Pages: 1
So I don't think I ever posted the completed script for this, i'm ridiculously proud of this as it's very useful (to me at least) and it's the first complex script that I actually made work in Python. The issue it helps with is defined somewhat in my loooong comments in the script, it's a really strange one and I have it narrowed down pretty much in the source code right where they screwed up, but my bug report has sadly gone unnoticed and I don't quite have the chops to fix it myself, yet. So I made a band-aid.
Issue is the setting in PcmanFM preferences for thumbnailing does NOT do what it says it does, it actually controls caching of thumbnails, and that would be fine but unfortunately it also has a weird effect upon thumbnailing which in turn affects caching too. At any setting below about 4.2 mb it randomly refuses to thumbnail and cache image files of various sizes, it's very arbitrary and occurs quite a bit at the factory setting of 2 mb, lower or raise it just a bit from that, and a whole different batch of files refuses to thumbnail/cache. But up above 4.2 mb and it will properly thumbnail all image and video files and properly cache anything over that 4.2 mb size.
Which is better than refusing completely, but still means as you add images nothing under that level will get cached, and if you have an image-heavy folder with lots of them under that size then every time you return to that folder it has to re-thumbnail all the images which takes a lot of time and is very frustrating to workflow. So I made this script which catches all images/vidoes in your home folder, checks to see if it has a thumbnail cached and if not it creates one for images/videos 100k and up. I have it set to run once at login, but also a menu entry so I can refresh it at any time if I add a lot of images under that 4.2 mb size.
It's fast and works seamlessly, I used parallel-processing too to speed it up quite a bit, default is to use up to 4 processes but if you have a 16 core machine you can adjust that to use more. And adjust lower limit for caching and thumbnail size. Anyhoo, maybe somebody can use it, if you use PcmanFM you should definitely try it.
#!/usr/bin/env python3
# This script creates and caches thumbnails of image/video files.
# It sweeps the user's home folder only (excluding hidden files), checking the
# status of image and video files for cached thumbnails, if needed it creates
# new thumbnails and adds them to the thumbnail cache in ~/.cache.
# Intended use is for PcmanFM, to assist in generating a proper thumbnail cache.
# It can be set to run once at boot/login, and/or used with a menu entry to
# create an updated cache file at any time.
# PcmanFM will continue to generate the cached thumbnails for images larger than
# 4.2 mb on-the-fly per the default setting in Vuu-do, at 4.2 mb or higher the
# thumbnail setting in PcmanFM works (mostly), any lower and you start losing
# thumbnails of arbitrary sizes randomly for some reason, this script catches the
# smaller stuff and anything else, albeit not on-the-fly which would be optimal,
# but even just running this once at boot helps a LOT.
# Copyleft: greenjeans 2025, use as you see fit. https://sourceforge.net/projects/vuu-do/
# Version: 1.02 - adds support for .jxl format.
# This is free software with no warranty, use at your own risk.
# Depends: python3, python3-pil, the gdk-pixbuf, heif, and ffmpeg thumbnailers,
# libjxl and libjxl-gdk-pixbuf version 0.11.1 or higher.
import os
import subprocess
import hashlib
import urllib.parse
import mimetypes
import time
from pathlib import Path
import logging
from PIL import Image
import PIL.PngImagePlugin
from multiprocessing import Pool, cpu_count
# Set up logging. Logs/errors in ~/.xsession-errors.
logging.basicConfig(level=logging.INFO, format='%(asctime)s - %(levelname)s - %(message)s')
logger = logging.getLogger(__name__)
