#1 2025-07-12 01:57:23
Anyone have familiarity with GrapheneOS?
Like, what kind of cable is needed, the steps needed to be taken, how to get it detected via webusb, etc...
I dislike chromium, but firefox alas does not support webusb.
(unfortunate...)
Anywho, I wondered if anyone has done this before on a pixel 7. Mine has OEM unlockable setting and I a long time ago did a jailbreak on an old samsung phone.
So I am not completely lost.
But anywho, feel free to help if you know how to do this.
Reasons for wanting to do this?
Google is scary with its tentacles even on  their pixel devices which are more secure than most other android devices.
Which is for their competition very sad that they do security worse than Google. tongue
#2 2025-07-12 02:46:12
Re: Anyone have familiarity with GrapheneOS?
A USB data cable, obviously. Same as you would use for ADB or fastboot any other time.
Same as flashing any other ROM, after doing whatever your hardware vendor requires to unlock the bootloader.
e.g. Enable debugging -> OEM unlock -> bootloader unlock -> reboot to fastboot -> fastboot flash [partition] [image file] (repeat as needed) -> reboot to recovery bootloader -> wipe /data ("factory reset") -> reboot to OS.
Why? Just use fastboot and follow the instructions on the grapheneos site. They even give you a shell script so you don't have to go through each step manually.
know how to do this
On a pixel specifically, no. I'm not about to fork-out for any "flagship" phone, let alone one made by Google.
Aside from vendor specifics like bootloader unlocking, android is android, fastboot is fastboot, and flashing a rom is much the same as it ever was. If the install page is anything to go by, this one is about as uncomplicated and "vanilla" a flashing process as you could want.
#3 2025-07-12 06:06:23
#4 2025-07-12 06:10:25
@steve_v I don't blame you for being skeptical of anything Google. But therr phones are honestly less crappy then most others. I am used to bloatware samsung by comparison.  Google Pixel 7 even with android on it is less bloated then the samsung's android.
Which is kind of sad for the samsung. Being worse than google is pathetic, for real.
by usb data cable, I assume you mean one made for transferring files. In any case,
Honestly, the only point I am probably confused about that you made is your first point.  I'll have to look on amazon or something to see what data cable I need probably.
Btw, appreciate you being helpful on this matter. Its a nice change.
#5 2025-07-12 06:14:31
@stargate-sg1-cheyenne-mtn I saw that already. My problem is I think I need to know what cable is needed to make this work.
like usb-a to usb-c data transfer?
I dunno myself.
I assume that is it though.
#6 2025-07-12 06:45:32
bloatware samsung
That is was easily fixed by flashing an AOSP-based bloatware (and touchwiz) free ROM, of which there are were many. These days that's a non-starter, as most modern samsung phones use their in-house (exynos) SOC, and that requires unobtainable proprietary modem firmware for VoLTE and 5G support.
You can still root and debloat the stock ROM, and that's still a serious improvement, but AOSP builds are kinda dead until someone reverse engineers the modem.
If you want a reasonably priced bootloader-unlockable phone that ships (mostly) bloat-free OOTB and works well with third-party AOSP builds, I suggest Motorola. They're also not bad to work on, for when you inevitably smash the LCD or need to replace a port.
Google works too of course, and third-party ROM support is probably the best of all... It's just the price that stings. I really don't need a high-end device, and I have no interest in "premium" features or 50 cameras.
worse than google
It's just the bloatware and custom UI really, and that can mostly be fixed if you're willing to root it (and trip knox). Hardware and build-quality wise, Samsung are pretty good.
It could be worse... Most cheap Chinese brands are bootloader-locked and unrootable, and some even ship literal malware in the stock OS.
Dude, seriously, just a plain-old USB cable. The kind that comes in the box with pretty much every tech gadget and multiplies in everyone's desk drawers.
So long as it has appropriate plugs for the things you want to connect it to (likely USB-A[male] -> USB-C[male]) and all the wires (i.e. not a "charging only" cable, if those even still exist), it'll be fine.
Well, you're not raging at the sky or slandering anyone in this thread. vOv
#7 2025-07-12 08:00:16
re: "charging only" cables
best guess is when a batch of cables Q.C.ed bad for data at a high-enough failure rate then they magically became "charging-only" cables(ooohhh, specialty item...sigh...argh)
#8 2025-07-12 10:32:49
They were actually an intentional thing for a bit, back when active power-delivery negotiation specs were still a total mess.
If devices couldn't agree on a current limit, they would default to 100mA (which sucked), but there was a dumber standard that pretty much everything understood...
Bridging the data pins with a <200ohm resistor indicated a device was a charger that could deliver up to 1500mA, and it saved the manufacturer on both the power-delivery IC and the two extra wires.
This is supposed to happen inside the power supply/charger rather than a generic-looking cable of course, but Chinese manufacturers aren't exactly well-known for adhering to spec... So a few "magic" cables that would make your not-entirely-compatible (or just buggy) charger and device settle on an amp or so made it into the wild, as did cables that look like a standard USB cable but aren't, because they shipped with a charger and it saved a few cents to use normal connectors but only two wires.
