As a newbie to the debian/devuan world (but not to Linux) I found that my biggest obstacle was all things related to packages since because of almost 3 decades of using RPM based distros my brain is hardwired to the rpm commands to query installed packages and their dependencies.
So in a quest to both familiarize myself with the equivalent dpkg and apk commands and to make my life on Devuan easier I decided to write a small tool (a Perl script) that translates common rpm commands to the equivalent dpkg/apk commands.
For now the tool supports the following rpm commands (these are the ones I use most commonly) but I might add more in the future:
rpm -qa
rpm -qi <pkgname>
rpm -qip <filename>
rpm -ql <pkgname>
rpm -qlp <filename>
rpm -qR <pkgname>
rpm -q --whatrequires <pkgname>
rpm -q --changelog <pkgname>
rpm -qf </path/file>The tool is called 'drpm' (I couldn't call it 'rpm' as the rpm binary is available in the debian repositories so there would have been a name clash). It can be downloaded here: https://downloads.linuxtech.net/drpm/
That link will download a zip file which contains the script, just unzip it and place the script somewhere in your path (for example in /usr/local/bin/ ) and make it executable:
chmod 755 /usr/local/bin/drpmIn addition to that you need to install one dependency (a Perl library) from the debian/devuan repos:
sudo apt install libswitch-perlThere is no man page for now but if you run drpm in a terminal without any arguments you will get a brief help message.
The tool is provided "as is", the MIT license applies.
It should work on any distro that uses dpkg and apt for package management.
I hope it will be useful to fellow Devuan newbies who are coming from rpm-based distros.
Any bugs or problems please let me know.
Here are some examples of drpm being used on Devuan Excalibur:
user@vm:~$ drpm -qa|grep xorg
xorg 1:7.7+24
xorg-docs-core 1:1.7.3-1
xorg-sgml-doctools 1:1.11-1.1
xserver-xorg 1:7.7+24
xserver-xorg-core 2:21.1.16-1.1devuan1
xserver-xorg-input-all 1:7.7+24
xserver-xorg-input-libinput 1.5.0-1
xserver-xorg-input-wacom 1.2.3-1
xserver-xorg-legacy 2:21.1.16-1.1devuan1
xserver-xorg-video-fbdev 1:0.5.0-2
xserver-xorg-video-intel 2:2.99.917+git20210115-1
xserver-xorg-video-qxl 0.1.6-1.1
xserver-xorg-video-vesa 1:2.6.0-2
xserver-xorg-video-vmware 1:13.4.0-1user@vm:~$ drpm -qi xserver-xorg
Package: xserver-xorg
Status: install ok installed
Priority: optional
Section: x11
Installed-Size: 203
Maintainer: Debian X Strike Force <debian-x@lists.debian.org>
Architecture: amd64
Source: xorg
Version: 1:7.7+24
Provides: xserver
Depends: xserver-xorg-core, xserver-xorg-video-all | xorg-driver-video, xserver-xorg-input-all | xorg-driver-input, xkb-data, x11-xkb-utils
Recommends: libgl1-mesa-dri, xserver-xorg-legacy
Description: X.Org X server
This package depends on the full suite of the server and drivers for the
X.Org X server. It does not provide the actual server itself.
Homepage: https://www.x.org/user@vm:~$ drpm -q --whatrequires xserver-xorg
xserver-xorg
Reverse Depends:
xorguser@vm:~$ drpm -qR xserver-xorg
xserver-xorg
|Depends: xserver-xorg-input-all
Depends: xkb-data
Depends: x11-xkb-utilsuser@vm:~$ drpm -qf /usr/bin/Xorg
xserver-xorg-core: /usr/bin/XorgLast edited by tux_99 (2025-07-09 04:31:21)
“Either the users control the program – or the program controls the users” Richard Stallman
Cool script! I really like little utilities that help folks ease into a new system and get up and running quickly, nice work!
Devuan 5 mate-mini iso, pure Devuan, 100% no-vuu-do.
Devuan 6 version also available for testing.
Thanks greenjeans, when I find some time for it I will try to make a deb package for this tool, not because it really needs it (it's just a simple script with one dependency) but rather as an opportunity to learn how to make deb packages.
Nice, pretty much what i've been doing for the last week or so, been meaning for a long time to learn to package, so i'm easing into it with easy stuff, just building the structure manually and using dpkg-deb --build.
