#1 2025-05-29 15:11:02
Giorgos
Proposed Updates repository problem.
Hi!  :-)
When executing (as root) "apt update", I'm getting this error:
#apt update
Ign:8 http://deb.devuan.org/devuan daedalus-proposed-updates InRelease
Err:12 http://deb.devuan.org/devuan daedalus-proposed-updates Release
404  Not Found [IP: 185.236.240.103 80]
E: The repository 'http://deb.devuan.org/devuan daedalus-proposed-updates Release' no longer has a Release file.
My related sources.list entry is:
deb http://deb.devuan.org/devuan daedalus-proposed-updates main contrib non-free
I think I'm missing something here.  :-)
Any thoughts?
#2 2025-05-29 15:30:39
Re: Proposed Updates repository problem.
If you try again?
#3 2025-05-29 15:56:42
Further reading: https://www.devuan.org/os/packages
Add stable proposed-updates (default: no)
proposed-updates are packages that will become part of the next stable point release but are not fully tested yet. It is usually safe to use them, but we recommend not using them on production systems. Note that there may be rare cases where a package from Debian's proposed-updates is needed, and in that case /merged should be used instead of /devuan below.
# /etc/apt/sources.list
deb     http://deb.devuan.org/devuan <release codename>-proposed-updates main
#4 2025-05-29 21:33:37
Giorgos
OK, got it!
I delete it.
THANKS!!!
#5 2025-05-30 00:00:20
You should use the devuan-proposed-updates repository, and the soures.list line for that is
deb http://deb.devuan.org/merged daedalus-proposed-updates main contrib non-free non-free-.firmware
Pay special attention to the /merged URI which is what all devuan repositories have because devuan provides a merge of debian packages with an overlay of certain forked packages.
You tried to use the URI /devuan and that didn't work because that is wrong.
EDIT: you may omit some sections, like e.g. non-free but should at least include main.
