 32-bit linux-libre kernel.
Don't be mistaken that you use Wayland on Daedalus. Your system is setup with X11 as your inxi shows. This XWayland stuff is just a compatibility layer.
Thanks, I upgraded to Excalibur and sure enough, it all works there, so it is specifically a Daedalus problem. It's possible if I added the backports repo I might have got a fix, but that's too late to test.
My only concern is that I'm running an unstable pre-release version on a critical machine now, but while it works I've no inclination to tinker further. Perhaps I should withhold updating until it is released or limit it to the security repo only.
I won't mark this solved as although there will eventually be a solution when Excalibur goes into Stable (assuming this doesn't change in the meantime), the problem persists for Daedalus users if they need to plug an extra display into a laptop, at least if it's using graphics like mine.
I fail to see why Trixie (which in Devuan is Excalibur) is in the hard freeze state all you will ever get for updates at this point are bug fixes/security updates of the frozen software versions already installed. Once the new OS software is released as stable then the security archive starts to get packages as those issues come up.
That's interesting. I don't follow Debian development. I'm just a Devuan user.
I do I have been using a Debian or one based on it distribution since Woody was released in 2004 I think it was, so I have been through a few releases in that time. That is how it works it is at the stage now where nothing new is going to enter the archives for the coming release. So you can safely do updates knowing that they will be only the already mentioned bug fixes or security updates for the now fixed in stone versions of the software installed. Which is the main complaint against Debian as time goes on until the next release the outdated versions of the software installed in the current stable, as it takes them about two years between the stable release cycles to release the next version. But if you are interested in stability and something that just works day after day basically for years to come Debian stable and distributions based on it are unbeatable for that.