I've made such cables myself, they're kinda handy if you want to get an old phone charger or powerbank to "just gimme power" for not-really-usb purposes (or blow fuses on old motherboards, to be tried only if you like fiddly soldering wink ).
All this went away with later USB specs and fast-charging, which mandate active negotiation.
#9 2025-07-12 12:52:56
power and fuses and circuitboards, oh my!...beware the Magic Smoke!?
https://en.wikipedia.org/wiki/Magic_smoke
re: ... oh my!
https://en.wiktionary.org/wiki/lions_and_tigers_and_bears,_oh_my
and to get that earworm out, Bad Wolves tribute covering Cranberries Zombie rip Dolores O'Riordan:
https://www.youtube.com/watch?v=9XaS93WMRQQ
peace out
#10 2025-07-12 19:03:12
Nah, wrangling angry pixies and sniffing magic smoke is kinda my day-job. Nothing to "beware" of really, just keep one hand in your pocket and a fire extinguisher change of trousers believable excuse handy.
Bad Wolves
Not quite my jam, but close enough for government work. \m/
#11 2025-07-13 16:58:52
pcalvert
Since I use cheap phones that don't allow the bootloader to be unlocked, I basically gave up on the idea of using a custom ROM, even one that I've customized myself. Sadly, even my Motorola (Moto G Stylus 5G 2021) phone won't allow the bootloader to be unlocked because it was made for Tracfone.
That being the case, the Universal Android Debloater seems like my best option:
https://xdaforums.com/t/2022-07-03-v0-5-1-universal-android-debloater.4069209/
Universal Android Debloater Next Generation
https://github.com/Universal-Debloater-Alliance/universal-android-debloater-next-generation
Another one is called Luxxle.
#12 2025-07-13 22:25:44
tracfone unlocking webpage:
https://www.tfwunlockpolicy.com/wps/portal/home/
sad how verizon has consumed Straight Talk, Net10, Clearway, Total, Tracfone, Simple Mobile, Safelink(obamaphone), and Walmart Family Mobile
#13 2025-07-14 04:22:31
@steve_v I don't think though Samsung phones that are unlocked can use verizon and certain other carriers too.
I could be wrong, but as for pixel devices, if you don't get them from the wrong source, yes its possible.
#14 2025-07-15 01:55:45
pcalvert
stargate-sg1-cheyenne-mtn wrote:
AFAIK, that's just for unlocking the ability to switch to a different carrier and has nothing to do with the bootloader. I would love to be wrong, though. Maybe I should try to unlock the bootloader on my Motorola phone to see what happens.
#15 2025-07-15 04:50:30
Carrier branded phones might well have a locked bootloader as well (it's an option a carrier can request from the OEM), but IME that level of dickery is mostly a 'murican thing. Down here carrier locks of any kind are a rarity (outside of hire-purchase type arrangements), as is carrier branding in general... because we still have consumer-protection laws 'n stuff.
Personally I just refuse to deal with any provider that doesn't allow BYOD, and refuse to buy any device that's locked to a specific provider.
That usually means purchasing the hardware up-front at full price (or the used market, which I am a big proponent of in general), as opposed to the whole "sign up and get $phone on discount / glorified hire" thing. I'll gladly do that if it means I actually get to own my stuff. Matter of fact, everything I own I actually own, as a matter of principle.
My current phone came from England via ebay, and I did my own research on radio frequencies, carrier compatibility, lock status, parts availablilty and third-party OS support.
It was certainly more work than "sign up with $provider, get phone, use phone", but OTOH this one is mine, and I get to do whatever I want with it, for as long as I want (or at least until the next ridiculous [X]G hype-wave).
#16 2025-07-16 01:45:56
@steve_v Your british? Hmm... wouldn't have known.
#17 2025-07-16 04:27:58
Your british?
Nope. There's a clue in there if you really want to play guessing games, but that wasn't it.
#18 2025-07-16 04:47:30
@steve_v well I guess I took it out of context, you mentioned the phone coming out of Britain. I guess i got mixed up. Nevermind...
#19 2025-07-18 15:18:05
I installed it as of today, so fat so good, it works like it did before with the carrier in it, but better.
The only unfortunate thing is I couldn't install grapheneos  in firefox. I  had to install chromium to do it via webusb.
All in all, good to go!
#20 2025-07-18 15:28:03
^^^@zapper, thanks for your installation report! keep us posted on your experiences/observations/progress/etc
#21 2025-07-18 23:25:36
@stargate_sg1_cheyenne-mtn
I have already noticed at least one small difference.
The way you close multiple tabs is to flick to the side of the bottom of the touchscreen. It was rather annoying that this was changed in grapheneos. But now that I know how it works, its fine.
I have yet to see the battery life and how good it is though.
I anticipate though that it will save battery life on a massive scale because it won't be doing as much dialing back to random places. the three letter agencies and google. Although it still has verizon, so there will be some minor problems there.
But its an improvement, a massive one.