# Configuration. Svg, webp, and jxl files are handled now by gdk-pixbuf-thumbnailer.
# Image/heic must be defined here in addition to image/heif.
HOME = str(Path.home())
CACHE_DIR = os.path.join(HOME, '.cache', 'thumbnails', 'normal')
MIN_FILE_SIZE = 100 * 1024 # 100 KB in bytes, everything above this size gets thumbnailed/cached. (edit to change)
THUMBNAIL_SIZE = 128 # Normal size per XDG spec. (edit to change)
THUMBNAILERS = {
'image/png': ['gdk-pixbuf-thumbnailer', '-s', str(THUMBNAIL_SIZE), '{input}', '{output}'],
'image/jpeg': ['gdk-pixbuf-thumbnailer', '-s', str(THUMBNAIL_SIZE), '{input}', '{output}'],
'image/gif': ['gdk-pixbuf-thumbnailer', '-s', str(THUMBNAIL_SIZE), '{input}', '{output}'],
'image/jxl': ['gdk-pixbuf-thumbnailer', '-s', str(THUMBNAIL_SIZE), '{input}', '{output}'],
'image/heif': ['heif-thumbnailer', '{input}', '{output}'],
'image/heic': ['heif-thumbnailer', '{input}', '{output}'],
'image/avif': ['heif-thumbnailer', '{input}', '{output}'],
'image/webp': ['gdk-pixbuf-thumbnailer', '-s', str(THUMBNAIL_SIZE), '{input}', '{output}'],
'image/svg+xml': ['gdk-pixbuf-thumbnailer', '-s', str(THUMBNAIL_SIZE), '{input}', '{output}'],
'video/mp4': ['ffmpegthumbnailer', '-i', '{input}', '-o', '{output}', '-s', str(THUMBNAIL_SIZE), '-t', '10'],
'video/mpeg': ['ffmpegthumbnailer', '-i', '{input}', '-o', '{output}', '-s', str(THUMBNAIL_SIZE), '-t', '10'],
'video/x-matroska': ['ffmpegthumbnailer', '-i', '{input}', '-o', '{output}', '-s', str(THUMBNAIL_SIZE), '-t', '10'],
# EXTENSIONS must be defined below in lowercase for case-insensitive matching.
EXTENSIONS = {'.png', '.jpg', '.jpeg', '.gif', '.heic', '.heif', '.avif', '.webp', '.svg', '.mp4', '.mpeg', '.mpg', '.mkv', '.jxl'}
def ensure_cache_dir():
"""Ensure the thumbnail cache directory exists."""
os.makedirs(CACHE_DIR, exist_ok=True)
logger.info(f"Thumbnail cache directory: {CACHE_DIR}")
def get_thumbnail_path(file_path):
"""Generate the thumbnail filename per XDG spec (MD5 of file URI)."""
file_uri = f"file://{urllib.parse.quote(file_path)}"
thumb_hash = hashlib.md5(file_uri.encode('utf-8')).hexdigest()
return os.path.join(CACHE_DIR, f"{thumb_hash}.png")
def add_png_metadata(thumb_path, file_path, mtime):
"""Add XDG-required metadata to the PNG thumbnail."""
try:
img = Image.open(thumb_path)
metadata = PIL.PngImagePlugin.PngInfo()
metadata.add_text("Thumb::URI", file_uri)
metadata.add_text("Thumb::MTime", str(int(mtime)))
img.save(thumb_path, "PNG", pnginfo=metadata)
logger.debug(f"Added metadata to {thumb_path}")
except Exception as e:
logger.error(f"Failed to add metadata to {thumb_path}: {e}")
def generate_thumbnail(file_path, thumb_path):
"""Generate a thumbnail using the appropriate thumbnailer."""
mime_type, _ = mimetypes.guess_type(file_path)
if not mime_type or mime_type not in THUMBNAILERS:
logger.warning(f"No thumbnailer for MIME type {mime_type or 'unknown'} ({file_path})")
return False
cmd = [arg.format(input=file_path, output=thumb_path) for arg in THUMBNAILERS[mime_type]]
try:
subprocess.run(cmd, check=True, capture_output=True)
logger.debug(f"Generated thumbnail for {file_path}")
return True
except subprocess.CalledProcessError as e:
logger.error(f"Thumbnailer failed for {file_path}: {e}")
return False
def needs_update(file_path, thumb_path):
"""Check if the thumbnail needs to be updated."""
if not os.path.exists(thumb_path):
return True
file_mtime = os.path.getmtime(file_path)
try:
metadata_mtime = img.info.get('Thumb::MTime')
if metadata_mtime and int(metadata_mtime) == int(file_mtime):
return False
return True
logger.warning(f"Invalid thumbnail {thumb_path}: {e}")
return True
def generate_thumbnail_worker(args):
"""Worker function for multiprocessing to generate a thumbnail for a single file."""
