#1 2025-05-18 15:57:46
[SOLVED] zramswap script won't start
Still working on my Asus 1000HE. 8^°
I have set up zram / zramswap with this script which I found referenced here.
Just in case, I added both the shebang (#!/bin/sh) and the usual PATH= variable as I saw it was missing.
I then named it zramswap, copied it to /etc/init.d, made it executable and did update-rc.d zramswap defaults.
The problem I have is that it does not start at boot and I can't figure out why.
But I can start it from a terminal:
$ sudo zramswap start
Setting up swapspace version 1, size = 1002.6 MiB (1051303936 bytes)
no label, UUID=05decff9-d90e-4db3-ae9d-a65484a3462c
$ sudo swapon -s
Filename				Type		Size	Used	Priority
/dev/sda5                              	partition	12595196	0	1
/dev/zram0                             	partition	1026664	0	20
$ cat /proc/swaps
$ sudo zramctl
NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0 lzo-rle    1002.6M   4K   74B    4K       2 [SWAP]
I can't get anything from running the script in a terminal either:
# /etc/init.d/zramswap start > /tmp/zramswap.log 2>&1
# cat /tmp/zramswap.log
#                           <- nothing to see here ...
Just in case ...
#!/usr/bin/env /lib/init/init-d-script
### BEGIN INIT INFO
# Provides:          zramswap
# Required-Start:    $syslog $time $remote_fs
# Required-Stop:     $syslog $time $remote_fs
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Linux zramswap setup
# Description:       Debian init script for zramswap
### END INIT INFO
PATH=/bin:/usr/bin:/sbin:/usr/sbin
DAEMON=/usr/sbin/zramswap
PIDFILE=none
_is_active() {
	$DAEMON status >/dev/null 2>&1
	return $?
do_start_prepare() {
	if _is_active; then
		log_warning_msg "$NAME is already active"
		exit 3
	fi
do_start_cmd_override() {
	$DAEMON start
do_stop_prepare() {
	if ! _is_active; then
		log_warning_msg "$NAME is not active"
		exit 3
	fi
do_stop_cmd_override() {
	$DAEMON stop
do_status_override() {
	$DAEMON status
do_restart_override() {
	if _is_active; then
		$DAEMON restart
	else
		$DAEMON start
	fi
How to troubleshoot this further?
#2 2025-05-18 23:20:23
Re: [SOLVED] zramswap script won't start
Hello.
I wrote:
... troubleshoot this further?
No need.
In true (and time proven) Linux fashion I found a way out.
ie: by doing it in a different manner.
For those interested, the whole explanation is here.
TL;DR
For whatever reason, it seems the problem of getting the/a zram script to start in /etc/init.d has been doing the rounds for a while.
I could not find out why.
The solution is to start zram, setting the parameters and the zramswap file directly from rc.local.
And Bob's your uncle.
To test, I just dropped in the lines posted but (just to be neat) I'll write up a short script as a replacement for that.
#3 2025-05-19 00:24:33
EDX-0
you could also give my https://github.com/eylles/zram-service script a try, it just works perfectly on my machine, also i'm planning to make it have some feature parity with what the rust-systemd-zram-generator so that it can also do mounts not just a single zram device as zramswap.
#4 2025-05-19 01:15:51
EDX-0 wrote:
Yes, I saw it.
But this is for an undepowered (Intel Atom N280/2Gb) ca. 2009 netbook for which I need a simple/easy solution.
The zramctl command can set up all the parameters I need in a jiffy in case the default ones are not suitable or I want to experiment.
Thanks for your input.
#5 2025-05-19 18:26:24
hunter0one
As another option I've ported the zramen script from Void Linux to Devuan. It comes with a working init script for Daedulus.
https://git.disroot.org/hunter0one/devu … ter/zramen
#6 2025-05-19 19:39:04
hunter0one wrote:
... ported the zramen script from Void Linux ...
... comes with a working init script for Daedulus.
Thanks for doing that for the team Dev1.
#7 2025-05-20 20:54:47
hunter0one
No problem. Its not actually in Devuan repos as I'm not sure how to propose it. It may have to first be enabled by you if I remember correctly. I am currently on PCLOS, not Devuan.
#8 2025-05-20 21:21:34
hunter0one wrote:
... not actually in Devuan repos ...
... not sure how to propose it.
... be enabled by you ...
No, not me. 8^D!
I'm just an interested observer.
That would be one of the admins (@golinux / @fsmithred / @Ralph.Ronnquist).
But I don't know what the process is / entails.
#9 2025-05-20 21:28:01
hunter0one
By enabled I meant that the init script does not start automatically if I remember correctly. You have to enable it with update-rc.d.
#10 2025-05-20 22:16:09
hunter0ne wrote:
... meant that the init script does not start ...
... enable it with update-rc.d.
Right ...  8^°
Sorry, my bad.
Yes, update-rc.d uses the INIT INFO fields and is mandatory when adding a script to /etc/init.d.
