#1 2025-05-16 20:36:39
[SOLVED] Compressor lz4 not available
Wanting to get the last possible bit of ooompf from my Asus 1000HE, I installed zswap.
Chimaera+Openbox do a good job.
But the 2.0Gb RAM is rather limiting, especially when using my coffee roasting software.
The system is up to date and the kernel command line has all the needed bits:
zswap.enabled=1  zswap.compressor=lz4  zswap.max_pool_percent=40  zswap.zpool=z3fold.
/etc/initramfs-tools/modules also has the needed bits:
lz_4
lz4_compress
z3fold
Yet the dmesg printout reads:
[     4.495646] zswap: compressor lz4 not available, using default lzo
Interestingly enough, opening a terminal and doing modprobe lz4 will actually load it and it will show up with lsmod.
Maybe it is the order in which these are loaded?
I'd appreciate some input on this.
#2 2025-05-16 23:33:51
Re: [SOLVED] Compressor lz4 not available
Maybe having lz4 in /etc/initramfs-tools/modules (and an update-initramfs run) would work?
What's lz_4 ?
#3 2025-05-17 00:42:16
ralph.ronnquist wrote:
Maybe having lz4 in /etc/initramfs-tools/modules ...
Indeed ...
That would have done it.
Except that, for some reason, I decided to add an (obviously unneeded) underscore.
Hence it not working as expected.
What's lz_4 ?
Hmm ...
Direct consequence of not taking my 20:00 pill?
Or maybe taking it twice.  8^°
Now it works.  8^)
[     4.473334] zswap: loaded using pool lz4/z3fold
There's nothing like paying attention to what you are typing.
While you are typing it.
Thanks so much for you input.
Have a good week-end.
