#1 Yesterday 07:50:55
pearmypie
Good X11 environment for laptops? Plasma 6 is not ideal
Hello!
Please don't suggest Wayland. I really like and do use X11 as a network protocol.
I am using KDE Plasma 6, I just installed Devuan testing and made sure everything is up to date. The experience out of the box is not ideal. KDE is configured not to have keybinds for increasing or decreasing volume (you can set them, but loading the default values will remove these keybinds). There aren't many trackpad gestures set out of the box (such as changing workspaces and whatnot). I will investigate if they can be set, but I don't have high hopes.
Gnome is worse. Even if libinput does support multi touch gestures, Gnome does gestures using their Wayland compozitor and won't work without the `touchegg` package.
Should I migrate to XFCE or Cinammon? Is anyone using X11 on laptops and can share their advice?
#2 Yesterday 07:57:15
Andre4freedom
Re: Good X11 environment for laptops? Plasma 6 is not ideal
Cinnamon works perfectly well on Devuan 5 (Daedalus) and Excalibur, and all this on X11 (Xorg).
XFCE works as well, but Cinnamon is the way to go when looking for comfort. All this "out-of-the-box" - and can be tweaked too.
I have no intention to burn my fingers with Wayland.
#3 Yesterday 08:20:52
pearmypie
I think I'll install both since they use the same display manager by default. Do you know if it's possible to switch workspaces using three finger gestures?
#4 Yesterday 11:22:10
Andre4freedom
Sorry, here I'm lost. I should first get to know what a three finger gesture is. I use mostly a desktop computer and a laptop only when out of office.
#5 Yesterday 11:29:52
E.g. ctrl-alt-$something
#6 Yesterday 11:45:04
Andre4freedom
Just a hint:
https://www.debugpoint.com/cinnamon-5-8-features/
Devuan Excalibur is at Cinnamon v. 6.4
Devuan Daedalus at 5.6
Good luck.
#7 Yesterday 12:37:44
Hmm... One finger is very rude, two fingers is "I can still shoot you", three fingers is... More fun? tongue
Close... While those do often require 3 fingers... they're not "gestures".
pearmypie wrote:
trackpad gestures
Methinks OP is referring to those newfangled things you drag your phalanges around on smear grease all over. Sometimes they're part of the display so the grease blurs your terminal and you scratch the tube trying to wipe it off, but more often they're in the palmrest of a luggable so as to catch coffee and be as irritating as possible while you're trying to type.
Horrid idea all around if you ask me, but that's what the kids are into these days.
@OP: I have no idea, I hate trackpads with a passion. Best try it and find out, push-comes-to-shove just use touchegg or similar (which I expect you will need to build yourself) to convert hand-waving into proper keybinds. That should work with any DE or WM, and any action you can bind keys to (provided libinput supports multi-touch for your hardware to begin with).
As for X on laptops, sure... A thinkpad with real mouse buttons and a nipple nub whatever the red rubber thing is that makes it so I don't have to take my fingers off the keyboard to move the cursor around. wink
#8 Yesterday 14:50:13
Surprised nobody mentioned Mate, Devuan's Mate version is very nice. Not sure about the touchpad stuff as I never use it.
https://sourceforge.net/projects/vuu-do/ New Vuu-do isos uploaded April 2025!
#9 Today 00:28:59
Last millennium we talked like this:
https://en.wikipedia.org/wiki/Control-Alt-Delete
