#1 2025-05-31 15:54:09
webman
[SOLVED] Non-root-users cannot ping in devuan5-based lxc-container
Hello!
Probably someone could shed some light onto this:
ping -c2 192.168.26.252
ping: socktype: SOCK_DGRAM
ping: socket: Address family not supported by protocol
System:
~$ lsb_release -a
No LSB modules are available.
Distributor ID:	Devuan
Description:	Devuan GNU/Linux 5 (daedalus)
Release:	5
Codename:	daedalus
Linux devu5test 5.10.0-0.bpo.9-amd64 #1 SMP Debian 5.10.70-1~bpo10+1 (2021-10-10) x86_64 GNU/Linux
This not an exception - I am "on the road" to replace my debian infra with devuan and starting
with containers. All behave the same.
Wether on debian 10/11/12 lxc-containers have that problem.
There are no firewall/iptables restrictions in use making this tests.
I read in another thread (from 2024 in galaxy) that this even happend on hardware,
which - at least - my first and only hardware installtion does not have.
I generally install iputils-ping. it has nothing to do with interfaces and routes, I use
always the same structures.
Thanks,,
Manfred
#2 2025-05-31 16:11:19
Re: [SOLVED] Non-root-users cannot ping in devuan5-based lxc-container
The kernel 5.10.0-0.bpo.9-amd64 is definitely not from Daedalus. Daedalus uses linux-image-6.1.0* or 6.12 from backports.
#3 2025-05-31 16:33:58
webman
Yes, ok.
But containers should be - at a degree - run on different kernels.
The container has been created by zfs send/recv, which worked in my experience.
BTW, the other containers, using debian 10/11/12 use exactly this same kernel.
Why should ping work with them?
Why can I even install a devuan-lxc on the same box?
Thanks,
Manfred
#4 2025-06-01 02:09:23
Which kind of interface is set up for 192.168.26.252 ?
If it uses some pcap connection (like "user" networking in qemu), then it would only support IP level networking and ICMP would not be supported. I agree it's an LXC (on Devuan) issue although it may also be an admin choice of local networking. (I don't know LXC well enough to tell).
How is your networking set up?
#5 2025-06-01 12:01:50
trinidad
See the link about this address scheme.
https://en.ipshu.com/ipv4/192.168.26.252
TC
Often unawares.
#6 2025-06-01 19:13:24
webman
Thanks for the replies!
@ralf, the interfaces are defined in the containers config file like this:
lxc.net.0.type = veth
lxc.net.0.name = eth0
lxc.net.0.veth.pair = ct-eth0
lxc.net.0.link = hovmbr
lxc.net.0.flags = up
#lanbr - optional, but now under test
lxc.net.1.type = veth
lxc.net.1.name = eth1
lxc.net.1.veth.pair = ct-eth1
lxc.net.1.link = lanbr
lxc.net.1.flags = up
Both end up in a bridge of the host (the first terminates at the host).
This usually works always and I rarely need others (but used macvtap, hardware).
All containers using this schema (debian + devuan), the debian'eses are working.
Using 'ip link' they appear like an ethernet interface.
Exact the same works on a devuan5 container on a devuan hardware.
For root, it works. For other usual users not (added another one for testing).
The users are only in their own and in the users group.
All firewall restriction have been removed on container AND host.
No ping is going out, ether which interface (destionation addr will be used).
A tcpdump does not show any outgoing packets (not even arp).
And the shown destination address has been random (though existing, running node),
it effects all - the routes are correct too (root has no different routing and it works).
@trinidad, that address is not my gateway, have never been it and something
linke wlan is NOT present.
Regards,
Manfred
#7 2025-06-01 21:14:36
webman
Hi All !
Found someone, who knows the bug.
Part of the message appears, if ipv6 has been disabled (everywhere in my infra), and I know this.
Came to the idea, to supply the "-4" switch (not neccessary) - and this show a complete different message:
$ pc2 -4 192.168.26.88
ping: socktype: SOCK_RAW
ping: socket: Operation not permitted                            <===
ping: => missing cap_net_raw+p capability or setuid?  <===
This was the same as in an older forum message with the same symptom, but this was hardware,
not a container. I compared working and non-working container, with no ideas.
But the leads to another websearch, which reveals the bug in a googl group:
I've installed mantic from the images repo multiple times and created multiple users, I've set lxc.apparmor.profile = unconfined, but nothing that I do will allow ordinary users to use "ping".
I've tracked this down.  It is a setting in sysctl.  For whatever reason it is set like this:
    net.ipv4.ping_group_range =  1      0
Changing to what most distros have:
    net.ipv4.ping_group_range = 0    2147483647     <===
and ping is available again.
NB. This was from -d ubuntu -r mantic from the default images repository.
After I set this value into sysctl.conf and applied, it works!
So this came from install sources.
I just duplicated another working container using zfs send/recv (from devu5 container on devu5 hardware) to
debian (where the devuan container live). The only change I had to do, was to replace:
lxc.include = /usr/share/lxc/config/devuan.common.conf
to:
lxc.include = /usr/share/lxc/config/debian.common.conf
So its not the "copying" of the container.
But thanks for all help!
Regards,
Manfred
#8 2025-06-01 22:56:11
Good find; appears to be a sysctl default with linux-image-6.1.0-28-amd64 (current daedalus). I guess someone found a "security" sticker and needed somewhere to put it so decided that "Oh! non-root users shouldn't be allowed to 'ping' willy-nilly"... or something.
Slightly odd though that you don't have the same with your debian setup, but perhaps that non-root user is more capable(?). (As we often find repeated: the packages in devuan are mostly debian's packages directly and not changed, other than the few that are forked and compiled by devuan)
#9 2025-06-02 02:19:06
webman
Hi Ralph!
Not completely true - because host, and therefore the container, is using kernel 5.10.
The mentioned new test-container (replicated by zfs), has been directly created on
devuan host using kernel 6.5 and does not have that problem running on the debian
host with kernel 5.10.
And indeed, it is strange - there will be no users, but services running as non-root.
I keep it in mind, when my new squid will come (which uses ping and so far I remember
right, form the non-root running process).
Regards,
Manfred
#10 2025-06-07 15:03:30
rbit
I just noticed this problem yesterday on a VPS that I use.  But it does not affect a different one.  Both on the same kernel, 6.1.0-37 (amd64).  May have something to do with the hosts.  Thanks for tracking it down and finding a solution!