file_path, thumb_path = args
try:
if generate_thumbnail(file_path, thumb_path):
add_png_metadata(thumb_path, file_path, os.path.getmtime(file_path))
logger.info(f"Generated thumbnail for {file_path}")
return True
else:
logger.warning(f"Failed to generate thumbnail for {file_path}")
return False
logger.error(f"Error processing {file_path}: {e}")
return False
def scan_and_cache():
"""Scan home directory and generate/update thumbnails using multiprocessing."""
ensure_cache_dir()
file_count = 0
thumb_count = 0
tasks = []
# Collect all files that need thumbnailing, excluding hidden files, symlinks, and unreadables.
for root, dirs, files in os.walk(HOME, topdown=True, followlinks=False):
dirs[:] = [d for d in dirs if not d.startswith('.')]
for fname in files:
if not any(fname.lower().endswith(ext) for ext in EXTENSIONS):
continue
file_path = os.path.join(root, fname)
try:
if os.path.getsize(file_path) < MIN_FILE_SIZE:
logger.debug(f"Skipping {file_path} (size < {MIN_FILE_SIZE} bytes)")
continue
thumb_path = get_thumbnail_path(file_path)
file_count += 1
if needs_update(file_path, thumb_path):
tasks.append((file_path, thumb_path))
else:
logger.debug(f"Thumbnail up-to-date for {file_path}")
except OSError as e:
logger.warning(f"Skipping {file_path}: {e}")
continue
# Process tasks in parallel, default setting is to use up to 4 processes, this can be changed if needed.
if tasks:
num_processes = min(cpu_count(), 4)
logger.info(f"Generating {len(tasks)} thumbnails using {num_processes} processes")
pool = Pool(processes=num_processes)
try:
results = pool.map(generate_thumbnail_worker, tasks)
finally:
pool.close()
pool.join()
thumb_count = sum(1 for result in results if result)
logger.info(f"Processed {file_count} files, generated/updated {thumb_count} thumbnails")
def main():
"""Main function to run the thumbnail caching process."""
try:
scan_and_cache()
logger.error(f"Script failed: {e}")
raise
if __name__ == "__main__":
main()https://sourceforge.net/projects/vuu-do/ New Vuu-do isos uploaded December 2025!
Devuan 5 mate-mini iso, pure Devuan, 100% no-vuu-do.
Devuan 6 version also available for testing.
Please note the dependencies, they are all available in the repo except for the libjxl packages which are not in the repo, but are made by the same author and the version 0.11.1 is made specifically for daedalus/bookworm, and can be found here: https://github.com/libjxl/libjxl/releases?page=1
This is the one you're looking for: jxl-debs-amd64-debian-bookworm-v0.11.1.tar.gz
Extract and these are the three you want to install (2 if you don't use GIMP):
libjxl_0.11.1_amd64.deb
libjxl-gdk-pixbuf_0.11.1_amd64.deb
libjxl-gimp-plugin_0.11.1_amd64.deb
This looks pretty interesting. Thanks for your contribution!
Would this work with SpaceFM? Since it's forked from PCManFM (before the rewrite).
Thanks! It should work for anything, I have only tested it with Openbox/PcmanFM and Mate/Caja so far but it's totally agnostic so should work with any file manager/DE.
Okay, been better than 6 months and no action on bug report(s) to upstream, time to put on my battle-rattle on, sketching out a plan to patch PcmanFM, it's really a great basic file-manager, just the one bug and one feature I want to add. Now i'll see if i've leveled up enough to do this.
I'm using pcmanfm now since trying it in vuudo, it's great. I'm actually now using a lot of the stuff you use in vuudo that I had never tried before and it works a lot better then my old setup. I combined two "hobby" projects devuan and vuudo.
It's all flying along on my main box running 16gb ram, intel i7-12400F and nvidia rtx 4060
Installed excalibur sysvinit with no desktop environment, xlibre, openbox, pcmanfm, lxpolkit, lxterminal, lightdm, tint2, obmenu-generator, obsession, nitrogen, nvidia cuda driver, brave, pluma and my chat bot program jack-bridge.
I've got the best working setup I've ever had thanks to the info in this forum
SOURCEFORGE jack-bridge
Pages: 1
