#1 2025-07-05 20:40:58
Micronaut
How are 'live' disks that can boot on many systems created?
Is there an option in the standard installer of Devuan -- or any other major distro -- to include all the files you need to test at boot time and choose the right drivers for whatever system the disk has been placed in? Or is that a special mode that has to be configured by expert devs?
#2 2025-07-05 22:40:49
RedGreen925
Re: How are 'live' disks that can boot on many systems created?
That is by definition what most live boot systems are. They are designed to have pretty much all the drivers needed to boot on most hardware. Now there are some live boot systems which only boot on certain hardware like a Pi or other such specialized hardware. But for the most part the 32 and 64 bit live disks for the most common Intel/AMD processors will boot on the vast majority of the hardware out there doing what you want without any extra effort.
#3 2025-07-05 23:15:46
Micronaut
Yeah, but they are fixed on CD. If I install from a "live" CD don't I get a system adapted to the hardware I installed on? If I want to take an HDD with a personal install (choice of applications) and use it in several different systems, can I make such an HDD with a typical "Live" disk?
#4 2025-07-05 23:39:03
A live disk will install the system that's on the live disk. It's not designed for you to select software like the installer isos are. If you want a live CD that has your customizations on it, you need to make your own. You could install and run refractasnapshot in your HDD system and make a live iso that's a copy of that system, then you could use that to install the same thing to other computers.
#5 2025-07-05 23:57:00
^^^What he said is exactly how I would do it.
I started work on a script a while back that's now on the back-burner, that would query your system to find out what all firmware was actually being used and what was superfluous and could be un-installed and do so. But that kinda stuff is fraught with peril, even if I got it working for me I doubt I would make it public as there's too much that can go wrong.
Seems like I remember PclinuxOS had such a script way back in the day, don't know if they still do.
#6 2025-07-06 01:21:59
Micronaut
It's odd how you can ask the same question multiple times and never be understood. Is it so impossible to create an HDD that can boot on multiple systems like a "live" CD, that no one can even comprehend the question? I would think it would be possible to tell your OS to install all available drivers and use a slightly modified boot process similar to what a live CD uses.
#7 2025-07-06 03:14:38
generally speaking the linux kernel continues to grow in size partially because of new devices being added as time marches on:
https://www.kernel.org/doc/html/latest/driver-api/driver-model/index.html
so for example, devuan installed on an ssd could be moved between different machines as long as they were the same architecture
also you might find these interesting as well:
https://www.theregister.com/2022/06/20/redbean_2_a_singlefile_web/
https://justine.lol/cosmo3/
https://github.com/jart/cosmopolitan
#8 2025-07-06 15:37:45
That's not really the same question you asked in the original post, you kinda moved the goal-post my friend.
I guess what you're asking might be possible, you should try it.
But I don't see the point when it's easy to make a much more portable USB stick with your system on it that will boot up any machine. Use Refracta2usb and you can get persistence, multi-boot if you want more than one system on the USB, and also additional partitions just for data.
It's also possible to make a USB system that's NOT a live-session, you can do a conventional install on a USB stick too, i've done it with Refracta Installer. Perhaps that would be more suitable to your purpose.
Either way, good luck! smile
#9 2025-07-06 22:04:30
RedGreen925
Certainly can and is what my cloning script does. It takes my live running system and clones it to the drive I choose which I then boot it on. When booting the boot process does hardware probes which will load the required drivers for the system booted on. Where you can run into problems is when you have nvidia card using the proprietary drivers that will fail on machine without one in it that can use the driver installed. I rarely do installs any more it is simple clone boot then clone onto new machine once booted. Edit three files to change the UUIDs required for the new machine drive to ensure proper booting once done and reboot to new install with all of my previous information and settings intact.
The way it can be done with a live USB is by booting the live installer on your original install. with new machine drive connected to it. Then you open a terminal and partition the new drive and format it. You then mount the current install drive partitions and the new install drive partitions. Using the rsync program you copy byte for byte the original to the new drive then make the UUID changes in the already mentioned three files for EFI install, MBR no clue. Take the drive put it in the new machine and it should just boot. I made post just the other day giving all of the commands needed to do it.
Edit: The thread that contains the instructions.
https://dev1galaxy.org/viewtopic.php?id=7275
#10 2025-07-07 16:49:24
GNUser
Hi, Micronaut. Not impossible. It just requires attention to small details that are often overlooked.
My household is GNU/Linux-only. My wife and I homeschool our 6 kids, who need laptops for online classes. They are rough with the laptops so I find myself frequently pulling an HDD out of a damaged laptop, putting it into a "new" laptop of different make and model, and needing it to just work.
There are at least two things to consider:
1. Partition names
Your bootloader (I use grub2) may use different names for the same partition on the HDD, depending on the machine being used. For example, grub may call the first HDD partition (hd0,gpt1) on one machine but (ahci0,gpt1) on another. Using UUIDs in the bootloader's config file (grub.cfg) avoids any of this kind of ambiguity.
2. Legacy BIOS vs. UEFI
The HDD should be able to boot regardless of whether it finds itself in a legacy BIOS machine or UEFI machine. The trick to accomplish this is to create both an EFI partition and a "BIOS boot partition."
Nomadic operating systems (meant to be installed on a USB drive and used on whatever machine is available)--such as Tiny Core Linux--have to worry about all the above all the time, so they have experience dealing with this. You may find some helpful tips at these two links:
https://forum.tinycorelinux.net/index.p … 364.0.html (the excellent first post in the thread)
and
https://forum.tinycorelinux.net/index.p … #msg172581 (reply #51 which I wrote last year when trying to achieve same thing as you)
Hope that helps. If you have any questions let me know and I'll try to help.
#11 2026-02-24 10:25:35
tyder
I have just set  up HDDs to work like 'live' CDs, with persistence. It's not hard at all. And the inevitable disk crash problems become almost trivial to handle. Full system backup may amount to copy one file.
Has anybody tested exactly how much is won by doing this driver selection and tailoring vs just running a live system with persistence?
A live system with persistence may, generally, be moved around with small problems. And when the compressed 'live' part is < 10 GB, space is not a problem. Slower running might be, but even 15 years ago, that was not a problem for me, with adequate RAM and good disks.
Booting should not be a problem when a small selection of hardware is targeted, and in any case, there seem to be several solutions to that.
