#1 2025-05-09 18:15:44
deepforest
[SOLVED] Hide message from bootlog
Hi)
I am use Ceres.
Successfully install 340.108 nvidia driver.
All working good, but every boot i see this message at first string
[    1.957565] udevd[199]: Error running install command 'modprobe -i nvidia-legacy-340xx ' for module nvidia: retcode 1
Its bit annoying. Is there way to hide this message?
Its related with dracurt or initramfs
When i use dracurt --force this string gone from bootlog
but i see another errors at boot
[    4.139449] systemd-udevd[406]: failed to execute '/lib/elogind/elogind-uaccess-command' '/lib/elogind/elogind-uaccess-command /dev/sg1 ': No such file or directory
[    4.170784] systemd-udevd[407]: failed to execute '/lib/elogind/elogind-uaccess-command' '/lib/elogind/elogind-uaccess-command /dev/sr0 ': No such file or directory
and again when i did update-initramfs -u i see again this
its collision loop...
ps here nvidia modprobe file
/etc/nvidia/legacy-340xx/nvidia-modprobe.conf
install nvidia modprobe -i nvidia-legacy-340xx $CMDLINE_OPTS
install nvidia-uvm modprobe nvidia ; modprobe -i nvidia-legacy-340xx-uvm $CMDLINE_OPTS
remove nvidia modprobe -r -i nvidia-uvm nvidia
alias char-major-195* nvidia
# These aliases are defined in *all* nvidia modules.
# Duplicating them here sets higher precedence and ensures the selected
# module gets loaded instead of a random first match if more than one
# version is installed. See #798207.
alias   pci:v000010DEd00000E00sv*sd*bc04sc80i00*        nvidia
alias   pci:v000010DEd00000AA3sv*sd*bc0Bsc40i00*        nvidia
alias   pci:v000010DEd*sv*sd*bc03sc02i00*               nvidia
alias   pci:v000010DEd*sv*sd*bc03sc00i00*               nvidia
smile
pyzNi 3.14zDa! smile
#2 2025-05-10 04:48:37
deepforest
Re: [SOLVED] Hide message from bootlog
its very werid
afrter manipulation with update-initramfs -u
now at bootlog i see
calling:trigger
calling:settle
instead
its seems systemd related?
ps system working and booting good
smile
#3 2025-05-10 23:41:33
deepforest
solved, thanks @All for useful answers here wink
add to grub
quiet loglevel=3
smile
